POV-Ray : Newsgroups : povray.binaries.scene-files : texture bluring v 0.55 WIP - 1 attachment Server Time
12 Jan 2026 10:50:56 EST (-0500)
  texture bluring v 0.55 WIP - 1 attachment (Message 1 to 4 of 4)
Subject: texture bluring v 0.55 WIP - 1 attachment
Date: 20 Jul 2002 08:05:52
Message: <Xns92518ED33590Eraf256com@204.213.191.226>
alsow on .general and .b.i
You can configure this file.
btw. how about copy/paste scenes (simple 1..500 lines) here (with no warp-
lines) instead of attache them ? Imho it would be a bit more comfortable to
im someone wants just to take a look on sources. Alsow this will allow to
quote part of source and comment it here.
> A jedyne co czytam, ze to terrorysci internetowi z echelonu planuja
> kolejny atak na centrale TPSA
- Expert vel Jacek (obecnie gol### [at] pocztaonetpl)
Download '2002_07_15_textblur.pov.txt' (3 KB)
Subject: Re: texture bluring v 0.55 WIP - 1 attachment
Date: 20 Jul 2002 08:10:52
Message: <3d39534c@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> schrieb im Newsbeitrag
That's what p.text.scene-files is for, isn't it?
Marc-Hendrik
Date: 20 Jul 2002 08:23:25
Message: <Xns925191CCF27C2raf256com@204.213.191.226>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in
news:3d39534c@news.povray.org
>> warp- lines) instead of attache them ?
sorry - I didn't use attachmenst often in news://
I.e. my previous posts in Xnews - I see only ~15 lines of regular text,
and informations that attachment has been decoded.
I was asking about putting .pov exacly in post body (not as attchment),
like this :
  Textur Blur Finction + example
  1:1 ratio
  started ~10.07.2002, last ver 0.55 20.07.2002 for 3.5win
// vvv OPTIONS ==================
#declare blur1_rad   = 0.02;  // radius +n. def.: 0.02
#declare blur1_sampl = 6;     // samples +n def.: 6  0=off
// pigment - MONOCHROME :
#declare fn1 = function {  pigment {
    marble color_map {[0 color rgb 0][0.1 color rgb 0.2][0.92 color rgb 0.5][1 color
rgb 1]}
    scale 2  turbulence 1.0
#declare blur2_rad   = 0.02;  // radius +n. def.: 0.02
#declare blur2_sampl = 6;     // samples +n def.: 6  0=off
#declare fn2 = function { pigment { checker color rgb 0 color rgb 1 scale <1,1,1000> }
// ^^^ OPTIONS ==================
#include "functions.inc"
camera { right x up y location -z*10 }
light_source { <-30,100,-100>*10 color rgb 1 }
#declare f1 = function(_x,_y,_z) {
  #if (!blur1_sampl)
    fn1(_x,_y,_z).gray
  #else
    #local r=blur1_sampl;  #local sc=blur1_rad;
    #local maxDist = sqrt(r*r*3);
    #local ax=-r; #while (ax<=+r)
      #local ay=-r; #while (ay<=+r)
        #local az=-r; #while (az<=+r)
          fn1(_x+ax*sc,_y+ay*sc,_z+az*sc).gray +
        #local az=az+1; #end
      #local ay=ay+1; #end
    #local ax=ax+1; #end
    0) / pow((r*2+1),3)
#declare f2 = function(_x,_y,_z) {
  #if (!blur2_sampl)
    fn2(_x,_y,_z).gray
  #else
    #local r=blur2_sampl;  #local sc=blur2_rad;
          fn2(_x+ax*sc,_y+ay*sc,_z+az*sc).gray +
    0) / pow((r*2+1),3)
sphere { 0 1
  texture { pigment { function { f1(x,y,z) } scale 0.2 } finish { specular 0.9
roughness 0.02 } }
  texture { pigment { function { f2(x,y,z) }
    color_map { [0 color rgbf <1,.1,.1,.5>][1 color rgbf <1,.9,.6,.9>] }
    scale .3
  scale 4
Date: 20 Jul 2002 09:44:59
Message: <3d39695b@news.povray.org>
> like this :
Sorry, it seems that I've confused you.
There are two groups for posting scene-files on this server:
povray.text.scene-files and povray.binaries.scene-files.
The later is for scene-files in attachments, the other one for copy-pasted
text. So the first time, you did it right, the second time wrong :-)
You can learn all this (and probably more) in
povray.announce.frequently-asked-questions.
Hope, I was clearer now.
Marc-Hendrik
