POV-Ray : Newsgroups : povray.binaries.scene-files : How to do bent rebar Server Time
22 May 2025 17:55:41 EDT (-0400)
  How to do bent rebar (Message 1 to 3 of 3)
Subject: How to do bent rebar
Date: 9 Sep 2004 00:01:23
Message: <413fd593@news.povray.org>
How would you POV-Ray gurus do a bent rebar.
So for example a straight section, then a 90 degree smooth bend (with some
bending radius), another straight section, another bend (for example a U
with a flat bottom).
I tries with a sphere-sweep and a cubic spline, but this does not give me
the ability to specify the bend radius and I was unable to produce a smooth
shape. I really do not want to have to specify the bend points explicitly.
I want to be able to specify the shape descriptively. For example, 0.5
straight, 90 degree bend (downwards) with bend radius of 0.2, 1.0 straight,
90 degree bend (upwards) with bend radius of 0.3.
Is there a way?
Thanks,
dave
Subject: Re: How to do bent rebar
Date: 9 Sep 2004 13:41:31
Message: <414095B8.2070807@hotmail.com>
> Is there a way?
> Thanks,
> dave
I'm not so sure this is the right group to be asking this....
Anyway, to make such bent rebar I would contruct it out of clipped torii
and cylinders. A simple bar with a radius-2 bend at the beginning would
look something like this:
union{
  cylinder{0,x*3,.1}
  torus{2,.1
   clipped_by{
    box{
     <-2.5,-.2,-2.5>,<0,.2,0>
   rotate x*270 translate y*2
  pigment{rgb .13}
Please note that using clipped torii and cylinders in this manner will
render more quickly than using a sphere_sweep.
-Sam
Date: 9 Sep 2004 15:44:23
Message: <4140b297$1@news.povray.org>
i came across this problem quite a few times before, so i decided to make a
macro which does this automaticly. It is finished (only 2D), but not ready
for publishing. This weekend i shall finish the 2D version, 3D version is a
bit more difficult.
Greetings,
JWV
"Dave" <DAn### [at] Genifycom> wrote in message
news:413fd593@news.povray.org...
smooth
straight,
> Is there a way?
> Thanks,
> dave
