POV-Ray : Newsgroups : povray.binaries.scene-files : Simulated orbits. Server Time
23 May 2025 03:24:02 EDT (-0400)
  Simulated orbits. (Message 1 to 2 of 2)
Subject: Simulated orbits.
Date: 17 Mar 2004 12:40:02
Message: <40588d72$1@news.povray.org>
See "Crazy ovals" discussion in povray.binaries.animations
Note that the time scale for the simulated ellipse was determined
empirically.  If you change the initial velocity or
Download 'us-ascii' (2 KB)
Subject: Re: Simulated orbits.
Date: 22 Mar 2004 18:29:09
Message: <405f76c5$1@news.povray.org>
> Okay, last evening I managed to get a couple of simple macros together
> that work well to remove the cumulative errors.  Since the equation of
> the orbital angle (as a function of time) does not have a
> straightforward solution, it is solved in an iterative (convergent) manner.
> The macro allows specifying a MAXERR (measured as the correction on the
> last iteration since the actual solution isn't know and it can't
> determine *real* error).
> I'd be curious if anyone finds this useful, if you do, please drop me a
> line (just remove ".nospam").
> Also see p.b.animation for an animation using an earlier version of this
> scene (just a sun/earth).
Well I feel stupid; I somehow posted incompatible/broken scene files
previously (I canceled that post).  Attached are the working versions,
both dated today marked "VERSION 1.1".
D'oh
Download 'us-ascii' (3 KB) Download 'us-ascii' (2 KB)
