High!
(see also message in p.b.i.)
Here the code:
// cabinrailway.pov
// Maglev commuter train and Personal Rail Cabin system, 60-cm gauge
// (c) 2009 by Jörg 'Yadgar' Bleimann (yazdegird [at] gmx de)
// TEXTURES
#declare T_Bright_Metal =
texture
pigment
color rgb 0.85
finish
ambient 0.15
diffuse 1
brilliance 0.3
phong 0.9
phong_size 110
// OBJECTS
#macro StraightRail(le) // le: length in meters
#local StraightOuterRounding =
cylinder
<0.005, 0.495, 0>, <0.005, 0.495, 4>, 0.005
union
prism
linear_sweep
linear_spline
0, -le, 21
<0, 0>, <0, 0.495>, <0.005, 0.495>, <0.005, 0.5>,
<0.21, 0.5>, <0.225, 0.485>, <0.225, 0.315>, <0.21, 0.3>,
<0.1, 0.3>, <0.1, 0.15>, <0.5, 0.15>, <0.5, 0.3>, <0.39, 0.3>,
<0.375, 0.315>, <0.375, 0.485>, <0.39, 0.5>, <0.595, 0.5>,
<0.595, 0.495>, <0.6, 0.495>, <0.6, 0>, <0, 0>
rotate -x*90
object { StraightOuterRounding }
object { StraightOuterRounding translate x*0.59 }
texture { T_Bright_Metal }
#macro BendRail(rd, ang) // rd: bend central radius; ang: circle section
angle (positive: right, negative: left);
#local FullCircle =
lathe
linear_spline
21
<rd-0.3, 0>, <rd-0.3, 0.495>, <rd-0.295, 0.495>, <rd-0.295, 0.5>,
<rd-0.09, 0.5>, <rd-0.075, 0.485>, <rd-0.075, 0.315>, <rd-0.09, 0.3>,
<rd-0.2, 0.3>, <rd-0.2, 0.15>, <rd+0.2, 0.15>, <rd+0.2, 0.3>,
<rd+0.09, 0.3>,
<rd+0.075, 0.315>, <rd+0.075, 0.485>, <rd+0.09, 0.5>, <rd+0.295, 0.5>,
<rd+0.295, 0.495>, <rd+0.3, 0.495>, <rd+0.3, 0>, <rd-0.3, 0>
#local Bend_Subtraction_Block =
box
<-(rd+0.31), -1, 0>, <rd+0.31, 1, rd+0.31>
#local BendOuterRounding =
torus
rd+0.295, 0.005
#local BendInnerRounding =
torus
rd-0.295, 0.005
difference
object { BendOuterRounding }
object
rotate y*ang
object { Bend_Subtraction_Block rotate y*180 }
difference
object { BendInnerRounding }
object
rotate y*ang
union
difference
object { FullCircle }
object
rotate y*ang
object { BendOuterRounding translate y*0.495 }
object { BendInnerRounding translate y*0.495 }
#if (ang >= 0)
translate x*(rd+0.3)
#else
translate -x*(rd-0.3)
#declare Straight4_Ground_Cutout =
box
<0, -0.45, 0>, <0.6, 0.05, 4.001>
// ACTUAL SCENE
sky_sphere
pigment
gradient y
color_map
[0 rgb 1 ]
[0.3 rgb 0.5 ]
plane
y, 0
texture
pigment
color rgb <0, 0.7, 0>
finish
ambient 0.15
diffuse 1
brilliance 0.2
light_source
<0, 1000, -2000>
color rgb 1
#declare RailElements = array[9][3];
#declare i=0;
#declare ty =0;
#declare s = 0;
#declare r = 0;
#fopen RailData "railtest.txt" read
#while (defined(RailData))
#read (RailData,ty,s, r)
#declare RailElements[i][0] = ty;
#declare RailElements[i][1] = s;
#declare RailElements[i][2] = r;
#declare i=i+1;
#fclose RailData
#declare i=0;
#declare trans=<0, 0, 0>; // position of first rail segment (lower left
front corner)
#declare d=0; // orientation (degrees) of first rail segment
#while (i<9)
#switch (RailElements[i][0])
#case (0)
object
StraightRail(RailElements[i][1])
rotate y*d
translate trans
#declare trans = trans+vrotate(<0, 0, RailElements[i][1]>,<0,
d, 0>);
#warning concat("< ",str(trans.x, 3, 3), ", ", str(trans.y, 3,
3), ", ", str(trans.z, 3, 3), " >")
#break
#case (1)
object
BendRail(RailElements[i][2], RailElements[i][1])
rotate y*d
translate trans
#if (RailElements[i][1] >= 0)
#declare diff = 0.3;
#else
#declare diff = -0.3;
#declare trans = trans +
2*(RailElements[i][2]+diff)*sin(radians(abs(RailElements[i][1])/2))*<sin(radians(abs(RailElements[i][1])/2)),
0, cos(radians(abs(RailElements[i][1])/2))>;
#declare d = d+RailElements[i][1];
#break
#declare i=i+1;
#warning str(d, 3, 3)
camera
// orthographic
location <10, 400, 10>
look_at <10, 0, 10>
angle 40
// end of code
