POV-Ray : Newsgroups : povray.binaries.scene-files : MyMaglev animation sequence generator Server Time
26 Mar 2026 22:30:44 EDT (-0400)
  MyMaglev animation sequence generator (Message 1 to 4 of 4)
Subject: MyMaglev animation sequence generator
Date: 2 Jul 2009 20:15:42
Message: <4a4d4dae@news.povray.org>
The C++ source code attached here generates animations sequences of
camera rides along maglev tracks, which in turn are generated according
to small ASCII scripts describing connected rail segments. These track
definition scripts (TDSs) are defined as follows:
<Type>,<length|bend angle>,<non-relevant|bend radius>, <CR>
"Type" can take on the values of either 0 (straight rail segment) or 1
(bent segment). If "Type" is 0, then the second value is interpreted as
length in POV units (1 POV unit equals 1 metre), otherwise it is
interpreted as the angle of the bend, given in degrees. Positive values
describe right turns, negative ones describe left turns.
If "Type" is 0, then the third value is not interpreted at all;
otherwise it is interpreted as radius in POV units.
Every line is followed by \n (carriage return), but after the last value
of the last line no comma follows.
Type is an integer, length/angle and radius are float variables.
A typical TDS:
0,8,0,
1,-80,10,
1,179,7,
1,31,7,
1,-30,8,
0,12,0
The third and fourth line show a special restriction: as bends are
constructed as CSG difference objects from full-circle lathes, any bend
greater than 180 degrees must be split up in two segments each shorter
than 180 degrees, otherwise the segment will be rendered interrupted by
gaps!
The C++ routine, called makemm ("make MyMaglev") is started from the
Linux or Windows console (I compiled it only for 64-bit Linux) with
seven parameters:
makemm <start_x> <start_y> <start_z> <direction> <speed> <frames per
second> <camera height above track>
Example:
makemm 0 0 0 80 5 25 0.2
will generate a track which first segment starts centered at <start_x,
start_y, start_z>, and is oriented into a direction of 80 degrees  (0
being in positive direction along the z axis, 90 in positive direction
along the x axis and so on), the camera moves at 5 metres/second using
25 frames per second, at 0.2 POV units above the track.
You will be asked for the name of the TDS file and an output file, then
the camera animation sequence is written.
After that, you append this to the existing scene "header":
// cabinrailway.pov
// Maglev commuter train and Personal Rail Cabin system, 60-cm gauge
// (c) 2009 by J�rg 'Yadgar' Bleimann (yaz### [at] gmxde)
// Thanks to:
// Martin (don### [at] onocom) for fixing the segment connection routine
// VARIABLES
#declare ani=1;  // animation flag
// TEXTURES
#declare T_Bright_Metal =
texture
   pigment
     color rgb 0.85
   finish
     ambient 0.15
     diffuse 1
     brilliance 0.3
     phong 0.9
     phong_size 110
#declare T_Simple_Green =
   texture
     pigment
       color rgb <0, 0.7, 0>
     finish
       ambient 0.15
       diffuse 1
       brilliance 0.2
// OBJECTS
#macro StraightRail(le) // le: length in metres
   #local StraightOuterRounding =
   cylinder
     <0.005, 0.495, 0>, <0.005, 0.495, 4>, 0.005
   union
     prism
       linear_sweep
       linear_spline
       0, -le, 21
       <0, 0>, <0, 0.495>, <0.005, 0.495>, <0.005, 0.5>,
       <0.21, 0.5>, <0.225, 0.485>, <0.225, 0.315>, <0.21, 0.3>,
       <0.1, 0.3>, <0.1, 0.15>, <0.5, 0.15>, <0.5, 0.3>, <0.39, 0.3>,
       <0.375, 0.315>, <0.375, 0.485>, <0.39, 0.5>, <0.595, 0.5>,
       <0.595, 0.495>, <0.6, 0.495>, <0.6, 0>, <0, 0>
       rotate -x*90
     object { StraightOuterRounding }
     object { StraightOuterRounding translate x*0.59 }
     texture { T_Bright_Metal }
     translate <-0.3, -0.45, 0>
#macro Straight_GroundCutout(le) // le: length in metres
   box
     <0, 0, -0.0001>, <0.6, 0.451, le+0.0001>
     translate -x*0.3
