POV-Ray : Newsgroups : povray.binaries.scene-files : Light Beams in a Dusty Atmosphere Server Time
19 Dec 2025 07:56:45 EST (-0500)
  Light Beams in a Dusty Atmosphere (Message 1 to 9 of 9)
Subject: Light Beams in a Dusty Atmosphere
Date: 15 Nov 2006 07:19:05
Message: <455b05b9@news.povray.org>
Hi everyone.
Is there any sample code how to create a dusty atmosphere where lightsources
create visible light beams, and where the air around a lightsource is
iluminated (particles?)?
I know I once saw such an image rendered with POV-Ray, but I don't remember
anymore and have no access to the details or sourcecode.
Thanks,
Sven
Subject: Re: Light Beams in a Dusty Atmosphere
Date: 15 Nov 2006 22:44:05
Message: <455bde85$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 15/11/2006 07:19:
> Hi everyone.
> Thanks,
> Sven
More than one way.
Acurate but slow: fill the scene with scathering media.
Somewhat faster: as above, but the media is contained around the beam by some
container.
Both use a strong light_source to illuminate the media.
Faked but faster: the beam path is materialised by a long conical container
filled with emissive media.
Here, the actual light is just for show as the media itself is luminous.
Using the last 2, you need to increase max_trace_level, particularly if you have
multiple beams that may visualy cross each other.
If you are good, you will be assigned all the work. If you are really good, you
will get out of it.
Date: 16 Nov 2006 08:43:08
Message: <455c6aec$1@news.povray.org>
Alain,
can you give me an example code? I just start to work with media...   :-(
Thanks,
Sven
> More than one way.
> some container.
> container filled with emissive media.
> you have multiple beams that may visualy cross each other.
> Alain
> good, you will get out of it.
Date: 16 Nov 2006 17:16:28
Message: <455ce33c$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 16/11/2006 08:43:
> Alain,
> Thanks,
> Sven
>> More than one way.
>> some container.
>> Alain
Minimal samples for the suggestions.
1-
media{scattering{1 rgb 1}samples 100}//scene whide media using isotropic scattering
light_source{0, rgb 100//very bright so you can easily see the beam
	spot_light radius 2 falloff 3 point_at x rotate -32*y}
//A tight spot light shining to the right and away
2-
union{//link light and media cone so they can be oriented together
cone{0,0, 1000*x,53 pigment{rgbt 1}interior{media{scattering{1 rgb 1}samples 10}}}
	spot_light radius 2 falloff 3 point_at x}
rotate -32*y}
3-
cone{0,0, 1000*x,53 pigment{rgbt 1}interior{media{emission 50}samples 10}rotate
32*y}
//this won't shed any light, unless you are using radiosity.
No matter how good she looks, some other guy is sick and tired of putting up
with her shit.
	Men's Room, Linda's Bar and Grill, Chapel Hill , NC
Date: 17 Nov 2006 02:58:49
Message: <455d6bb9$1@news.povray.org>
Alain,
thanks a lot!
I tried it out, but the current beta version does not reach yet the full
performance of the last full version of POV-Ray. Seems I have to wait...
I will try to get the last full version and try the render!
Greetings,
Sven
Date: 17 Nov 2006 03:26:27
Message: <455d7233$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> schreef in bericht
news:455d6bb9$1@news.povray.org...
> Alain,
> thanks a lot!
Beta is beta, Sven  :-)
How so? If you can use the beta, you have already a full version? Or do I
miss something here?
By the way, Megapov is also really worthwhile.
Date: 17 Nov 2006 11:55:51
Message: <455de997@news.povray.org>
Beta is not yet fully reaching the performance.
That's why I need to get the last "regular" version. The betas always
overwite the .exe files of the regular version.
Greetings,
Sven
Date: 17 Nov 2006 20:33:35
Message: <455e62ef$1@news.povray.org>
Sven Littkowski nous apporta ses lumieres en ce 17/11/2006 11:55:
> Greetings,
> Sven
Install the beta in it's own subfolder.
That way, you have both versions available. It's the proposed and recomended way
of doing it.
Hardware, n.: The parts of a computer system that can be kicked.
Date: 18 Nov 2006 08:25:43
Message: <455f09d7@news.povray.org>
True, true. I should have done so...   :-)
Thanks,
Sven
> recomended way of doing it.
> Alain
