POV-Ray : Newsgroups : povray.binaries.scene-files : Sky simulation Server Time
24 Apr 2024 11:19:58 EDT (-0400)
  Sky simulation (Message 29 to 38 of 38)
Subject: Re: Sky simulation
Date: 8 Mar 2018 08:26:33
Message: <5aa13a09@news.povray.org>
On 08/03/2018 12:23, Thomas de Groot wrote:
> On 8-3-2018 10:34, Stephen wrote:
>>> Easy peasy indeed. I imagine the guys calibrating those data sheets:
>> More likely Pop. The materials used are designed to take the weight
>> and are over rated.
> Sad. I would like a bit of drama ;-)
Your slightest wish is my command.
https://youtu.be/CjzykTQM-4w?t=78
A similar incident happened on the platform I was on. Unfortunately the
crane driver was not so lucky. He got trapped in the cabin for hours and
lost a foot and part of his lower leg.
>>> I am always surprised that we got to the Moon at all, or Mars for
>>> that matter, where we were able to crash at least once because of
>>> imperial/metrics confusion... ;-)
>> Big mistake mixing units. I may think in imperial but work in metric
>> when I can.
> smart. But then you grew up with imperial of course. I find it difficult
> (not that I need it).
It is difficult and took years of repetition before it became second
nature. But after learning things like there are 5280 ft in a mile and
60 mph is 88 ft/s. Not to mention the currency. The metric system is a
walk in the park.
Also we oldies can add up in our head. Unlike the youth of today.
Regards
Date: 8 Mar 2018 08:38:18
Message: <5aa13cca$1@news.povray.org>
I just noticed a follow up video.
The cage the guys are in is galled a Billy Pugh and you are supposed to
stand on the outside so you don't get trapped if it goes into the sea. I
used them for my one trip on the Piper. A white knuckle job.
https://www.youtube.com/watch?v=ZD8y7Slx2ow
Regards
Date: 8 Mar 2018 09:13:37
Message: <5aa14511@news.povray.org>
On 07/03/2018 23:29, Mike Horvath wrote:
> On 3/7/2018 7:21 AM, Stephen wrote:
>> Now, I would be surprised if people in the UK did not know that. I
>> guess I was about 15 or 16 when I was taught it at school.
>> But as a rule of thumb that an inch is about the length of your
>> thumb's distal phalanx. Is good enough for children as they more
>> resemble the size of an adult of bygone years.
>> BTW has anyone heard or seen a ruler where feet are divided into tenths?
>> Giving the impression that there are 10 "X inches" to a foot.
>> I saw one once about 30 years ago.
> I have a triangular drafting ruler that is like that.
Hmm I got a set of drafting scale rulers, somewhere in storage. I must
have a look at them. I think the one I saw was a folding yardstick. My
great uncle gave them to me when I was at school.
Regards
Date: 8 Mar 2018 15:21:06
Message: <5aa19b32$1@news.povray.org>
> On 7-3-2018 22:44, Stephen wrote:
>>>> tenths?
>>> Not feet into tenth, but with inches divided into 1/5, 1/10, 1/3,
>>> 1/6, 1/9 and 1/12.
>>> I've seen one with foot divided into 1/3 and 1/4.
>> I think it might be industry specific rule.
>> About 30 years ago. My boss, offshore, took some measurements in the
>> toolpusher's office using a rule he found there. After getting
>> whatever it was made. It did not fit. He got a bit of a slagging for
>> it. As you would. ;-)
>> He went back up to check only to find that there was 10 "inches" to
>> the foot.
>> Drillers use some strange terms. The anchor chain tension is measured
>> in Kilo-pound-inches. I had never heard of that measurement before I
>> had to calibrate the load sensors.
> Interesting story. "kilo-pound-inches", could that mean 'thousand pounds
> per inch'? the word kilo being used for the thousand's value?
Very reasonable assumption. Values in pound per inches would require
uselessly large values with some not very significant trailing zeros.
Date: 9 Mar 2018 02:53:34
Message: <5aa23d7e$1@news.povray.org>
Wow... that is nasty. I guess the operator got a well-earned spanking.
I suppose that with high seas this can happen very easily all by itself...
Date: 9 Mar 2018 03:02:32
Message: <5aa23f98$1@news.povray.org>
>>> and are over rated.
Yes... I was joking but I am very aware of the dangers. At the Survey
one day, we got a sampler stuck at the base of a borehole. The tension
on the hoisting cable gradually increased until you saw it vibrate like
a violin string. We rapidly backed away from the site as you can imagine.
>>> when I can.
>> difficult (not that I need it).
> walk in the park.
Yes indeed. I struggled with the currency... In the bar, it got easier
with the hour. :-]
Yep :-)
Date: 10 Mar 2018 20:48:47
Message: <5aa48aff$1@news.povray.org>
On 3/6/2018 9:48 PM, Alain wrote:
>> Quick question:
>> How do I convert the units of ExposureFactor to my scene?
>> In my scene, 20 units = 1 foot.
>> Thanks!!
>> Mike
> The formula use meter, a meter = about 39 inches, or 3 feet and 3 inches
> (3.25 feet in 1 m).
> There are 10.5625 square feet in a square meter.
I still don't know what the effect on the value of ExposureFactor should be.
//  ExposureFactor A conversion factor between the luminance of the
//                 sky calculated (in cd/m2) to POV values. As the sky
//                 luminance can be very high (around 10000 cd/m2)
//                 then an ExposureFactor around 1e-5 will be needed to
//                 get a correct exposure when looking at the sky
Mike
Date: 10 Mar 2018 20:53:22
Message: <5aa48c12$1@news.povray.org>
Should this macro use srgb in its pigments or rgb?
Mike
Date: 11 Mar 2018 18:06:37
Message: <5aa5a86d@news.povray.org>
>>> Quick question:
>>> Thanks!!
>>> Mike
>> inches (3.25 feet in 1 m).
> be.
> Mike
Just start with 1/100000.
If it's to bright, use a lower value. If it's to dark, use a higher value.
Repeat until you get a pleasing result.
Date: 11 Mar 2018 18:10:22
Message: <5aa5a94e$1@news.povray.org>
> Mike
It looks like it's based on lightsys. That mean that you should use rgb.
Rule of thumb : If the colour is from some colour picker or a paint
application, use srgb. If it's from a formula calculated within the SDL,
use rgb unless the documentation for that code tells you to use srgb.
