POV-Ray : Newsgroups : povray.binaries.scene-files : A-114 Grid Media - 1 attachment Server Time
19 Dec 2025 15:55:03 EST (-0500)
  A-114 Grid Media - 1 attachment (Message 1 to 5 of 5)
Subject: A-114 Grid Media - 1 attachment
Date: 5 Feb 2004 07:59:44
Message: <Xns94868E8FF4111raf256com@203.29.75.35>
Image in .images
simple media example
Download 'a00114_gid_by_raf256_com.pov.txt' (3 KB)
Subject: Re: A-114 Grid Media - 1 attachment
Date: 5 Feb 2004 15:28:03
Message: <4022A77C.2020303@web.de>
sorry, but can't see the .pov file in netscape-newsreader
bye
	espri128
Rafal 'Raf256' Maj schrieb:
> Image in .images
Date: 5 Feb 2004 15:29:10
Message: <Xns9486DABC459D3raf256com@203.29.75.35>
spr### [at] webde news:402### [at] webde
just copy/paste into *.pov :
  A-00114 Grid
  by Rafal Maj 'Raf256'
  http://www.raf256.com/
  http://www.raf256.com/3d/pov/
  mailto:raf### [at] raf256com
#declare QQ_MEDIA = 1;
#declare CFG_FOG = 0.30; // <-- for strength
global_settings {
  assumed_gamma 2
  max_trace_level 50
  location <-70, 81, -90>*1.5 // <-- camera X,Y,Z positon (left, up, back)
  #local P=<-3,5,5>; // <-- look at X,Y,Z
  look_at P
  angle 57
  #if (1)
    focal_point P
    aperture 1
    blur_samples 20
    variance 1/64
    confidence 0.98
fog {
  color rgb <.2,.25,.3>*.5
  distance 100/CFG_FOG
#declare Mat1 = material {
  #if (QQ_MEDIA=0) texture { pigment { color  <.6,.8,.97> filter .5 } finish { ambient
.5 }  }
  #else
    texture { pigment { rgbf 1 } finish { ambient 0 diffuse 0 } }
    interior {
      media {
        #local C =<.3,.4,.99>;
        #local C2=<.3,.6,1.2>;
        density { cylindrical
           //color_map {[0 rgb .1*C][.2 rgb .15*C][0 rgb .3*C][.5 rgb .3*(C+C2)/2][.8
rgb .8*C2][1 rgb 1*C2]}
           color_map {[0 rgb C*0][0.5 rgb C*0.25][1 rgb C2]}
        emission .05
#declare Mat2 = material {
.5 }  }
  #else
    interior {
      media {
        #local C=<.3,.72,.99>;
        density { cylindrical color_map {[0 rgb 0*C][.5 rgb .3*C][.8 rgb .7*C][1 rgb
1*C]} }
        emission .6
#local A1=-4; #local A2=+4; // <--- number of grid lines
#local E = 220; // <--- space between grid lines
#local R = 12; // <--- grid line thicknes
#local ofs = <12,1,2>; // <-- grid offset
#local J=A1; #while (J<A2) #local I=A1; #while (I<A2)
  #declare obj =
  cylinder {
    y*-1000 y*+1000 1
    material { Mat1 }
    hollow
    scale <R,1,R>
    rotate z*90 translate <0,I,J>*E
  object { obj translate ofs }
  object { obj rotate y*90 translate ofs }
  object { obj rotate z*90 translate ofs }
#local I=I+1; #end #local J=J+1; #end
#macro Cross(_a)
#local obj = merge {
  cylinder { y*-50 y*-_a 1 }
  sphere { 0 1 scale <1, 4, 1> translate -y*50 }
  material { Mat2 } scale <9,1,9>
  hollow
merge {
  object { obj rotate  z* 0 }
  object { obj rotate  z*180 }
  object { obj rotate z*90 }
  object { obj rotate z*270 }
  object { obj rotate z*270 rotate y*90 }
  object { obj rotate z*270 rotate y*270 }
object { Cross(12) translate <-2,2,-3>/2+ofs  }
#local objCross = Cross(3)
#local J=A1; #while (J<A2) #local I=A1; #while (I<A2)  #local K=A1; #while (K<A2)
  #if (I | J | K)
  object { objCross scale 1/3 translate <I,J,K>*E + ofs }
#local K=K+1;  #end  #local I=I+1; #end #local J=J+1; #end
Date: 5 Feb 2004 15:56:16
Message: <4022AE18.709@web.de>
Hi Rafal,
thanx
	espri128
>   A-00114 Grid
> global_settings {
>   assumed_gamma 2
>   max_trace_level 50
> camera {
>   look_at P
>   angle 57
>   #if (1)
>     focal_point P
>     aperture 1
>     blur_samples 20
>     variance 1/64
>     confidence 0.98
>   #end
> fog {
ambient .5 }  }
>   #else
>     interior {
>       media {
.3*(C+C2)/2][.8 rgb .8*C2][1 rgb 1*C2]}
>         emission .05
>   #end
ambient .5 }  }
>   #else
>     interior {
>       media {
1*C]} }
>         emission .6
>   #end
>   #declare obj =
>   cylinder {
>     y*-1000 y*+1000 1
>     material { Mat1 }
>     hollow
>     scale <R,1,R>
> #macro Cross(_a)
>   hollow
> merge {
> #end
>   #if (I | J | K)
>   #end
Date: 5 Feb 2004 16:22:14
Message: <4022B3C2.7080404@hotmail.com>
Rafal posts in UU-encode format.
I can not directly read that in my netscape either.
work around:
save file as *.uue (perhaps remove an extra .eml
extension later)
now you can read the file in e.g. winzip.
Winzip is quite forgiving with non UUE text
(i.e. the posting before the attachment)
If you use something more strict then you also have to
delete all lines before the line that begins with:
'begin 644 ....'
I noticed that Rafal did post his source in plain text
so it is not important anymore, but may be you can
use this trick some other time (e.g. to see his
images in pbi) ;).
> bye
>     espri128
>> Image in .images
