High!
After the harddisk crash, I found out, that I made the last backup
BEFORE I started the PoVEarth project... so I had to program the (still
very embryonic) scene once again. After advancing to the balconies (but
not yet to the floor cutouts and balcony doors), I noticed that suddenly
the blue sky_sphere (lines 153 to 165) disappeared, although the scale
flag models[3] was set... and when I commented out the mentioned lines,
also the ground plane (lines 169 to 177) disappeared, even after I added
a new (also conditional) definition of the sky_sphere (lines 190 to
202)! Why? All #if clauses are properly terminated by #end...
Here's the code:
// My Place in the World
// A sub-sub-subsection of the PoVEarth project
// (C) 2008 Jörg 'Yadgar' Bleimann
// E-mail: yazdegird [at] gmx de
// RADIOSITY
#declare radio=1;
global_settings
#if (!radio)
ambient_light 0.15
#else
ambient_light 0
radiosity
brightness 1
adc_bailout 0.01
gray_threshold 0.8
// TIME VARIABLES
// PIGMENTS
#declare P_Concrete =
pigment
color rgb 0.9
// FINISHES
#declare F_Standard =
finish
diffuse 1
brilliance 0.15
// NORMALS
// TEXTURES
#declare T_Concrete =
texture
pigment { P_Concrete }
finish { F_Standard }
// LENGTH VARIABLES
#declare FrKarl_SideStreet_Width = 6.09;
#declare FrKarl_SideStreet_Pavement_Width = 1.32;
#declare GWG_FrKarl_Block_Front_Way_Length = 4.09;
#declare GWG_FrKarl_Block_Front_Doorstep_Depth = 0.427;
#declare GWG_FrKarl_Block_Stair_Height = 0.168;
#declare GWG_FrKarl_Block_Floor_Height = 16 * GWG_FrKarl_Block_Stair_Height;
#declare GWG_FrKarl_Block_Floor_yOffset = 8 * GWG_FrKarl_Block_Stair_Height;
#declare GWG_FrKarl_Block_Ceiling_Thickness = 0.148;
#declare GWG_FrKarl_Block_Balcony_Spacing=9.19;
#declare GWG_FrKarl_Block_Floor_Offset =
// OBJECT DEFINITIONS
#declare GWG_FrKarl_Block_Raw=
box
0, <11.08, 9.523, 53.49>
#declare GWG_FrKarl_Block_Balcony_Raw=
difference
box
0, <1.155, 0.948, 3.24>
box
<0.165, 0.148, 0.155>, <1.65, 0.95, 3.085>
// CAMERA SETTINGS
// using microlocal coordinates
#declare view=1;
#switch(view)
#case (0)
#declare camPos = <-5, 1.7, -10>;
#declare camLook = <5, 7.2, 3>;
#declare camAng = 40;
#break
#case (1)
#declare camPos = <-(FrKarl_SideStreet_Width / 2 +
FrKarl_SideStreet_Pavement_Width + GWG_FrKarl_Block_Front_Way_Length +
GWG_FrKarl_Block_Front_Doorstep_Depth), 1.7, 70>;
#declare camLook =<-(FrKarl_SideStreet_Width / 2 +
GWG_FrKarl_Block_Front_Doorstep_Depth), 1.7, 0>;
#declare camAng = 60;
#break
// ACTUAL SCENE
#declare detail=0;
#if (!detail) // full scene views
// SCALE MODELS
#declare models = array[5] { 0, 0, 0, 1, 0 }
// models[0]: cosmic scale - whole Solar System, heliocentric
// models[1]: global scale - Earth, geocentric, spherical terrain relief
// models[2]: regional scale - 40 x 40 kms area around Cologne,
heightfield
// models[3]: local scale - 500 x 500 metres around my apartment, plane
// models[4]: microlocal - my apartment only, outside world only as
HDRI bitmaps
#declare a=0;
#declare i=0;
#while (a<5)
#if (models[a])
#declare i=i+1;
#declare a=a+1;
#if (!i | i>1)
#warning "Missing or ambiguous scale setting" // terminating POV script
#else
#if (models[0])
#declare f=1000000 // 1 unit = 1000 kms
#if (models[1])
#declare f=1000; // 1 unit = 1 km
#if (models[2] | models[3] | models[4])
#declare f=1; // 1 unit = 1 metre
#if (models[3])
#declare trans=<251.565, 0, 250.325>;
/* #if (models[3])
sky_sphere
pigment
gradient y
color_map
[0 rgb <0.7, 1, 1>]
[0.15 rgb <0, 0.4, 1>]
[1 rgb <0, 0.4, 1>]
#end */
#if (models[3] | models[4])
plane
y, 0
texture // bare sandy soil
pigment { color rgb <0.5, 0.35, 0.2> }
#if (models[2] | models[3])
light_source
<0, 500000, 1000000>
color rgb 1
#if (models[3])
sky_sphere
pigment
gradient y
color_map
[0 rgb <0.7, 1, 1>]
[0.25 rgb <0, 0.5, 1>]
[1 rgb <0, 0.5, 1>]
union
object // Apartment block Friedrich-Karl-Straße #246, #248, #250
and #252
scale 1/f
translate trans/f
#declare a=0;
#while (a<3) // 3 floors with balconies
#declare b=0;
#while (b<2) // 2 balconies per floor
object
translate (<-1.155 +b * 0.515,
GWG_FrKarl_Block_Floor_yOffset + a * GWG_FrKarl_Block_Floor_Height,
1.045 + b * GWG_FrKarl_Block_Balcony_Spacing>
+ trans)/f
#declare b = b + 1;
#declare a = a + 1;
texture { T_Concrete }
object // Apartment block Friedrich-Karl-Straße #238, #240, #242
and #244
scale 1/f
translate (< -((FrKarl_SideStreet_Pavement_Width +
GWG_FrKarl_Block_Front_Doorstep_Depth) * 2 +
FrKarl_SideStreet_Width)*2,
0,
0 > + trans)/f
camera
location camPos/f+trans
look_at camLook/f+trans
angle camAng
#else // single detail views
sky_sphere
pigment { color rgb 1 }
plane
y, 0
texture
light_source
<1000, 2000, -4000>
color rgb 1
object
camera
location <8, 1.5, 1.6>
look_at <0, 0.5, 1.6>
angle 40
