POV-Ray : Newsgroups : povray.binaries.scene-files : Earth Globe Server Time
15 May 2026 13:12:52 EDT (-0400)
  Earth Globe (Message 1 to 4 of 4)
Subject: Earth Globe
Date: 9 May 2017 04:39:56
Message: <5911805c$1@news.povray.org>
Attached is a Pov file for the Earth using a specular map.
The image maps are to be found on the Blue Marble site. They are large.
https://visibleearth.nasa.gov/view_cat.php?categoryID=1484
If you can't find any particular map from the names. Let me know and I
will upload it.
The scene was created in Bishop3D so you might get a few warnings.
Regards
Download 'earth globe.zip' (2 KB)
Subject: Re: Earth Globe
Date: 9 May 2017 05:01:39
Message: <59118573$1@news.povray.org>
> will upload it
Oh! I changed some jpeg files to png.
Regards
Date: 9 May 2017 05:39:07
Message: <59118e3b$1@news.povray.org>
Am 2017-05-09 04:39, also sprach Stephen:
Awesome! Thanks.
Do you find any overall speed improvement using Render_Block_Size=8?  Or
is it just more fun to watch it render? ;)
Interesting it is a 10,000 frame animation, yet the source doesn't use
"clock" anywhere, so every frame is identical. :)
dik
Date: 9 May 2017 06:10:11
Message: <59119583$1@news.povray.org>
> Awesome! Thanks.
Yes a bit. Especially with media and lots of reflections.
But the real reason is for that last block that takes hours to render
and there are cores lying idle. It annoys the bejasus out of me. :)
At least this way I can have 12 threads working on it.
That's how the modellers, I've used, work to create an animation. They
output one scene file for every frame and use the
Subset_Start_Frame/End, ini commands to control it.
I generally write the animation code myself. After setting the scene up
in Bishop3D. I prefer to use frame_number rather than clock. Clock is so
analogue ;) You know where you are with frames.
Regards
