POV-Ray : Newsgroups : povray.binaries.scene-files : Lego bricks Server Time
22 May 2025 21:37:09 EDT (-0400)
  Lego bricks (Message 1 to 7 of 7)
Subject: Lego bricks
Date: 12 Jul 2004 20:06:47
Message: <40f32797@news.povray.org>
Hi there!
I'm trying to make LEGO bricks. By now, I only made 3001, 3002, 3003, 3007 and
2456 (these numbers can be found under the real bricks).
I used just a magnifying glass and a ruler to measure real bricks. Each POV-unit
is 1/16 inch.
The attached files are:
- l_macros.inc: Contains stud objects, a macro to position them, a macro to
#include the bricks, and shortcuts to rotate and translate bricks.
- pyramid.inc: a simple LEGO pyramid
- 3001.inc: brick 2x4
- 3003.inc: brick 2x2
- test.pov: the file used to make all the test renders
LMKWYT
- Nicolas Alvarez
nicoalvar0 [at] hotmail [dot] com
Download 'test.pov.txt' (1 KB) Download 'l_macros.inc.txt' (2 KB) Download 'pyramid.inc.txt' (2 KB) Download '3001.inc.txt' (1 KB) Download '3003.inc.txt' (1 KB)
Subject: Re: Lego bricks
Date: 13 Jul 2004 03:23:19
Message: <40f38de7@news.povray.org>
Hi!
if your doing this just to make the pieces, more power to you!
but if your doing it to build Lego models in pov-ray you might want to look
here:
http://www.antonraves.com/lego.html
I found that a while back during a foray into the online lego
comunity(www.lugnet.com).
Gary
Gary Blessing
Have Laptop, Will Travel.
"Nicolas Alvarez" <nic### [at] hotmailcom> wrote in message
news:40f32797@news.povray.org...
> Hi there!
and
POV-unit
> is 1/16 inch.
to
> LMKWYT
> - Nicolas Alvarez
Date: 13 Jul 2004 13:25:51
Message: <40f41b1f$1@news.povray.org>
Tip. To enable easy placement and building, you might want to consider to make
1 unit a 1x1 brick. Or use millimeters. LEGO is a european company. Bricks are
exactly 10mm in height. For all the scenes I make, I prefer to use the meter as
the base unit (Or millimeters for very small scenes or when creating a scene
from a technical drawing).
Just my two eurocents.
SomeOne
"Nicolas Alvarez" <nic### [at] hotmailcom> schreef in bericht
| Hi there!
and
POV-unit
| is 1/16 inch.
| LMKWYT
| - Nicolas Alvarez
Date: 18 Jul 2004 19:15:03
Message: <40fb0477@news.povray.org>
"Gary Blessing" <ble### [at] icefognet> wrote en el message
news:40f38de7@news.povray.org...
> Hi!
look
> here:
> community(www.lugnet.com).
> Gary
> Gary Blessing
I know LUGNET. I discovered POV-Ray there!
There is an LDRAW to POV-Ray converter called L3P (update to L2P). I think
the images in www.antonraves.com are rendered with POV-Ray using L3P (I
think)
I'm trying to make the LEGO pieces in POV-Ray because the ones made by L3P
are basically made of triangles (and because I didn't know what else to do
in POV).
- Nicolas Alvarez
Date: 18 Jul 2004 20:42:58
Message: <40fb1912@news.povray.org>
news:40fb0477@news.povray.org...
> > Hi!
> look
> > here:
> > Gary
> > Gary Blessing
So did I!
> think)
No, the lego pieces at www.antonraves.com  are modeled completely in pov,
there is another project
with the name lgeo besides Antons that is used with L3P.
> in POV).
I started with l2p and pov 3.0, and I couldn't do anything else with pov.
one day I decided that I wanted my models to apear as if they were in a real
world, so I found a way to do other thigs in pov.
Have fun!
Gary
Date: 19 Jul 2004 23:02:02
Message: <40fc8b2a@news.povray.org>
Bricks are not 10mm in height. A 1x1 brick is <5,6,5> 1/16 inches. Check
L_macros.inc. Plt and Brk give the size of two basic bricks to make
translations easy.
news:40f41b1f$1@news.povray.org...
make
Bricks are
meter as
scene
> SomeOne
Subject: Re: Lego bricks (askin' for help)
Date: 21 Jul 2004 21:19:14
Message: <40ff1612@news.povray.org>
I'm currently working on 6126. I only made the exterior part by now.
Does anyone have a real *transparent* 6126? The inner parts are not too
difficult to do but I can't see them very well.
- Nicolas Alvarez
"Nicolas Alvarez" <nic### [at] hotmailcom> wrote in the message
> Hi there!
3007 and
POD-unit
> is 1/16 inch.
to
> LMKWYT
> - Nicolas Alvarez
Download 'test.pov.txt' (2 KB) Download 'l_macros.inc.txt' (3 KB) Download '6216.inc.txt' (1 KB)
