POV-Ray : Newsgroups : povray.binaries.scene-files : A POV-color picker Server Time
27 Mar 2026 10:20:21 EDT (-0400)
  A POV-color picker (Message 1 to 3 of 3)
Subject: A POV-color picker
Date: 3 Jan 2005 11:30:32
Message: <41d97328$1@news.povray.org>
Sample image in p.b.i.
Paolo
%<-------------------------- cut here ----
// POV-color picker
// Paolo Gibellini 2005
// A simple wallpaper: +H1280 +W1024 +A0.1 (for straight lines AA 0.1 is
better)
Parameters
cubes: size of the color cube
  n.b. increasing this number could be very memory-consuming (with 256 Mb I
cannot use more than 100 cubes)
tipo: type of the color 0=solid, 1=semitransparent, 2=metallic
random seed determines position (picking) of the color dropper and the color
of the dropper itself
#version 3.5;
// Impostazioni globali ------------------------------------
global_settings {
  assumed_gamma 1.0
  max_trace_level 5
// Ambiente ------------------------------------------------
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
// Parameters ----------------------------------------------
#declare cubes=8;     /* Size of the color cube */
#declare tipo=2;      /* 0=solid, 1=semitransparent, 2=metallic */
#declare s=seed(39);   /* Random seed (determines position of the color
dropper and the color of the dropper itself) */
// Random --------------------------------------------------
#macro r(m)
    rand(s)*m
// Textures ------------------------------------------------
#declare t_cromata=texture {
      color rgb <0.8,0.8,1.0>
    finish{
      diffuse 0.3
      ambient 0.0
      specular 0.6
      reflection {
        0.8
        metallic
      conserve_energy
#declare t_onde=  texture {
    normal {
     waves
    finish{
      diffuse 0.3
      ambient 0.0
      specular 0.6
      reflection {
        0.8
// Moray's NBoldglass
#declare NBoldglass = material  {
            color rgbf <0.8, 0.9, 0.85, 0.85>
         finish {
            ambient 0.1
            diffuse 0.1
            specular 1.0
            roughness 0.001
            reflection 0.25
      interior  {
         ior 1.5
// Camera --------------------------------------------------
  location  <-cubes*0.8, cubes*0.6, -cubes*3.5>
  direction 1.5*z
  look_at   cubes/2
// Un po' di scena -----------------------------------------
plane {
 y, -3
 texture {t_onde scale cubes}
sphere {
 <-cubes/2,cubes/1.8,cubes/2>, cubes/3
 texture {t_cromata}
// color dropper -------------------------------------------
#declare cx=(r(cubes))*0.6+cubes*0.2;
#declare cy=(r(cubes))*0.6+cubes*0.2;
#declare cz=(r(cubes))*0.6+cubes*0.2;
cylinder {<cx,cy,cz> <cubes*0.8,cubes*0.9,-cubes*1> 0.2*(cubes/10)
 pigment {color rgbft <cx/cubes,cy/cubes,cz/cubes,0.6,0.3>}
cylinder {<cubes*0.8,cubes*0.9,-cubes*1> <cubes*0.8,cubes*0.7,-cubes*1.35>
0.2*(cubes/10)
 pigment {color rgbft <cx/cubes,cy/cubes,cz/cubes,0.3,0.3>}
// Glass ---------------------------------------------------
difference {
 cylinder {<cubes*0.8,cubes*0.8,-cubes*1.3>
<cubes*0.8,cubes*0.35,-cubes*1.3> 1.1*(cubes/10)}
 cylinder {<cubes*0.8,cubes*0.8,-cubes*1.3> <cubes*0.8,cubes*0.4,-cubes*1.3>
1*(cubes/10)}
 material {NBoldglass}
cylinder {<cubes*0.8,cubes*0.7,-cubes*1.3> <cubes*0.8,cubes*0.4,-cubes*1.3>
1*(cubes/10)
 pigment {color rgb <cx/cubes,cy/cubes,cz/cubes>}
// Colors --------------------------------------------------
#declare rx=0;
#declare gy=0;
#declare bz=0;
#while (rx<cubes)
 #declare gy=0;
 #while (gy<cubes)
  #declare bz=0;
  #while (bz<cubes)
   #switch(tipo)
    #case(1)
     box {<rx,gy,bz>, <rx+0.8,gy+0.8,bz+0.8> pigment {color rgbft
<rx/cubes,gy/cubes,bz/cubes,0.6,0.3>}}
    #break
    #case(2)
<rx/cubes,gy/cubes,bz/cubes> } finish{diffuse 0.3 ambient 0.0 specular 0.6
reflection {0.8 metallic}}}
    #break
    #else
<rx/cubes,gy/cubes,bz/cubes>}}
   #declare bz=bz+1;
  #declare gy=gy+1;
 #declare rx=rx+1;
Download 'color_picker_03_en.zip' (2 KB)
Subject: Re: A POV-color picker
Date: 8 Jul 2005 04:05:02
Message: <web.42ce335a2715ce6ec62e6bcb0@news.povray.org>
Cool! I actually made something similar, but not nearly as good as this. I
didn't realize this already existed.
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.42cc6059664ac275c62e6bcb0%40news.povray.org%3E/
Date: 8 Jul 2005 08:54:30
Message: <42ce7786$1@news.povray.org>
Hope it can help you.
I've realized that a 3d color picker must be interactive and needs some
(simple) mathematics and time (I haven't) to be performed.
Basic idea is to have a 256+256+256 cube with visible pixel colored by
coordinates (e.g. r=x, g=y, b=z), a button to rotate the cube and a pipe
tool to pick in depth the color, showing the section of the cube normal to
the pipe while the pipe is advancing in his interior. From the section the
color can be picked.
Have a nice day,
Paolo
