POV-Ray : Newsgroups : povray.binaries.scene-files : Tierra (LOTW) Server Time
19 Dec 2025 14:17:02 EST (-0500)
  Tierra (LOTW) (Message 1 to 10 of 16)
Subject: Tierra (LOTW)
Date: 27 Jun 2004 17:02:18
Message: <40df35da@news.povray.org>
Finally! Sorry all for the delay...
Note: it requires Lightsys: http://www.ignorancia.org/zips/lightsys4.zip
Jaime
Download 'tierra-1.zip' (22 KB)
Subject: Re: Tierra (LOTW)
Date: 27 Jun 2004 17:41:28
Message: <40df3f08@news.povray.org>
In article <40df35da@news.povray.org> , Jaime Vives Piqueres
Great!  After rendering at a 2:1 aspect ratio I still do have one question:
Should the landscape and sky look like the one you posted April 29th?  If
so, which version did you render it with back then?
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Jun 2004 17:54:12
Message: <40df4204@news.povray.org>
   Of course no! Any resemblance between images I post and the code I
publish will be mere coincidence... :)
 > If so, which version did you render it with back then?
   I changed many things since then, so it will be imposible to render
the same image, and I've not backed up the previous versions. But it
must render landscapes very semblant to this one, as the main techniques
have not changed too much.
   My approach is surely very different from the ones by Christoph,
Nathan and Zeger, and is not very well automated nor parametrized, but
it's a very interesting project, so I hope to improve it and make it
more usable (and even include a readme file too! :).
Jaime
Date: 27 Jun 2004 18:01:33
Message: <40df43bd$1@news.povray.org>
In article <40df4204@news.povray.org> , Jaime Vives Piqueres
Ahhhhhh! :-)
Well, that is a problem for the artistically challenged like me ;-)  Still,
thank you very much for making it available!
Still, in the end, I care more about optimising the isosurface code (also I
might as well tweak parsing speed first), so I do not "care" that much about
the image itself.  Effectively, once I find time for such experiments, after
rendering the same image twenty times or more, I cannot stand it any more
anyway.  Thus, easily creating variations for the next twenty tests will
indeed be useful :-)
    Thorsten
Date: 28 Jun 2004 07:17:22
Message: <40dffe42$1@news.povray.org>
   For the next version I will create some demo scenes with different
kind of landscapes, it must help to get your own setup more quickly, by
comparision.
   I only ask you to not publically say what you are surely going to
think of me when reading my code... :)
> the image itself.
   All the optimising I know of is "keep the max_gradient low" and "use
simple functions"... :(
   I'm just borrowing from Nathan code the idea of a general seed that
governs the rest of the seeds, so it will be easier to get random
landscapes on each try.
Jaime
Date: 28 Jun 2004 07:40:02
Message: <cbovqn$5de$1@chho.imagico.de>
ROTFL
I assume Thorstens experience is writing POV-SDL is not sufficient to
actually judge much about your code (although what he thinks might still
be not suited for public citation).
What seems very inefficient to me is
   scale .001 warp{turbulence Terrain_Turb} scale 1000
   scale .01 warp{turbulence Terrain_Turb} scale 100
   scale .1 warp{turbulence Terrain_Turb} scale 10
   scale 10 warp{turbulence Terrain_Turb} scale .1
   scale 100 warp{turbulence Terrain_Turb} scale .01
   scale 1000 warp{turbulence Terrain_Turb} scale .001
since turbulence warps already introduce different scales of turbulence
(how many is influenced by 'octaves').  So by having 6 warps with a
scaling factor of 10 in between you overlay a lot of turbulences of
equal scale which is unnecessary.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 28 Jun 2004 13:31:29
Message: <40e055f1$1@news.povray.org>
   Hmmm... you got me: I didn't really understand how turbulence works.
Do you mean that I only need 1 warp, but with higher octaves, so the
turbulence will affect the pattern at higher scales?
Jaime
Date: 28 Jun 2004 13:34:16
Message: <kurtzlepirate-D31288.19341628062004@news.povray.org>
In article <40df35da@news.povray.org>,
> Jaime
> [Image]
  thanks sharing your code...
  just downloaded, just installed, trying to render and :
  >>File: i_land.inc  Line: 18
  >>// select pigments combination :
  >>#declare c-snow=ReflectiveSpectrum(RS_Fine_Snow) <---- ERROR
  >>Parse Error: Expected '( or [', ) found insted
  what i'm missing ?
  louis
Date: 28 Jun 2004 13:52:20
Message: <40e05ad4$1@news.povray.org>
   I suppose you didn't paste directly, because c-snow must be c_snow ...
   That's strange... I checked on a clean POV-Ray install that it works
"out of the box". IIRC, this error did happend to someone with the first
3.6 betas or with MegaPOV, and I think it disappeared enclosing the
spline identifier within a spline sentence, in this case:
   #declare c_snow=ReflectiveSpectrum(spline{RS_Fine_Snow})
   Are you using MegaPOV?
Jaime
Date: 29 Jun 2004 07:31:35
Message: <40e15317$1@news.povray.org>
In article <cbovqn$5de$1@chho.imagico.de> , Christoph Hormann
> ROTFL
:-)  Actually, I have not even looked further than the main file...
    Thorsten
