POV-Ray : Newsgroups : povray.binaries.scene-files : PoVEarth: strange phenomenon Server Time
15 Jul 2026 19:22:06 EDT (-0400)
  PoVEarth: strange phenomenon (Message 1 to 1 of 1)
Subject: PoVEarth: strange phenomenon
Date: 31 Jul 2008 07:30:25
Message: <4891a251@news.povray.org>
High!
After the harddisk crash, I found out, that I made the last backup
BEFORE I started the PoVEarth project... so I had to program the (still
very embryonic) scene once again. After advancing to the balconies (but
not yet to the floor cutouts and balcony doors), I noticed that suddenly
the blue sky_sphere (lines 153 to 165) disappeared, although the scale
flag models[3] was set... and when I commented out the mentioned lines,
also the ground plane (lines 169 to 177) disappeared, even after I added
a new (also conditional) definition of the sky_sphere (lines 190 to
202)! Why? All #if clauses are properly terminated by #end...
Here's the code:
// My Place in the World
// A sub-sub-subsection of the PoVEarth project
// E-mail: yaz### [at] gmxde
// RADIOSITY
#declare radio=1;
global_settings
   #if (!radio)
     ambient_light 0.15
   #else
     ambient_light 0
     radiosity
       brightness 1
       adc_bailout 0.01
       gray_threshold 0.8
// TIME VARIABLES
// PIGMENTS
#declare P_Concrete =
pigment
   color rgb 0.9
// FINISHES
#declare F_Standard =
finish
   diffuse 1
   brilliance 0.15
// NORMALS
// TEXTURES
#declare T_Concrete =
texture
   pigment { P_Concrete }
   finish { F_Standard }
// LENGTH VARIABLES
#declare FrKarl_SideStreet_Width = 6.09;
#declare FrKarl_SideStreet_Pavement_Width = 1.32;
#declare GWG_FrKarl_Block_Front_Way_Length = 4.09;
#declare GWG_FrKarl_Block_Front_Doorstep_Depth = 0.427;
#declare GWG_FrKarl_Block_Stair_Height = 0.168;
#declare GWG_FrKarl_Block_Floor_Height = 16 * GWG_FrKarl_Block_Stair_Height;
#declare GWG_FrKarl_Block_Floor_yOffset = 8 * GWG_FrKarl_Block_Stair_Height;
#declare GWG_FrKarl_Block_Ceiling_Thickness = 0.148;
#declare GWG_FrKarl_Block_Balcony_Spacing=9.19;
#declare GWG_FrKarl_Block_Floor_Offset =
// OBJECT DEFINITIONS
#declare GWG_FrKarl_Block_Raw=
box
   0, <11.08, 9.523, 53.49>
#declare GWG_FrKarl_Block_Balcony_Raw=
difference
   box
     0, <1.155, 0.948, 3.24>
   box
     <0.165, 0.148, 0.155>, <1.65, 0.95, 3.085>
// CAMERA SETTINGS
// using microlocal coordinates
#declare view=1;
#switch(view)
   #case (0)
     #declare camPos = <-5, 1.7, -10>;
     #declare camLook = <5, 7.2, 3>;
     #declare camAng = 40;
   #break
   #case (1)
     #declare camPos = <-(FrKarl_SideStreet_Width / 2 +
FrKarl_SideStreet_Pavement_Width + GWG_FrKarl_Block_Front_Way_Length +
                        GWG_FrKarl_Block_Front_Doorstep_Depth), 1.7, 70>;
     #declare camLook =<-(FrKarl_SideStreet_Width / 2 +
                        GWG_FrKarl_Block_Front_Doorstep_Depth), 1.7, 0>;
     #declare camAng = 60;
   #break
// ACTUAL SCENE
#declare detail=0;
#if (!detail) // full scene views
   // SCALE MODELS
   #declare models = array[5] { 0, 0, 0, 1, 0 }
   // models[0]: cosmic scale - whole Solar System, heliocentric
   // models[1]: global scale - Earth, geocentric, spherical terrain relief
   // models[2]: regional scale - 40 x 40 kms area around Cologne,
heightfield
   // models[3]: local scale - 500 x 500 metres around my apartment, plane
   // models[4]: microlocal - my apartment only, outside world only as
HDRI bitmaps
   #declare a=0;
   #declare i=0;
   #while (a<5)
     #if (models[a])
       #declare i=i+1;
     #declare a=a+1;
   #if (!i | i>1)
     #warning "Missing or ambiguous scale setting" // terminating POV script
   #else
     #if (models[0])
       #declare f=1000000 // 1 unit = 1000 kms
     #if (models[1])
       #declare f=1000; // 1 unit = 1 km
     #if (models[2] | models[3] | models[4])
       #declare f=1; // 1 unit = 1 metre
     #if (models[3])
       #declare trans=<251.565, 0, 250.325>;
     /* #if (models[3])
       sky_sphere
         pigment
           gradient y
           color_map
             [0 rgb <0.7, 1, 1>]
             [0.15 rgb <0, 0.4, 1>]
             [1    rgb <0, 0.4, 1>]
     #end */
     #if (models[3] | models[4])
       plane
         y, 0
         texture // bare sandy soil
           pigment { color rgb <0.5, 0.35, 0.2> }
     #if (models[2] | models[3])
       light_source
         <0, 500000, 1000000>
         color rgb 1
     #if (models[3])
     sky_sphere
       pigment
         gradient y
         color_map
           [0 rgb <0.7, 1, 1>]
           [0.25 rgb <0, 0.5, 1>]
           [1    rgb <0, 0.5, 1>]
     union
and #252
         scale 1/f
         translate trans/f
       #declare a=0;
       #while (a<3) // 3 floors with balconies
         #declare b=0;
         #while (b<2) // 2 balconies per floor
           object
             translate (<-1.155 +b * 0.515,
GWG_FrKarl_Block_Floor_yOffset + a * GWG_FrKarl_Block_Floor_Height,
1.045 + b * GWG_FrKarl_Block_Balcony_Spacing>
                        + trans)/f
           #declare b = b + 1;
         #declare a = a + 1;
       texture { T_Concrete }
and #244
       scale 1/f
       translate (< -((FrKarl_SideStreet_Pavement_Width +
GWG_FrKarl_Block_Front_Doorstep_Depth) * 2 +
                      FrKarl_SideStreet_Width)*2,
                      0,
                      0 > + trans)/f
     camera
       location camPos/f+trans
       look_at camLook/f+trans
       angle camAng
#else // single detail views
   sky_sphere
     pigment { color rgb 1 }
   plane
     y, 0
     texture
   light_source
     <1000, 2000, -4000>
     color rgb 1
   object
   camera
      location <8, 1.5, 1.6>
      look_at  <0, 0.5, 1.6>
      angle 40
