POV-Ray : Newsgroups : povray.binaries.scene-files : Greeble-macros Server Time
29 Sep 2024 00:15:53 EDT (-0400)
  Greeble-macros (Message 1 to 10 of 16)
Subject: Greeble-macros
Date: 5 Jun 2006 11:49:50
Message: <4484529e$1@news.povray.org>
stats for the demo-file:
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes 11 seconds (11 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Cloth Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Mechsim Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  3 minutes 33 seconds (213 seconds)
  Postpr. Time:  0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  3 minutes 44 seconds (224 seconds)
CPU time used: kernel 4.91 seconds, user 201.72 seconds, total 206.62
seconds
Render averaged 5947.01 PPS over 1228800 pixels
there is some explanation of how to use it in the file greebles.inc
cu!
Download 'greebles.zip' (10 KB)
Subject: Re: Greeble-macros
Date: 6 Jun 2006 06:04:20
Message: <44855324$1@news.povray.org>
When I try to render your POV file I get the following error...
    Parse Error: Singular matrix in MInvers.
I am using WinPOV 3.6.1c.. Do I need another version?
Rarius
Date: 6 Jun 2006 08:04:17
Message: <44856f41$1@news.povray.org>
"Rarius" <rar### [at] rariuscouk> wrote in message
news:44855324$1@news.povray.org...
you should read the first lines of greebles.inc, it says:
// Greeble-macros and utilities
// for some weird reason, these don't function properly in POV-Ray
3.6.1, but they work fine in MegaPOV
the problem, as far as I can tell, is that some greeble-cells get too
small for POV-Ray, causing an error in the official version when I try
to create a polygon for that cell.  MegaPOV probably just ignores those
polygons.
cu!
Date: 7 Jun 2006 05:24:07
Message: <44869b37$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] povplacecom> wrote in message
news:44856f41$1@news.povray.org...
>// for some weird reason, these don't function properly in POV-Ray 3.6.1,
>the problem, as far as I can tell, is that some greeble-cells get too small
>for POV-Ray, causing an error in >the official version when I try to create
>a polygon for that cell.  MegaPOV probably just ignores those >polygons.
Nope, Megapov also throws the same error specifically pointing at line 75
Reading your code it looks like you've got a NOP #while...#end
Is it possible you've posted the wrong version - something I've done a few
times :-)
Mind you, it would help if my Dutch was better then I could read all your
comments (I must buy a dictionary)
John
"Please refrain from fondling the nymphs and sprites - it makes them giggly
and skittish.
Thank you for your co-operation.
The Management"
Date: 7 Jun 2006 09:24:07
Message: <4486d377@news.povray.org>
"Doctor John" <doc### [at] linuxmailorg> wrote in message
news:44869b37$1@news.povray.org...
3.6.1,
small
create
>polygons.
75
few
> times :-)
your
I posted a more or less working version, but there are a few bugs in it.
try this one.
cu!
Download 'us-ascii' (47 KB)
Date: 7 Jun 2006 16:30:01
Message: <web.448736d68ff9e6c3a8399d8d0@news.povray.org>
I'm a native Dutch speaker, but somehow reading code with Dutch comments
feels wrong. I use English in my own code, as well as for my txt files with
notes.
English just seems much more dyslectic-friendly, and also a better fit for
describing technical things. (and it's plain shorter) :-)
Date: 8 Jun 2006 05:03:47
Message: <4487e7f3@news.povray.org>
"Jaap" <jws### [at] yahoocom> wrote in message
news:web.448736d68ff9e6c3a8399d8d0@news.povray.org...
True ...
Now see p.b.i. for continuation of this discussion
John
and skittish.
The Management"
Date: 8 Jun 2006 08:18:09
Message: <44881581@news.povray.org>
news:4487e7f3@news.povray.org...
fit for
> True ...
I disagree, but I'm not going to turn this into a discussion.
cu!
Date: 20 Jun 2006 12:13:04
Message: <44981e90$1@news.povray.org>
Hi Zeger,
I am also getting errors, and I use the updated version you posted as
response of Doctor John's and Rarius' problems.
Here is the error message:
Preset INI file is 'D:\PROGRAMME\POV-RAY FOR WINDOWS\RENDERER\QUICKRES.INI',
section is '[800x600, AA 0.3]'.
Preset source file is 'D:\Programme\POV-Ray for Windows\Scenes\Other
Authors\Greebles\greebletest.pov'.
Rendering with 4 threads.
Parser Options
  Input file: D:\Programme\POV-Ray for Windows\Scenes\Other
  Remove bounds........On
  Split unions.........Off
  Library paths:
    D:\Programme\POV-Ray for Windows\Include
    E:\Scripts\Eigene Bilder\Povray Textures
    C:\WINDOWS\Fonts
    D:\PROGRAMME\POV-RAY FOR WINDOWS\include
    C:\WINDOWS\Fonts
File 'D:\Programme\POV-Ray for Windows\Include\greebles.inc' line 75: Parse
Warning: Polygon not closed. Closing it.
File 'D:\Programme\POV-Ray for Windows\Include\greebles.inc' line 520: Parse
Warning: Patch objects not allowed in intersection.
File 'D:\Programme\POV-Ray for Windows\Include\greebles.inc' line 521: Parse
Warning: Should have at least 2 objects in csg.
Possible Parse Error: Singular matrix in MInvers.
Fatal error in parser: Uncategorized error.
Render failed
CPU time used: kernel 0.58 seconds, user 0.16 seconds, total 0.73 seconds.
Elapsed time 0.86 seconds.
Date: 24 Aug 2006 07:34:03
Message: <44ed8eab$1@news.povray.org>
Just curious...
Doctor John had found a way to correct Zeger's Greeble but has not posted a
new version. How are things going on that front?