#macro BendRail(rd, ang) // rd: bend central radius; ang: circle section
angle (positive: right, negative: left);
   #local FullCircle =
   lathe
     linear_spline
     21
     <rd-0.3, 0>, <rd-0.3, 0.495>, <rd-0.295, 0.495>, <rd-0.295, 0.5>,
     <rd-0.09, 0.5>, <rd-0.075, 0.485>, <rd-0.075, 0.315>, <rd-0.09, 0.3>,
     <rd-0.2, 0.3>, <rd-0.2, 0.15>, <rd+0.2, 0.15>, <rd+0.2, 0.3>,
<rd+0.09, 0.3>,
     <rd+0.075, 0.315>, <rd+0.075, 0.485>, <rd+0.09, 0.5>, <rd+0.295, 0.5>,
     <rd+0.295, 0.495>, <rd+0.3, 0.495>, <rd+0.3, 0>, <rd-0.3, 0>
   #local Bend_Subtraction_Block =
   box
     <-(rd+0.31), -1, 0>, <rd+0.31, 1, rd+0.31>
   #local BendOuterRounding =
   torus
     rd+0.295, 0.005
   #local BendInnerRounding =
   torus
     rd-0.295, 0.005
   difference
     object { BendOuterRounding }
     object
       rotate y*ang
     object { Bend_Subtraction_Block rotate y*180 }
   difference
     object { BendInnerRounding }
     object
       rotate y*ang
   union
     difference
       object { FullCircle }
       object
         rotate y*ang
     object { BendOuterRounding translate y*0.495 }
     object { BendInnerRounding translate y*0.495 }
     #if (ang >= 0)
       translate x*rd
     #else
       translate -x*rd
     translate -y*0.45
#macro Bend_GroundCutout (rd, ang) // rd: bend central radius; ang:
circle section angle (positive: right, negative: left);
   #local FullCircle =
   difference
     cylinder
       0, <0, 0.451, 0>, rd+0.3
     cylinder
       <0, -0.001, 0>, <0, 0.452, 0>, rd-0.3
   box
   difference
     object
       rotate y*(ang+0.0001)
     #if (ang >= 0)
       translate x*rd
     #else
       translate -x*rd
// ACTUAL SCENE
sky_sphere
   pigment
     gradient y
     color_map
       [0 rgb 1 ]
       [0.3 rgb 0.5 ]
light_source
   <0, 1000, -2000>
   color rgb 1
// INSERTION GENERATED WITH MAKEMM
// INSERTION BEGIN
#declare RailElements = array[6][3];
#declare i=0;
#declare ty =0;
#declare s = 0;
#declare r = 0;
#fopen RailData "railtest4.txt" read
   #while (defined(RailData))
     #read (RailData,ty,s, r)
     #declare RailElements[i][0] = ty;
     #declare RailElements[i][1] = s;
     #declare RailElements[i][2] = r;
     #declare i=i+1;
#fclose RailData
#declare trans_general = <0, 0, 0>;
#declare d_general = 0;
#declare i = 0; // loop counter
#declare trans = trans_general; // position of first rail segment
(center of front side)
#declare d = d_general; // orientation (degrees) of first rail segment
#while (i < 6)
   #switch (RailElements[i][0])
     #case (0)
       object
         StraightRail(RailElements[i][1])
         rotate y*d
         translate trans
         #declare trans = trans+vrotate(<0, 0, RailElements[i][1]>,<0,
d, 0>);
     #break
     #case (1)
       object
         BendRail(RailElements[i][2], RailElements[i][1])
         rotate y*d
         translate trans
         // begin of Martin's code
         #declare dir= select(RailElements[i][1],1,-1,-1);
         #declare pt= vrotate(x*(RailElements[i][2])*dir,
RailElements[i][1]*y)-x*RailElements[i][2]*dir;
         #declare trans= trans+vrotate(pt,y*d);
         // end of Martin's code
         #declare d = d+RailElements[i][1];
     #break
   #declare i=i+1;
#declare i=0;
#declare trans=trans_general; // position of first ground cutout segment
#declare d=d_general; // orientation (degrees) of first ground cutout
segment
#declare Ground_Cutout =
union
   #while (i<6)
       #case (0)
         object
           Straight_GroundCutout(RailElements[i][1])
           rotate y*d
           translate trans
d, 0>);
       #break
       #case (1)
         object
           Bend_GroundCutout(RailElements[i][2], RailElements[i][1])
           rotate y*d
           translate trans
       #break
     #declare i=i+1;
difference
   plane
     y, 0
     texture { T_Simple_Green }
   object { Ground_Cutout translate -y*0.45 }
