POV-Ray : Newsgroups : povray.binaries.scene-files : Flea City Server Time
22 May 2025 12:02:34 EDT (-0400)
  Flea City (Message 1 to 1 of 1)
Subject: Flea City
Date: 3 Mar 2005 21:57:43
Message: <4227cea7$1@news.povray.org>
// Persistence of Vision Ray Tracer Scene Description File
// File: fleacity.pov
// Vers: 3.6
// Desc: Hairs with windows
// Date: 3/2/2005
// Auth: Tim Attwood
#version 3.5;
#include "functions.inc"
#include "finish.inc"
global_settings {
  assumed_gamma 1.0
  location  <0.0, 1, -2.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare grass = function { (y+1) - f_noise3d(x * 4, y * 4, z * 4) *1 };
#declare g1 = isosurface {  // a noisy plane
    function { grass(x,y,z)}
    contained_by { box { <-10,-1,-10>,<10,2,10> } }
    evaluate 200,2,1
    pigment {checker Red White}
#declare R1 = seed(0);
#declare fur = function { // for picking random hair color
      gradient x
      color_map {
         [0 Gray90]
         [0.1 Yellow]
         [0.2 Tan]
         [0.5 Brown]
         [0.9 Black]
         [1 Black]
#declare grid = 0.04;
#declare base = 0.02;
#declare tip = 0.01;
union {
   #declare Col = -3;
   #while (Col < 10)
      #declare Row = -6.5;
      #while (Row < 6.5)
         #declare Spot = trace(g1,<Row,3,Col>,<0,-1,0>);
         //#declare adj = Spot.y+1;
         //#declare opp = grid/2;
         #declare ang = atan2(grid/2,Spot.y+1)*180/3.1416; // maximum random
angle
         #declare RX = rand(R1)*ang*2-ang; // random rotate
         #declare RZ = rand(R1)*ang*2-ang;
         union {
            sphere {<0,Spot.y+1,0>,tip}
            #switch (Col) //reduce number of windows in areas they aren't
seen
            #range (-2.2,2.2)
               difference {
                  cone{<0,0,0>,base,<0,Spot.y+1,0>,tip}
                  box{<-0.375*tip,0,-1>,<0.375*tip,tip*2,0> translate
<0,Spot.y+1-2*tip,0> }
<0,Spot.y+1-5*tip,0> }
<0,Spot.y+1-8*tip,0> }
<0,Spot.y+1-11*tip,0> }
<0,Spot.y+1-14*tip,0> }
<0,Spot.y+1-17*tip,0> }
<0,Spot.y+1-20*tip,0> }
<0,Spot.y+1-23*tip,0> }
<0,Spot.y+1-26*tip,0> }
<0,Spot.y+1-29*tip,0> }
<0,Spot.y+1-32*tip,0> }
<0,Spot.y+1-35*tip,0> }
<0,Spot.y+1-38*tip,0> }
               cone{<0,0,0>,base-tip/2,<0,Spot.y+1,0>,tip-tip/2
                     pigment {Blue}
                     finish {
                        reflection { 0.03, 1 }
            #break
            #range (2.2000001,7)
               difference {
                     pigment {Blue}
                     finish {
            #break
            #else
            #declare rpig = fur(rand(R1),0,0);
               pigment {color rpig }
               finish {Dull}
            rotate <RX,0,RZ>
            translate <Spot.x,-1,Spot.z>
         #declare Row = Row + grid;
      #declare Col = Col + grid;
/*   // the isosurface
object {
   g1
plane {
  y,
  -1.0
         cells
         color_map {
            [0 Pink ]
            [0.8 Pink ]
            [0.81 White ]
            [1 White]
      finish {Dull}
