POV-Ray : Newsgroups : povray.binaries.scene-files : New version screen.inc Server Time: 16 Nov 2018 09:24:17 GMT
  New version screen.inc (Message 1 to 10 of 52)
Subject: New version screen.inc
Date: 13 Nov 2009 03:07:54
Message: <4afccd8a$1@news.povray.org>
I modified screen.inc so that it works with orthographic cameras as
well. Simply add "yes" or "no" as a new parameter when calling the
"Set_Camera" macro.
There are some glitches, however. In the demo scene, setting the
"scaling" parameter to low values (i.e. below 1) causes artifacts when
orthographic mode is turned on. Also, while the crosshairs are visible,
the pigment/texture looks a lot different than when using a
non-orthographic camera.
Anyone have any idea how to fix these?
Thanks.
Mike
Subject: Re: New version screen.inc
Date: 13 Nov 2009 03:08:58
Message: <4afccdca$1@news.povray.org>
> "Set_Camera" macro.
> Thanks.
> Mike
Forgot to attach the file.
Mike
Download 'screen.inc.txt' (6 KB)
Date: 13 Nov 2009 04:53:11
Message: <4afce637$1@news.povray.org>
> Mike
Slightly tweaked version. Also, the demo scene which I forgot to add
earlier.
Mike
Download 'screen.pov.txt' (6 KB)
Date: 16 Nov 2009 03:10:46
Message: <4b00c2b6$1@news.povray.org>
Update:
Includes the changes I made in my last post to enable the script to work
with orthographic cameras. Also includes a new macro called
"Get_Screen_XY" to return the 2D screen location of a set of 3D coordinates.
The lighting/material issues WRT the crosshairs and orthographic cameras
remains unresolved.
Mike
Download 'screen.pov.txt' (7 KB)
Date: 16 Nov 2009 14:12:01
Message: <4b015db1$1@news.povray.org>
"SharkD" <mik### [at] gmailcom> wrote in message
news:4b00c2b6$1@news.povray.org...
> Update:
> coordinates.
> remains unresolved.
> Mike
Very cool, indeed... looking forward to trying it out. :D Thanks for the
work.
Date: 16 Nov 2009 21:22:03
Message: <4b01c27b$1@news.povray.org>
> work.
I know of one bug already. I've already fixed it and will upload it
soon. Let me know if you notice any others.
Mike
Date: 16 Nov 2009 21:31:49
Message: <4b01c4c5$1@news.povray.org>
news:4b01c27b$1@news.povray.org...
>> work.
> I know of one bug already. I've already fixed it and will upload it soon.
> Mike
I'm setting up an animation now... my goal is to create a text file that
lists, for each frame, the pixel position of an object I'm tracking in the
scene. I'll try to get it  tested by tomorrow.
Jack
Date: 17 Nov 2009 12:53:30
Message: <4b029cca$1@news.povray.org>
OK, here's the latest version. I added support for specifying the camera
direction, right and up vectors directly. Use the macro "Set_Camera_Alt"
instead of "Set_Camera" if you want this. Please report any bugs you may
encounter. I tested versus a series of scenes including ones with
perspective projection, orthographic projection and even oblique
projection. I also tested different aspect ratios and output sizes. I
may have missed something however.
Mike
Download 'screen.inc.txt' (8 KB)
Date: 17 Nov 2009 13:28:52
Message: <4b02a514$1@news.povray.org>
> Mike
Ooops. had some values reversed.
Mike
Date: 17 Nov 2009 19:40:46
Message: <4b02fc3e@news.povray.org>
news:4b02a514$1@news.povray.org...
> Mike
I'm rendering an animation now where I'm tracking part of the object using
the Get_Screen_XY function to build a file of screen coordinates. Once I get
that run, I'll try importing the data into another program and comping the
results. So far, it seems to be working fine and I haven't gotten any
errors; looks great, Mike.
Jack
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