#declare speed = 5; // metres/second
#declare fps = 25; // animation frames per second
#if (ani)
   camera
     #switch (clock)
       #range(0, 40) // track segment #1: 8 metres straight; total
length = 8
         #declare loc = < 0, 0.2, 0 > + < 0, 0, 0> + < 0* (clock-0), 0,
0.2 * (clock-0)>;
         #declare ldir = vrotate(<0, 0, 1>, y*0);
         location loc
         look_at loc+ldir
       #break
       #range(41, 110) // track segment #2: 80 degrees left turn; total
length = 21.9626
         #declare loc = < 0, 0.2, 8 > + < -10, 0, 1.94115e-06 > + 10 *
<sin(radians(0+90-0.214101-( 1.14592 * ( clock-41)))), 0,
cos(radians(0+90-0.214101-( 1.14592 * ( clock-41))))>;
y*(0-0.214101-(1.14592*(clock - 41))));
         location loc
         look_at loc+ldir
       #break
       #range(111, 220) // track segment #3: 179 degrees right turn;
total length = 43.8316
         #declare loc = < -8.26352, 0.2, 17.8481 > + < 1.21554, 0,
6.89365 > + 7 * <sin(radians(-80-90+1.07247+( 1.63702 * ( clock-111)))),
0, cos(radians(-80-90+1.07247+( 1.63702 * ( clock-111))))>;
y*(-80+1.07247+(1.63702*(clock - 111))));
         location loc
         look_at loc+ldir
       #break
       #range(221, 239) // track segment #4: 31 degrees right turn;
total length = 47.619
         #declare loc = < -5.95294, 0.2, 31.6556 > + < -1.09504, 0,
-6.91382 > + 7 * <sin(radians(99-90+0.103427+( 1.63702 * (
clock-221)))), 0, cos(radians(99-90+0.103427+( 1.63702 * ( clock-221))))>;
y*(99+0.103427+(1.63702*(clock - 221))));
         location loc
         look_at loc+ldir
       #break
       #range(240, 260) // track segment #5: 30 degrees left turn; total
length = 51.8078
         #declare loc = < -2.54847, 0.2, 30.104 > + < 5.1423, 0, 6.12836
 > + 8 * <sin(radians(130+90-0.080288-( 1.43239 * ( clock-240)))), 0,
cos(radians(130+90-0.080288-( 1.43239 * ( clock-240))))>;
y*(130-0.080288-(1.43239*(clock - 240))));
         location loc
         look_at loc+ldir
       #break
       #range(261, 321) // track segment #6: 12 metres straight; total
length = 63.8078
         #declare loc = < 1.20465, 0.2, 28.3539 > + < 0, 0, -0> + <
0.196962* (clock-261), 0, -0.0347296 * (clock-261)>;
         #declare ldir = vrotate(<0, 0, 1>, y*100);
         location loc
         look_at loc+ldir
       #break
     angle 40
// end of code
And here the C++ source code:
// makemm version 0.1
// A utility to generate PoV-Ray scripts for animating camera rides
along railroad tracks
// (C) 2009 by Jörg "Yadgar" Bleimann (yaz### [at] gmxde,
http://www.khyberspace.de)
// Thanks to 0xdeadbeef for the implementation of the "explode" function
#include <iostream>
#include <stdlib.h>
#include <cstdlib>
#include <fstream>
#include <string>
#include <vector>
#include <sstream>
#include <stdexcept>
#include <cmath>
using namespace std;
// begin code by 0xdeadbeef
template <typename to, typename from>
to convert(from const &src) {
   stringstream converter;
   to dest;
   converter << src;
   converter >> dest;
   if(!converter) {
     throw invalid_argument("Conversion failed");
   return dest;
vector<string> explode (string const &line, char delim)
   istringstream in(line);
   vector<string> result;
   string token;
   while(getline(in, token, delim))
     result.push_back(token);
   return result;
// end code by 0xdeadbeef
int main(int argc, char* argv[])
   double x, y, z, d, sp;
   unsigned short fps; // animation frames per second
   double loc_y; // camera height above track
   x = atof(argv[1]);
   y = atof(argv[2]);
   z = atof(argv[3]);
   d = atof(argv[4]);
   sp = atof(argv[5]); // provisional version of makemm: constant speed
of camera ride, to be replaced later on by a speed script, see also line 149
   fps = atoi(argv[6]);
   loc_y = atof(argv[7]);
   ifstream track;
   string track_name;
   cout << "Track script? ";
   cin >> track_name;
