POV-Ray : Newsgroups : povray.binaries.scene-files : Tierra (LOTW) Server Time
9 Jun 2026 19:09:54 EDT (-0400)
  Tierra (LOTW) (Message 11 to 16 of 16)
Subject: Re: Tierra (LOTW)
Date: 29 Jun 2004 07:32:28
Message: <40e1534c$1@news.povray.org>
In article <40dffe42$1@news.povray.org> , Jaime Vives Piqueres
<jai### [at] ignoranciaorg>  wrote:
>> Still, in the end, I care more about optimising the isosurface code (also I
>> might as well tweak parsing speed first), so I do not "care" that much about
>> the image itself.
>    All the optimising I know of is "keep the max_gradient low" and "use
> simple functions"... :(
Well, there is more to be done about the rest in the POV-Ray source code for
me :-)
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Jun 2004 07:59:52
Message: <40e159b8$1@news.povray.org>
In article <40df4204@news.povray.org> , Jaime Vives Piqueres
>> Great!  After rendering at a 2:1 aspect ratio I still do have one question:
>> Should the landscape and sky look like the one you posted April 29th?
>    Of course no! Any resemblance between images I post and the code I
> publish will be mere coincidence... :)
OK, maybe I should start picking on the "unrealistic" parts of the images
your scene generates: I think the general landscape looks really good and
sufficiently detailed (currently rendering one at 3600*2400 on my system at
work), but the clouds suffer from being colored to heavily when compared to
a "real" photograph.  Just compare the cloud colors with those used in your
scene with real clouds (taken both at about 14:00 a few days prior to summer
solstice at about 48 degrees latitude) to your scene's clouds* -
<http://mac.povray.org/new/clouds.jpg>.
As you can see, the bottom colors of the clouds are far to heavy in
particular for the given amount of sunlight.  Also, the atmosphere is a bit
too dense (and too dark at the horizon) for a good weather mountain day.  I
think you you tweak that a bit, your images if rendered at appropriate
resolutions cannot be told apart from photographs!  You could even get
prints of them...
    Thorsten
* The bottom one.  Note that all three image slices had previously been
color corrected on their own using the Photoshop "auto color" function,
which actually made the colors of your scene much more realistic, too :-)
Date: 29 Jun 2004 08:15:02
Message: <cbrm7v$4go$1@chho.imagico.de>
Jaime Vives Piqueres wrote:
>   Hmmm... you got me: I didn't really understand how turbulence works.
> Do you mean that I only need 1 warp, but with higher octaves, so the
> turbulence will affect the pattern at higher scales?
Not necessarily only one warp (you only have limited control over the
intensity of the different octaves with omega and lambda) but definitely
6 are more than necessary.  If you really want to use many warps like
this it would be a good idea to use lower octaves count than default for
them.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 29 Jun 2004 09:07:48
Message: <40e169a4$1@news.povray.org>
> me :-)
   I hope so, because I'm developing an addiction to isosurfaces...
Jaime
Date: 30 Jun 2004 13:03:03
Message: <kurtzlepirate-99147D.19030330062004@news.povray.org>
In article <40e05ad4$1@news.povray.org>,
> Kurts wrote:
> >   >>#declare c-snow=ReflectiveSpectrum(RS_Fine_Snow) <---- ERROR
>    I suppose you didn't paste directly, because c-snow must be c_snow ...
  yes... :-)
> >   >>Parse Error: Expected '( or [', ) found insted
>    That's strange... I checked on a clean POV-Ray install that it works
> "out of the box". IIRC, this error did happend to someone with the first
> 3.6 betas or with MegaPOV, and I think it disappeared enclosing the
> spline identifier within a spline sentence, in this case:
>    #declare c_snow=ReflectiveSpectrum(spline{RS_Fine_Snow})
>    Are you using MegaPOV?
  yes... :-))
> Jaime
  thanks for all !
  louis
Date: 3 Jul 2004 11:47:29
Message: <40e6d511$1@news.povray.org>
   Yes, you are right about the clouds. I think it's due to my cheap sun
model based on altitude only, wich gives too warm colors (I have to
revise it). For the moment. you can correct it somehow by changing the
white point of the color system to a lower temperature.
   I added also a parameter to control clouds brightness, as increassing
it also helps a bit to get more white clouds.
   The "atmosphere" density depends on the turbidity of the skilight
model, but is also controlable with the Haze_Distance parameter.
   Yes, but it doesn't works always. Sometimes it gives wierd colors,
other it darkens the image too much, at least with Gimp auto-levels.
   Thanks for the comments!
Jaime
