POV-Ray : Newsgroups : povray.binaries.scene-files : cubic interpolation for image_maps Server Time
27 Mar 2026 02:29:12 EDT (-0400)
  cubic interpolation for image_maps (Message 1 to 7 of 7)
Subject: cubic interpolation for image_maps
Date: 6 Mar 2007 20:47:38
Message: <45ee19ba@news.povray.org>
The files are in the zip!
~Sam
Download 'cubic_interpolation.zip' (3 KB)
Subject: Re: cubic interpolation for image_maps
Date: 10 Mar 2007 18:04:25
Message: <45f33979@news.povray.org>
Following the discussion in povray.binaries.images under the same
subject, here is my implementation of the bicubic interpolation.
The archive contains a scene file with the macro used for the
interpolation (could probably easily put in an include file if need be)
and an example TGA height field to test it on.
The implementation here is quite slow because it uses many function
calls. On the other hand, you could probably tweak it to have
interesting effects (for example by twisting the slope computation...).
Anyhow it is quite necessary when you want to blend image data with
procedural patterns in POV-Ray, because the internal interpolation
methods are more visible. I sure hope to see a similar internal method
in future official versions of POV-Ray...
And my thanks to Samuel for making me rediscover and clean up my old
code ;-)
Regards
Vincent
Download 'interpolation.zip' (8 KB)
Date: 10 Mar 2007 19:52:14
Message: <45f352be@news.povray.org>
> calls.
Whoah. I'm inclined to call it slow, considering it took 1m 36s just to
parse!
Upon closer inspection of the rendered image, I see that it shares
similar "step" artifacts as can be found with the blended cells
implementation, albeit yours are much less pronounced.
> code ;-)
> Regards
Hey, any time I can help :)
~Sam
Date: 11 Mar 2007 05:24:06
Message: <45f3d8c6$1@news.povray.org>
>>  calls.
> to parse!
O:-)
OK, maybe I should have said 'very slow' then :-)
Back when I was playing with that I chose to use a height field built at
parse time, because when used in an isosurface... It's even slower. At
least after parsing the render goes quick.
Yep, I saw those too.
I think that what we see here are discontinuities in the second
derivative, i.e. the slope is perfectly continuous but we can still see
that its rate of variation is not. The glossy finish also makes those
stand out.
Well, either that, or my implementation is wrong because the first
derivative *should* be continuous ;-)
Is there the same kind of effects with Megapov's interpolate 3 ?
Best
Vincent
Date: 11 Mar 2007 08:20:20
Message: <45f40214$1@news.povray.org>
I just downloaded Megapov and tried interpolate 3, and I have the same
result. Well, almost... There are strange things at the border, maybe
because I have some offset. But the 'step' effect is indeed there.
I feel reassured for my code, it is still slow but at least it does what
I think it does :-)
Regards
Vincent
Date: 11 Mar 2007 12:14:13
Message: <45f438e5$1@news.povray.org>
There is a bug with interpolate 3, now that you mention it. When you
wrap the interpolated image inside a pigment_pattern, the white portions
of the image turn black....
~Sam
Date: 11 Mar 2007 14:44:58
Message: <45f45c3a$1@news.povray.org>
That could be because the values are not clipped to [0,1] after the
interpolation. IIRC in a pigment_pattern, only the fractional part is
taken into account, i.e. if the pigment value is 1.1, higher than white,
it is mapped to 0.1, nearly black.
Even if all grid points have values between 0 and 1, with the bicubic
interpolation you can get values out of that range. This does not happen
with bilinear interpolation.
In my code I have a choice to clip or not the value, in Megapov I don't
know what choice has been made...
Regards
Vincent