   track.open(track_name.c_str());
   if (!track)
     cerr << track_name << " cannot be opened!\n";
     exit (-1);
   ofstream anim;
   string anim_name;
   char ch;
   vector<char> buffer;
   unsigned short segments=0;
   while (track.get(ch))
     buffer.push_back(ch);
     if (ch == '\n') segments++;
   track.close();
   cout << "Animation script? ";
   cin >> anim_name;
   anim.open(anim_name.c_str());
   if (!anim)
     cerr << anim_name << " cannot be opened!\n";
     exit (-1);
   anim << "// INSERTION GENERATED WITH MAKEMM" << endl;
   anim << endl;
   anim << "// INSERTION BEGIN" << endl;
   anim << "#declare RailElements = array[" << segments << "][3];" << endl;
   anim << "#declare i=0;" << endl;
   anim << "#declare ty =0;" << endl;
   anim << "#declare s = 0;" << endl;
   anim << "#declare r = 0;" << endl;
   anim << endl;
   anim << "#fopen RailData \"" << track_name << "\" read" << endl;
   anim << "  #while (defined(RailData))" << endl;
   anim << "    #read (RailData,ty,s, r)" << endl;
   anim << "    #declare RailElements[i][0] = ty;" << endl;
   anim << "    #declare RailElements[i][1] = s;" << endl;
   anim << "    #declare RailElements[i][2] = r;" << endl;
   anim << "    #declare i=i+1;" << endl;
   anim << "  #end" << endl;
   anim << "#fclose RailData" << endl;
   anim << endl;
   anim << "#declare trans_general = <" << argv[1] << ", " << argv[2] <<
", " << argv[3] << ">;" << endl;
   anim << "#declare d_general = " << argv[4] << ";" << endl;
   anim << endl;
   anim << "#declare i = 0; // loop counter" << endl;
   anim << "#declare trans = trans_general; // position of first rail
segment (center of front side)" << endl;
   anim << "#declare d = d_general; // orientation (degrees) of first
rail segment" << endl;
   anim << endl;
   anim << "#while (i < " << segments << ")" << endl;
   anim << "  #switch (RailElements[i][0])" << endl;
   anim << "    #case (0)" << endl;
   anim << "      object" << endl;
   anim << "      {" << endl;
   anim << "        StraightRail(RailElements[i][1])" << endl;
   anim << "        rotate y*d" << endl;
   anim << "        translate trans" << endl;
   anim << "        #declare trans = trans+vrotate(<0, 0,
RailElements[i][1]>,<0, d, 0>);" << endl;
   anim << "      }" << endl;
   anim << "    #break" << endl;
   anim << "    #case (1)" << endl;
   anim << "        BendRail(RailElements[i][2], RailElements[i][1])" <<
endl;
   anim << "        // begin of Martin's code" << endl;
   anim << "        #declare dir= select(RailElements[i][1],1,-1,-1);"
<< endl;
   anim << "        #declare pt= vrotate(x*(RailElements[i][2])*dir,
RailElements[i][1]*y)-x*RailElements[i][2]*dir;" << endl;
   anim << "        #declare trans= trans+vrotate(pt,y*d);" << endl;
   anim << "        // end of Martin's code" << endl;
   anim << "        #declare d = d+RailElements[i][1];" << endl;
   anim << "#end" << endl;
   anim << endl;
   anim << "#declare trans=trans_general; // position of first ground
cutout segment (center of front side)" << endl;
   anim << "#declare d=d_general; // orientation (degrees) of first
ground cutout segment" << endl;
   anim << endl;
   anim << "#declare Ground_Cutout =" << endl;
   anim << "union" << endl;
   anim << "{" << endl;
   anim << "  #while (i<" << segments << ")" << endl;
   anim << "          Straight_GroundCutout(RailElements[i][1])" << endl;
   anim << "          Bend_GroundCutout(RailElements[i][2],
<< endl;
   anim << "}" << endl;
   anim << endl;
   anim << "difference" << endl;
   anim << "  plane" << endl;
   anim << "    y, 0" << endl;
   anim << "    texture { T_Simple_Green }" << endl;
   anim << "  object { Ground_Cutout translate -y*0.45 }" << endl;
   anim << endl;
   // provisional version of makemm: constant speed of camera ride, to
   anim << "#declare speed = " << sp << "; // metres/second" << endl;
