A scale model of the solar system, differing scales for the smaller and
larger planets so they fit together into a single scene. This doesn't have
the image maps included but maybe I could post them later, they came from
various online sources I've forgotten. Easily replaced by ones you might
have already and/or could download. Best to resize to small low resolution
(I used 720X360) for speed of renders, especially during animations.
Things to do: orbits lack actual orientation with regard to stars (no star
background either) or real time, or much else aside from their scaled sizes,
tilts, inclines. So a version 1.1 or 2 is always possible.
This is free to use, modify as you please, without credit due.
/*bob hughes*/
Download 'us-ascii' (49 KB)
Running this scene as an animation again tonight I noticed how I neglected
to put clock in for a quick animation, something like
-ki0 -kf1 -kfi1 -kff100
for cmd: where I had already put a -w640 -h640 +a
For those unaware, you may right-click this line in the POV for Windows
editor to send it to the command line.
I'm accustomed to using the resolutions drop-down list containing my own
items with various animation parameters instead of the command line, so that
was something I meant to say before when posting this. Just make sure you
also put some number with clock in the Years=. Hope that helps.
Decided to put the resized image maps here in solarsystem-maps.zip. Maybe
that's OK... if I understand the terms I found at the web site where I think
most of these might come from, that being not to redistribute the images
unchanged (these are all down-sized).
Look at http://planetpixelemporium.com/planets.html for full-sized planet
image maps. I hadn't intended to zoom the view into planet surfaces but you
might. In fact, asteroid Ceres uses a different Pluto rendition (and Pluto
is Jupiter's moon Ganymede!).
One other thing... my choice of file name was a bad one for animations. The
ver1 ending gets numbers added to it, making it become ver101, ver102,
ver103... ver110 for a ten frame animation. So you should probably use
another output name. I will be sure to change that if I ever post another
version. Mistakes were rampant in that file as I readied it for posting
here, it could have many things wrong still. You've been warned.
Download 'solarsystem-maps.zip' (639 KB)
Not surprisingly, NASA has a lot of image maps as well; best thing: As a
government organization, they make them available for free to everyone and any
use.
They also provide a lot of stuff post-processed "ready for use" these days - and
they have the highest resolution you can get to date.
It may take a few googling attempts though to get to the right places - nasa.gov
is quite a big site :).
"clipka" <nomail@nomail> wrote in message
news:web.496dc9fd6fd6ebf6bdc576310@news.povray.org...
>> you
>> Pluto
> any
> use.
> days - and
> nasa.gov
Been through many a NASA web page, yep. Tried looking there just now and
didn't have much luck finding all I would want to immediately. ;^)
Came across the web page
http://www.carinasoft.com/support/links08.html
of several places to obtain solar system image maps, one such being the
aforementioned, and I immediately recognized the familiar names David Seal,
Bjorn Jonsson, as well as Hastings-Trew's I had told of (simulated Sun map
obviously from there).
Was going through my orrery file again and found numerous errors, mainly
where the Earth atmosphere got thrown in to the mix (scales wrong, metric is
same as Earth surface!). Obviously I couldn't keep order in the chaos while
I made changes. ha ha!
No idea if the whole thing functions as intended, leaving that up to others
to discover for themselves. Guess I should have added a disclaimer about it
not being for scientific purposes.
