POV-Ray : Newsgroups : povray.binaries.scene-files : Discontinuous functions? Server Time
13 Jun 2026 20:32:54 EDT (-0400)
  Discontinuous functions? (Message 1 to 5 of 5)
Subject: Discontinuous functions?
Date: 14 Aug 2004 07:19:55
Message: <411df55b$1@news.povray.org>
High!
I'm not really sure whether I'm on-topic here or not... but as this
group also deals with programming techniques, I just assumed...
My question: does PoV-Ray allow programming of "discontinuous" functions
(I only dabble in math, so please don't stone me if this is not the
correct terminus!)?
Is it possible to write a function which changes apruptly at certain
values, such as
from x=0 to x=1.5: pow(x, 2)
from x=1.5 to x=7: sqrt(14-x)+3
etc. etc. ?
See you in Khyberspace -
http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/
Yadgar
Now playing: Deimos and Phobos go to Mars (Synergy)
Subject: Re: Discontinuous functions?
Date: 14 Aug 2004 14:07:10
Message: <411e54ce$1@news.povray.org>
hi,
I think p.general would be better
> correct terminus!)?
> values, such as
> etc. etc. ?
Where would you like to use it? If you want to use it to describe the
postion of an object (in an animation), you can try the following:
#declare f1=function(x){pow(x,2)};
#declare f2=function(x){sqrt(14-x)+3};
#if(x>0 && x<1.5)//correct way to describe interval??
//use f1 to get position
#if(other interval)
//use f2 f1 to get position
I assume it would have the same effect as an discontious function.
Hoping to be of help,
JWV
"Yadgar" <yaz### [at] gmxde> wrote in message
news:411df55b$1@news.povray.org...
> High!
> correct terminus!)?
> values, such as
> etc. etc. ?
> Yadgar
Date: 15 Aug 2004 12:56:50
Message: <411f95d2@news.povray.org>
Yadgar nous apporta ses lumieres ainsi en ce 14/08/2004 07:33... :
> High!
> functions (I only dabble in math, so please don't stone me if this is
> not the correct terminus!)?
> values, such as
> etc. etc. ?
> Yadgar
It's possible but not alway a good solution. If used in an isosurface,
it will lead to infinite gradient. It may be preferable to use an union
of different objects, each modeled acording to a continuous function.
If used to define a path in an animation, it can lead to whatever is
folowing that path to jump around.
In your case use a #switch:
#switch(YourVar)
    #range(0,1.5)#declare OutVar=pow(YourVar,1);#break
    #range(1.5,7)#declare OutVar=sqrt(14-YourVar)+3;#break
    #range(.....
Date: 15 Aug 2004 14:29:11
Message: <411fab77$1@news.povray.org>
hm, I should be reading about #switch statements. Thanks for the tip!
JWV
"Alain" <aze### [at] qwertygov> wrote in message
news:411f95d2@news.povray.org...
> > High!
> > values, such as
> > etc. etc. ?
> > Yadgar
> #switch(YourVar)
>     #range(.....
> #end
> Alain
Date: 15 Aug 2004 17:18:52
Message: <411fd33c@news.povray.org>
Yadgar wrote:
> High!
> correct terminus!)?
> values, such as
> etc. etc. ?
Try this:
#declare MinB = 0.0;
#declare MaxB = 1.5;
#declare FnB = function(x) { pow(x, 2) }
#declare MinC = 1.5;
#declare MaxC = 7.0;
#declare FnC = function(x) { sqrt(14 - x) + 3 }
#declare IntervalFn =
   function(x) {
     select(x - MinB, 0, select(x - MaxB, FnB(x), 0)) +
     select(x - MinC, 0, select(x - MaxC, FnC(x), 0))
This function will return 0 when x is below 0 or above
(or equal to) 7.
To have it return (e.g.) -x when x is below 0 and (e.g.)
-1 when it is above or equal to 7, you can use this code:
#declare MaxA = 0.0;
#declare FnA = function(x) { -x }
#declare MinD = 7.0;
#declare FnD = function(x) { -1 }
   function(x) {
     select(x - MaxA, FnA(x), 0) +
     select(x - MinC, 0, select(x - MaxC, FnC(x), 0)) +
     select(x - MinD, 0, FnD(x))
- And (despite what others have said in this thread,)
such functions can sometimes be useful in isosurfaces.
Tor Olav
http://subcube.net
http://subcube.com
