POV-Ray : Newsgroups : povray.binaries.scene-files : Trace: How to work together with Rotate Server Time
13 Jun 2026 14:47:07 EDT (-0400)
  Trace: How to work together with Rotate (Message 1 to 5 of 5)
Subject: Trace: How to work together with Rotate
Date: 11 Nov 2006 03:06:40
Message: <45558490@news.povray.org>
Here a sample of my scene:
#declare Normal=< 0.0, 0.0, 0.0 >;
#declare Angle=30.0;
#while(Angle<360)
 #declare Location=< -25.0, 100.0, 0.0 > rotate < 0.0, Angle, 0.0 >;
 #declare Boden=trace( Meeresgrund, Location, -y, Normal );
 object {Licht translate < -25.0, Boden.y, 0.0 > rotate < 0.0, Angle, 0.0
 declare Angle=Angle+30;
I intent to place some objects (called "Licht") in a circle. Since the
underground is a height_field, I want to use Trace to get the proper Y
coordinate of the current location. There I fail. I don't know exactly, how
to properly define the location for Trace. Please see above. of course, that
returns an error message. How to do it better?
Thanks,
Sven
Subject: Re: Trace: How to work together with Rotate
Date: 11 Nov 2006 03:22:08
Message: <45558830$1@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> schreef in bericht
news:45558490@news.povray.org...
> how to properly define the location for Trace. Please see above. of
> course, that returns an error message. How to do it better?
I think you should determine first the new location by using:
vtransform(Vect, Trans)
in transform.inc, and then apply that to the trace().
Date: 11 Nov 2006 03:55:08
Message: <45558fec@news.povray.org>
It should work like this:
----------8<----------8<----------8<----------8<----------8<----------
#while(Angle<360)
  #declare LPos=trace( Meeresgrund, Location, -y, Normal );
  object {Licht translate LPos }
> #while(Angle<360)
> #end
> Thanks,
> Sven
Date: 11 Nov 2006 04:15:31
Message: <455594b3@news.povray.org>
"Sven Littkowski" <sve### [at] jamaica-focuscom> wrote in message
> #while(Angle<360)
> #end
> Thanks,
> Sven
Hi Sven,
It looks to me like you want 'Location' to be a point that is 25 units from
the Y axis and rotates around it.
You can get that by declaring 'Location' using:
#declare Location = vrotate(<-25,100,0>,<0,Angle,0>).
and it's always best (to avoid dissapointment) to test whether you actually
hit the surface using:
  #if (vlength(Norm)!=0)
By the way, if you start at 30 degrees and stop before you get to 360
degrees, then, don't you get an incomplete circle of Licht's (whatever a
Licht is).
As Jorg pointed out, you should be able to place your Licht on your
Meeresgrund using just:
  object {Licht translate Boden}
Regards
Chris B.
Date: 11 Nov 2006 04:48:36
Message: <45559c74$1@news.povray.org>
If your Licht object is a light_source you should also add an Y offset to the
position.
Otherwise your light_source is located exacly on the Meeresgrund object, this could
cause some problems.
So here's the new code with an Y offset:
#declare YOffset = 10;	// The lights are located YOffset
			// units above the Meeresgrund object
#while(Angle<360)
  object {Licht translate LPos + <0,YOffset,0> }
> #while(Angle<360)
> #end
>> #while(Angle<360)
>> 0.0  > }
>> #end
>> exactly, how to properly define the location for Trace. Please see
>> above. of course, that returns an error message. How to do it better?
>> Thanks,
>> Sven