   anim << "#declare fps = " << fps << "; // animation frames per
second" << endl;
   anim << endl;
   anim << "#if (ani)" << endl;
   anim << "  camera" << endl;
   anim << "    #switch (clock)" << endl;
   unsigned short i = 0; // counter for track segments in animation
sequences loop
   unsigned long j = 0; // counter for vector elements in "buffer"
   unsigned long start_s = 0; // frame number at beginning of each
animation sequence
   unsigned long end_s = 100; // frame number at end of each animation
sequence, provisionally initialized with a dummy value
   start_s = 0; //
   end_s = 0;
   i = 0; // track segment counter
   double length; // segment's length in metres
   double total_length = 0; // cumulated length of track segments
   bool t; // segment type: false = straight, true = curved
   double arc;    // curved segment's arc size in degrees
   double radius; // curved segment's radius width in metres
   double compart; // either length or arc size
   string comment; // adds information about each track segment
   string type;   // segment's type (to be printed into comment for each
#range section)
   string direction; // curved segment's direction (left or right)
   string line(""); // stores current track script line
   vector<string> numbers; // stores numerals extracted from line as string
   double step = sp/fps; // movement per frame in metres
   double remain; // remaining track length of each segment after at
last frame
   double offset; // track length allready travelled at fist frame of
segment (for all i>1)
   double offset_x; // x component of offset vector
   double offset_z; // z component of offset vector
   const double pi = 3.141592265359;
   double loc_x; // x coordinate of camera position
   double loc_z; // z coordinate of camera position
   double ldir_x = 0; // x component of look_at vector
   const double ldir_y = 0; // y component of look_at vector (fixed)
   double ldir_z = 1; // z component of look_at vector (default pointing
at N = 0 degrees azimuth)
   string lookat; // vrotate transformation for look_at vector
   double start_x; // x coordinate of each segment's starting point
   const double start_y = 0; // y coordinate of each segment's starting
point (fixed)
   double start_z;
   double end_x; // x coordinate of each segment's end point
   const double end_y = y + loc_y; // y coordinate of each segment's end
point (fixed)
   double end_z; // z coordinate of each segment's end point
   double center_x; // x coordinate of center point (curved segments only)
   double center_z; // z coordinate of center point (curved segments only)
   double arcstep;  // distance on curved segment travelled per frame
   string arcsign;  // clockwise vs. anti-clockwise curving
   string arcsign_lookat; // clockwise vs. anti-clockwise curving
   double arcoffset; // length offset converted to arc offset
   double d_old; // orientation of last segment
   double d_end; // orientation at end of current segment;
   while (j < buffer.size())
     line.append(1, buffer.at(j));
     if (buffer.at(j)=='\n')
       i++;
       numbers = explode(line, ',');
       try
         t = convert<bool>(numbers.at(0));
       catch(exception &e)
         cerr << "Error while processing \"" << numbers.at(0) << "\": "
              << e.what() << endl;
       try
         if (!t)
           length = convert<double>(numbers.at(1));
         else
           arc = convert<double>(numbers.at(1));
       catch(exception &e)
         cerr << "Error while processing \"" << numbers.at(1) << "\": "
       try
         if (t)
           radius = convert<double>(numbers.at(2));
       catch(exception &e)
       line = "";
       if (!t)
         compart = length;
         total_length += length;
         comment = " metres straight; total length = ";
         if (i==1)
           d_old = atof(argv[4]);
           start_s = 0;
