POV-Ray : Newsgroups : povray.binaries.scene-files : Graphical projection comparison Server Time
26 Jul 2026 10:43:30 EDT (-0400)
  Graphical projection comparison (Message 1 to 10 of 15)
Subject: Graphical projection comparison
Date: 4 May 2017 07:51:58
Message: <590b15de@news.povray.org>
I created four new scenes comparing different types of graphical
projection. You can see the results here:
https://commons.wikimedia.org/wiki/File:Various_projections_of_cube_above_plane.svg
What I did was this:
1. model the scenes in POV-Ray
2. using "screen.inc" export the important points to a text file
3. import the points into GeoGebra
4. connect in GeoGebra the points using segments and polygons
5. export to SVG
This was the easiest way I could think of for creating SVG files using
perspective projection.
Mike
Download 'wp_graphical_projection_examples_20170504.zip' (160 KB)
Subject: Re: Graphical projection comparison
Date: 4 May 2017 08:45:01
Message: <web.590b21eb3e0a9077c437ac910@news.povray.org>
> 5. export to SVG
eek.
I think that some of us have worked out a few rudimentary tools for making SVG
files that mimic some basic lines and shapes.
If and when I have the time and motivation, I could probably pair that with what
I've learned - and haven't forgotten - from the whole view frustum project, and
then use trace() to get screen coordinates.
Maybe a little macro could be worked out that - given the constants for defining
the image plane, the camera, and the viewing vector, would project a set of
given points onto that plane...
"... fastest way, using what I had, and what I already knew"
Yep - I often have to do that as an expedient, just to _get it done._
Nice little project though.  :)
> Mike
Date: 4 May 2017 11:25:36
Message: <590b47f0$1@news.povray.org>
>> 5. export to SVG
> eek.
>> Mike
I forgot that in my version of "screen.inc" I added a macro called
"Get_Screen_XY" that takes any 3D scene coordinate as input and outputs
the 2D screen coordinate, normalized between 0 and 1. This makes things
super simple! I just list whatever points I want to project, and then
write the 2D locations to a text file.
I've attached "screen.inc" to this post.
Mike
Download 'utf-8' (8 KB)
Date: 4 May 2017 11:29:12
Message: <590b48c8$1@news.povray.org>
I used a similar strategy when creating this image:
https://commons.wikimedia.org/wiki/File:Graphical_projection_comparison.png
The main image was rendered in POV-Ray. I then converted the important
coordinates from 3D to 2D, and built the arrows and text on top using
GeoGebra.
Mike
Date: 4 May 2017 11:37:35
Message: <590b4abf$1@news.povray.org>
The instructions say:
> You can only use screen.inc with the perspective camera.
Note that this is no longer the case. I added a macro called
"Set_Camera_Orthographic" that allows you to use a parallel camera as
well. I will need to update the text to reflect this.
Mike
Date: 4 May 2017 12:10:01
Message: <web.590b519f3e0a9077883fb31c0@news.povray.org>
> "Get_Screen_XY" ...
Yeah, I was perplexed as to how the 'vanilla' version of screen.inc could do
that.
This looks interesting. Thanks for posting your modified version.
Date: 4 May 2017 12:45:01
Message: <web.590b5a753e0a9077c437ac910@news.povray.org>
> super simple!
Hmmm.  I recall that Screen.inc uses a -0.5 to +0.5 range.
Might you want to edit "Get_Screen_XY" to output THAT range, so that it would be
easy to align things on the screen with objects in the image,
and then rename the "Get_Screen_XY" to "Get_Image_XY" - since that might
disambiguate things a bit?
I suppose if you're ambitious enough - you could flip those macros around and
given a distance from the camera-right-up plane, you could return x,y,z
coordinates to place an object into the scene, so that it would line up with a
place on the screen or in the image.
Since the SVG is just a text file, and you can clearly follow the syntax - why
not just write the SVG header, output an SVG line definition, and add some
triangles or whatnot, and get your usable SVG straight from POV-Ray?
It would cut out a lot from the workflow.
Just a suggestion.
Thank you :)
One thing that might be useful is to include some reminders and usage info for
output to the debug stream.
I often
#declare Verbose = true;
in my scene, and then any macros or parts of the scene where I want to get data
from check for that variable and then I get everything I want with just one
"switch".
I do the same thing with any weird command syntax that I use - I just output or
include in the comments a working line of code using that command.
Date: 4 May 2017 13:18:19
Message: <590b625b$1@news.povray.org>
>> super simple!
I just checked the code again and realized the output is not normalized
to between 0 and 1. Instead, it outputs a fraction of whatever
image_width and image_height are. Switching back to -0.5 to +0.5 should
be easy.
I can't really remember the details of how the code works. It's been so
long since I looked at this code. If you want to take a crack at it, go
ahead.
> Just a suggestion.
I would have to rewrite this code for every scene I create. What if I
want to change the colors? What if I want to add some text? Angle or
distance measurements? Buttons and check boxes? This all means extra
work compared to GeoGebra, which is WYSIWYG.
> Thank you :)
> I often
> "switch".
I don't think I modified the debug text from the original. This is all I
could find:
	#ifdef(View_POV_Include_Stack)	#debug "including screen.inc\n"		#end
Mike
Date: 4 May 2017 13:26:32
Message: <590b6448$1@news.povray.org>
I checked the code once again, an it may be already possible to do this
by adjusting the "Scaling" parameter of the "Screen_Object" and
"Screen_Plane" macros. I might be wrong though.
Mike
Date: 4 May 2017 15:32:40
Message: <590b81d8@news.povray.org>
Update in the attachment.
Mike
Download 'wp_graphical_projection_examples_20170505.zip' (313 KB)
