POV-Ray : Newsgroups : povray.binaries.scene-files : Macro to convert rotational axes Server Time
13 Jun 2026 16:26:38 EDT (-0400)
  Macro to convert rotational axes (Message 1 to 1 of 1)
Subject: Macro to convert rotational axes
Date: 2 Feb 2006 06:53:28
Message: <43e1f2b8@news.povray.org>
The attached macro is designed to take a set of 3 rotations developed for
one rotational system and convert it into a set of 3 rotations consistent
with an alternative rotational system. Initially it was written to convert
BVH motion capture joint rotation data into POV-Person joint rotations.
Since then it has been parameterised and extended to increase the rotational
systems that it can handle and to convert in either direction.
The BVH system uses a sequence of axes (usually Z, X, Y) to define joint
rotations. The Z and Y rotations are equivalent to negative rotations in the
standard POV-Ray space. Furthermore, the BVH axes move with the object,
whereas POV-Ray axes remain stationary as an object is rotated around them.
Comments welcome.
Chris B.
Download 'AxisConverter.pov.txt' (10 KB)
