POV-Ray : Newsgroups : povray.binaries.scene-files : Cloud code Server Time
29 Sep 2024 08:15:40 EDT (-0400)
  Cloud code (Message 1 to 1 of 1)
Subject: Cloud code
Date: 13 Jun 2004 05:20:42
Message: <40cc1c6a@news.povray.org>
#version 3.5;
global_settings
  assumed_gamma 1.0
  max_trace_level 120
  noise_generator 3  // was 3
   radiosity{
   pretrace_start 0.08
   pretrace_end   0.01
   count 10 // 10
   nearest_count 5
   error_bound 0.4
   recursion_limit 1
   low_error_factor 0.5
   gray_threshold 0
   minimum_reuse 0.015
   brightness .325
   adc_bailout 0.006
   normal on
     media on
camera{
  location  <0.0, 0.5 , -25> //-25
  //location  <0.0, 65 , 0>
  direction z   //1.5*z
  right     image_width/image_height*x
  look_at   z*10000//<0.0, 1,  0.0>
  //look_at 0
  rotate y*-5
  angle 50//32
  translate y*1500
sky_sphere{
   gradient y
   color_map { [0.0 SteelBlue+((White)/2)][0.75 SteelBlue*.75 ]}
    rotate x*-90
light_source{<0,100000,0>
color rgb <1,.6,.125> *.875
rotate z*25 rotate x*50   // was z*25 try 30
media_interaction on media_attenuation off
  #declare Rad = 8000;
    #macro SkyShell(minAlt, maxAlt, Int, Scle, Rot)
    difference {
     sphere {< 0, 0, 0>, 1 scale (Rad + maxAlt)}
     sphere {< 0, 0, 0>, 1 scale (Rad + minAlt)}
     texture {pigment {color rgbf 1}finish {ambient 0 diffuse 1}}
///****************Finish added???????????????????
     interior {Int}
       scale Scle
       rotate Rot
       translate -y*Rad
     hollow
  SkyShell(
    1000,1550, // high cloud
    interior {
      media {
        samples 5,10
        intervals 2
        scattering { 2, rgb <0.0075, 0.007, 0.0065>*.65 } //colour of base
of clouds multipyler controls darkness, smaller lighter
        density {
          wrinkles
            warp{turbulence 0.4 lambda 3 omega 0.6}
              scale Rad*.15
          color_map {
                  [0 rgb 0]
                  [0.125 rgb 0]
                  [0.38 rgb 0.5*.5]
                  [0.75 rgb 0.8*.5]
                  [1 rgb <1,1,0>*.5]
          }// cmap
          scale 1
        } //density
      } //media
    } //int
      <1,1,1>*3
      <-9,124,0>
 SkyShell(    //low dark cloud
    300,900
    interior {
      media {  method 3
        samples 5,10
        intervals 2
        scattering { 2, rgb <0.0075*1.75, 0.00875*1.75, 0.007*1.75>*.75 }
        density {
          wrinkles
            warp { turbulence 0.5 lambda 2.3 omega 0.475 }
              scale Rad*.15
          color_map {
                  [0 rgb 0]
                  [0.4 rgb 0]
                  [0.5 rgb 0.75/3]
                  [0.95 rgb 1.5/3]
                  [1 rgb 1]
          }// cmap
          turbulence .5
          scale <2,.75,1>*.7
        } //density
      } //media
    } //int
    <-1.75,1.75,1.75>
    <45,54,0>
 SkyShell(    //low scudding dark cloud
    100,295
    interior {
      media {  method 3
        samples 5,10
        intervals 2
        scattering { 2, rgb <0.0075*1.75, 0.00875*1.75, 0.007*1.75>*2 }
        //scattering { 2, rgb <0.0075*1.75, 0.00875*1.75,
0.007*1.75>*1.675 }
        density {
          wrinkles
              scale Rad*.15
          color_map {
                  [0 rgb 0]
                  [0.65 rgb 0]
                  [0.55 rgb 0.75/3]
                  [0.95 rgb 1.5/3]
                  [1 rgb 1]
          }// cmap
          scale <2,.75,1>*.7
        } //density
      } //media
    } //int
    <3,1.75,1.75>
    <-46.5,-43,0>
