POV-Ray : Newsgroups : povray.binaries.scene-files : mesh creation macros Server Time
20 Dec 2025 01:46:43 EST (-0500)
  mesh creation macros (Message 1 to 10 of 12)
Subject: mesh creation macros
Date: 17 Nov 2001 08:36:51
Message: <Xns915C94A8BA293seed7@povray.org>
Here's some mesh making macros I'd like to have some feedback on. Don't
rely too much on them as they are still changing and some depend on the
buggy POV-Ray 3.5 splines that also may change.
*Changed parametric a bit, for the better / for the worse?
*Add, where possible, endcapping options?
*Make the macros that use splines more general so they can take arrays
with points as input. Then provide macros that turn splines, functions
etc. into point arrays?
*Switches to turn off/on normals, uv_coordinates? Switch to generate
uv_coordinates in the BuildWriteMesh2 macro instead of on the fly like
in parametric? The uv-range then would always go from <0,0> - <1,1>.
*Other?
There are three more macros under construction:
* Ruled surfaces, kind off, uses more than 2 splines and does not
do only linear interpolation. It's finished but very mutch bitten by
the spline bugs, so I'm not shure wether it actually works right.
* Prism2, works like Double Sweep in Amapi3D. Half way there.
* Gordon Surface, probably too ambitious. Should be like Coons though,
but with more splines (adding 'extended' ruled surfaces?).
Ingo
Download 'makemesh.zip' (15 KB)
Subject: Re: mesh creation macros
Date: 17 Nov 2001 09:22:28
Message: <3bf672a4@news.povray.org>
They look so usefull! Thanks. Only msm.inc is missing.
Jonathan.
"ingo" <ing### [at] homenl> ha scritto nel messaggio
news:Xns### [at] povrayorg...
> *Other?
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
Date: 17 Nov 2001 11:13:44
Message: <Xns915CAF4284861seed7@povray.org>
No, msm.pov should not have been in there :(
Ingo
Date: 26 Nov 2001 10:05:38
Message: <opj40u8js0ku3s01riap7b9d0v1d71v0kp@4ax.com>
I played with similiar system like this set of macros. It is supposed to be
standard inlude files for POV 3.5 ?
Here are my propositions:
1. Coons
  Change header of Coons macro to:
  #macro Coons(
    Spl1, Min1, Max1,
    Spl2, Min2, Max2,
    Spl3, Min3, Max3,
    Spl4, Min4, Max4,
    Iter_U, Iter_V, FileName)
  and change calculation of P0 to
  #local P0=LInterpolate(
    I,
    <0,0,0>+Spl1(LInterpolate(J,Min1,Max1)),
    <0,0,0>+Spl3(LInterpolate(Jm,Min3,Max3))
  LInterpolate(
    Jm,
    <0,0,0>+Spl2(LInterpolate(I,Min2,Max2)),
    <0,0,0>+Spl4(LInterpolate(Im,Min4,Max4))
  )-C0;
  this way you achive possibility of use smaller number of splines
  old syntax
  #macro Coons_Simple(Spl1, Spl2, Spl3, Spl4, Iter_U, Iter_V, FileName)
      Coons(Spl1,0,1,Spl2,0,1,Spl3,0,1,Spl4,0,1, Iter_U, Iter_V, FileName)
  new possibilities
  #macro Closed_Surface(Spl, Iter_U, Iter_V, FileName)
    Coons(Spl,0,.25,Spl,.25,.5,Spl,.5,.75,Spl,.75,1,Iter_U,Iter_V,FileName)
  This way you can simplier control inner behaviour of surface becouse you can
  play with it on grid of splines by evaluating subsets.
2. Makemesh
Macros from Makemesh.inc are IMO designed to be more general than only for other
zipped macros they should allow meshes with no normals and no uvvectors. It
could be for example done this way:
//necessary declarations
#declare Empty_List=array[1];
#macro Make_List(Array) array[1]{Array} #end
// sample usage
BuildWriteMesh2(VecArr, Make_List(NormArr), Empty_List, U, V, FileName)
// changed begining of macros
#macro BuildWriteMesh2(VecArr, NormArr, UVArr, U, V, FileName)
  #local Normals_Defined=(defined(NormArr[0])?yes:no);
  #local UV_Defined=(defined(UVArr[0])?yes:no);
  // rest of macro with reference to normals and uv extended with [0]
Also if it is designed as standard include file I think it shuld be better to
refer to standard Interpolate macro or function adjust_range from math.inc.
yes.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 27 Nov 2001 09:19:44
Message: <02870u0f29o4uancolobb0ucvv8fp0eam7@4ax.com>
I forgot about lathe proposition.
There could be yes/no switch to rotate on/off spline during rotation around y
axis. Somethin like (corosssection):
and
ABX
Date: 28 Nov 2001 07:04:54
Message: <a2k90u0l561avfr1dh5tiunmdbcqod6qak@4ax.com>
Another things.
1. Clipping
It could be interesting when the macros could support clipping_object.
I know - clipped_by could be added to mesh2 but with clipping on the calculation
level you can eliminate triangles outside clipping object. It could save memory
a lot.
2. Output
At this level your macros return file or memory allocation of mesh. It could be
interesting if they could return data structures: arrays with vertices, normals,
uv-vectors and triangles (they are produced temporary). It could be useful for
further ....
3. Manipulation
It could be interesting when two meshes could be joined and produce large arrays
and/or connect similiar vertices and/or smooth normals on the border. Don't
forget about PCM posiibilities.
Do you read my propositions ?
ABX
Date: 28 Nov 2001 07:11:32
Message: <Xns91678633F7EABseed7@povray.org>
Skiba wrote:
> It is supposed to be standard inlude files for POV 3.5 ?
No
> 1. Coons
>  #macro Coons(
>    Spl1, Min1, Max1,
>    Spl2, Min2, Max2,
>    Spl3, Min3, Max3,
>    Spl4, Min4, Max4,
If, then I think it should be part of a method that allows a more
general input than just splines.
> 2. Makemesh
> only for other zipped macros they should allow meshes with no
Yes.
Ingo
Date: 28 Nov 2001 07:12:35
Message: <Xns91678661A9E9Fseed7@povray.org>
> rotation around y axis.
Nice. Also thought about adding a 'twist' option to the prism.
Ingo
Date: 28 Nov 2001 07:18:04
Message: <Xns9167874F6C315seed7@povray.org>
Skiba wrote:
> 1. Clipping
Don't know, I'll think about it.
> 2. Output
Yes, it's one of the things I'm working on.
 > 3. Manipulation
> large arrays and/or connect similiar vertices and/or smooth normals
> on the border. Don't forget about PCM posiibilities.
Yes, had lost my connection for a few days :(
Ingo
Date: 28 Nov 2001 07:28:23
Message: <11m90u0bdqeo9u3airdias53s9rdsg4u2l@4ax.com>
On 28 Nov 2001 07:18:04 -0500, ingo <ing### [at] homenl> wrote:
> > 2. Output
Look at the attached file.
ABX
Download 'structs.inc.txt' (11 KB)