           loc_x = sin(d_old*(pi/180))*step;
           loc_z = cos(d_old*(pi/180))*step;
           start_x = x;
           start_z = z;
         else
           start_s = end_s + 1;
           loc_x = sin(d_end*(pi/180))*step;
           loc_z = cos(d_end*(pi/180))*step;
           start_x = end_x;
           start_z = end_z;
           d_old = d_end;
         d_end = d_old;
         end_x = start_x + length*sin(d_end*(pi/180));
         end_z = start_z + length*cos(d_end*(pi/180));
         end_s = start_s + length/step;
         anim << "      #range(" << start_s << ", " << end_s << ") //
track segment #" << i << ": " << compart << comment << total_length
    << endl;
         remain = length - (end_s - start_s)*step;
         if (remain > 0)
           offset = step - remain;
         else
           offset = 0;
         offset_x = offset*sin(d_end*(pi/180));
         offset_z = offset*cos(d_end*(pi/180));
         d_old = d;
         anim << "        #declare loc = < " << start_x << ", " << loc_y
<< ", " << start_z << " > + < " << offset_x << ", " << 0 << ", " <<
offset_z << "> + < " << loc_x << "* (clock-" << start_s << "), " << 0 <<
", " << loc_z << " * (clock-" << start_s << ")>;" << endl;
         anim << "        #declare ldir = vrotate(<" << ldir_x << ", "
<< ldir_y << ", " << ldir_z << ">, y*" << d_end << ");" << endl;
       else
         compart = abs(arc);
         length = compart * (pi/180) * radius;
         arcstep = step / (pi * radius) * 180;
         if (i==1)
           start_s = 0;
           start_x = x;
           start_z = z;
         else
           start_x = end_x;
           start_z = end_z;
           d_old = d_end;
         d_end = d_old+arc;
         if (arc > 0)
           direction = "right ";
           center_x = radius * sin((d_old+90)*(pi/180));
           center_z = radius * cos((d_old+90)*(pi/180));
           arcsign = "-";
           arcsign_lookat = "+";
           //arcterm = "-90+arcstep*clock)";
           end_x = start_x + center_x + radius *
sin((d_old-90+arc)*(pi/180));
           end_z = start_z + center_z + radius *
cos((d_old-90+arc)*(pi/180));
           // loc_x = radius * sin((d-90
         else
           direction = "left ";
           center_x = radius * sin((d_old-90)*(pi/180));
           center_z = radius * cos((d_old-90)*(pi/180));
           arcsign = "+";
           arcsign_lookat = "-";
           // arcterm = "+90-arcstep*clock)";
sin((d_old+90+arc)*(pi/180));
cos((d_old+90+arc)*(pi/180));
         if (remain > 0)
         else
           offset = 0;
         arcoffset = offset / (radius * pi) * 180;
         comment = " degrees " + direction;
         comment += "turn; total length = ";
    << endl;
<< ", " << start_z << " > + < " << center_x << ", " << 0 << ", " <<
center_z << " > + " << radius << " * <sin(radians("<< d_old << arcsign
<< "90" << arcsign_lookat << arcoffset << arcsign_lookat << "( " <<
arcstep << " * ( clock-" << start_s << ")))), " << 0 << ",
cos(radians("<< d_old << arcsign << "90" << arcsign_lookat << arcoffset
<< arcsign_lookat << "( " << arcstep << " * ( clock-" << start_s <<
"))))>;" << endl;
<< ldir_y << ", " << ldir_z << ">, y*(" << d_old << arcsign_lookat <<
arcoffset << arcsign_lookat << "(" << arcstep << "*(clock - " << start_s
<< "))));" << endl;
       anim << "        location loc" << endl;
       anim << "        look_at loc+ldir" << endl;
     j++;
    anim << "    angle 40" << endl;
   return 0;
// end of code
Have fun!
See you in Khyberspace!
Yadgar
Subject: Re: MyMaglev animation sequence generator
Date: 3 Jul 2009 05:14:19
Message: <4a4dcbeb$1@news.povray.org>
Want some commentary on your C++ program?
Date: 3 Jul 2009 06:17:51
Message: <4a4ddacf@news.povray.org>
High!
Yes, I thought so...
Yadgar
Date: 3 Jul 2009 06:31:29
Message: <4a4dde01@news.povray.org>
> High!
  I apologize, I don't understand your answer...
