POV-Ray : Newsgroups : povray.binaries.scene-files : Rail segments assembly problem Server Time
28 Sep 2024 20:13:02 EDT (-0400)
  Rail segments assembly problem (Message 1 to 1 of 1)
Subject: Rail segments assembly problem
Date: 11 Apr 2009 10:23:54
Message: <49e0a7fa$1@news.povray.org>
High!
(see also message in p.b.i.)
Here the code:
// cabinrailway.pov
// Maglev commuter train and Personal Rail Cabin system, 60-cm gauge
// TEXTURES
#declare T_Bright_Metal =
texture
   pigment
     color rgb 0.85
   finish
     ambient 0.15
     diffuse 1
     brilliance 0.3
     phong 0.9
     phong_size 110
// OBJECTS
#macro StraightRail(le) // le: length in meters
   #local StraightOuterRounding =
   cylinder
     <0.005, 0.495, 0>, <0.005, 0.495, 4>, 0.005
   union
     prism
       linear_sweep
       linear_spline
       0, -le, 21
       <0, 0>, <0, 0.495>, <0.005, 0.495>, <0.005, 0.5>,
       <0.21, 0.5>, <0.225, 0.485>, <0.225, 0.315>, <0.21, 0.3>,
       <0.1, 0.3>, <0.1, 0.15>, <0.5, 0.15>, <0.5, 0.3>, <0.39, 0.3>,
       <0.375, 0.315>, <0.375, 0.485>, <0.39, 0.5>, <0.595, 0.5>,
       <0.595, 0.495>, <0.6, 0.495>, <0.6, 0>, <0, 0>
       rotate -x*90
     object { StraightOuterRounding }
     object { StraightOuterRounding translate x*0.59 }
     texture { T_Bright_Metal }
#macro BendRail(rd, ang) // rd: bend central radius; ang: circle section
angle (positive: right, negative: left);
   #local FullCircle =
   lathe
     linear_spline
     21
     <rd-0.3, 0>, <rd-0.3, 0.495>, <rd-0.295, 0.495>, <rd-0.295, 0.5>,
     <rd-0.09, 0.5>, <rd-0.075, 0.485>, <rd-0.075, 0.315>, <rd-0.09, 0.3>,
     <rd-0.2, 0.3>, <rd-0.2, 0.15>, <rd+0.2, 0.15>, <rd+0.2, 0.3>,
<rd+0.09, 0.3>,
     <rd+0.075, 0.315>, <rd+0.075, 0.485>, <rd+0.09, 0.5>, <rd+0.295, 0.5>,
     <rd+0.295, 0.495>, <rd+0.3, 0.495>, <rd+0.3, 0>, <rd-0.3, 0>
   #local Bend_Subtraction_Block =
   box
     <-(rd+0.31), -1, 0>, <rd+0.31, 1, rd+0.31>
   #local BendOuterRounding =
   torus
     rd+0.295, 0.005
   #local BendInnerRounding =
   torus
     rd-0.295, 0.005
   difference
     object { BendOuterRounding }
     object
       rotate y*ang
     object { Bend_Subtraction_Block rotate y*180 }
   difference
     object { BendInnerRounding }
     object
       rotate y*ang
   union
     difference
       object { FullCircle }
       object
         rotate y*ang
     object { BendOuterRounding translate y*0.495 }
     object { BendInnerRounding translate y*0.495 }
     #if (ang >= 0)
       translate x*(rd+0.3)
     #else
       translate -x*(rd-0.3)
#declare Straight4_Ground_Cutout =
box
   <0, -0.45, 0>, <0.6, 0.05, 4.001>
// ACTUAL SCENE
sky_sphere
   pigment
     gradient y
     color_map
       [0 rgb 1 ]
       [0.3 rgb 0.5 ]
plane
   y, 0
   texture
     pigment
       color rgb <0, 0.7, 0>
     finish
       ambient 0.15
       diffuse 1
       brilliance 0.2
light_source
   <0, 1000, -2000>
   color rgb 1
#declare RailElements = array[9][3];
#declare i=0;
#declare ty =0;
#declare s = 0;
#declare r = 0;
#fopen RailData "railtest.txt" read
   #while (defined(RailData))
     #read (RailData,ty,s, r)
     #declare RailElements[i][0] = ty;
     #declare RailElements[i][1] = s;
     #declare RailElements[i][2] = r;
     #declare i=i+1;
#fclose RailData
#declare i=0;
#declare trans=<0, 0, 0>; // position of first rail segment (lower left
front corner)
#declare d=0; // orientation (degrees) of first rail segment
#while (i<9)
   #switch (RailElements[i][0])
     #case (0)
       object
         StraightRail(RailElements[i][1])
         rotate y*d
         translate trans
         #declare trans = trans+vrotate(<0, 0, RailElements[i][1]>,<0,
d, 0>);
         #warning concat("< ",str(trans.x, 3, 3), ", ", str(trans.y, 3,
3), ", ", str(trans.z, 3, 3), " >")
     #break
     #case (1)
       object
         BendRail(RailElements[i][2], RailElements[i][1])
         rotate y*d
         translate trans
         #if (RailElements[i][1] >= 0)
           #declare diff = 0.3;
         #else
           #declare diff = -0.3;
         #declare trans = trans +
2*(RailElements[i][2]+diff)*sin(radians(abs(RailElements[i][1])/2))*<sin(radians(abs(RailElements[i][1])/2)),
0, cos(radians(abs(RailElements[i][1])/2))>;
         #declare d = d+RailElements[i][1];
     #break
   #declare i=i+1;
#warning str(d, 3, 3)
camera
   // orthographic
   location <10, 400, 10>
   look_at <10, 0, 10>
   angle 40
// end of code
