POV-Ray : Newsgroups : povray.binaries.scene-files : How do you make a light source glow using radiosity ... this doesn't work Server Time
27 Mar 2026 17:30:23 EDT (-0400)
  How do you make a light source glow using radiosity ... this doesn't work (Message 1 to 5 of 5)
Subject: How do you make a light source glow using radiosity ... this doesn't work
Date: 28 Apr 2003 19:00:19
Message: <3eadb283$1@news.povray.org>
global_settings{
  assumed_gamma 1.0
  ambient_light 0
    radiosity
      normal on
      pretrace_start 0.08
      pretrace_end   0.01
      count 100
      nearest_count 10
      error_bound 0.02
      recursion_limit 1
      low_error_factor 0.2
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1.0
      adc_bailout 0.01/2
        location <5, 5, 5> // standard angle
        look_at <0, 0, 0>   // standard center shot
  light_source {
    <0,0,0>
    color rgb <1,1,1>
    looks_like {
      sphere { <0,0,0>, 1 pigment { rgb<1,1,1> }  finish {ambient 0 diffuse
1}}
Edward Leibnitz
edw### [at] verizonnet
Subject: Re: How do you make a light source glow using radiosity ... this doesn't work - GOT IT
Date: 28 Apr 2003 19:53:21
Message: <3eadbef1$1@news.povray.org>
never - mind got it ......
tweaked some settings etc .....
done
thanks
"Edward Leibnitz" <lei### [at] rcncom> wrote in message
news:3eadb283$1@news.povray.org...
> global_settings{
>   assumed_gamma 1.0
>   ambient_light 0
>     radiosity
>       normal on
>       pretrace_start 0.08
>       pretrace_end   0.01
>       count 100
>       nearest_count 10
>       error_bound 0.02
>       recursion_limit 1
>       gray_threshold 0.0
>       minimum_reuse 0.015
>       brightness 1.0
>       adc_bailout 0.01/2
> camera {
>   light_source {
>     <0,0,0>
>     color rgb <1,1,1>
>     looks_like {
diffuse
> 1}}
> Edward Leibnitz
Date: 2 Apr 2004 16:00:04
Message: <406dd454$1@news.povray.org>
IYou cannot really do "glows" like this but...
I removed "ambient_light 0" and the sphere appears !
then
I made some changes, add a plane to see the "light" spread on a floor...
Try this :
global_settings{
    assumed_gamma 1.0
    //ambient_light 0
      radiosity
        normal on
        pretrace_start 0.08
        pretrace_end   0.01
        count 100
        nearest_count 10
        error_bound 0.02
        recursion_limit 1
        gray_threshold 0.0
        minimum_reuse 0.015
        brightness 1.0
        adc_bailout 0.01/2
plane {y, -1.0 pigment {rgb 0.8}}
  location <5, 5, 5>
  look_at <0, 0, 0>
union {
  light_source {0.0, 1.0}
   sphere { <0,0,0>, 1 pigment { rgb 1.0 }  finish {ambient 1.0 diffuse
0.0}}
Subject: Re: How do you make a light source glow using radiosity ... thisdoesn't work - GOT IT
Date: 2 Apr 2004 16:31:48
Message: <406ddbc4$1@news.povray.org>
LightBeam nous apporta ses lumieres ainsi en ce 2004/04/02 16:01... :
> then
> Try this :
> global_settings{
>    assumed_gamma 1.0
>    //ambient_light 0
>      radiosity
>        normal on
>        pretrace_start 0.08
>        pretrace_end   0.01
>        count 100
>        nearest_count 10
>        error_bound 0.02
>        recursion_limit 1
>        gray_threshold 0.0
>        minimum_reuse 0.015
>        brightness 1.0
>        adc_bailout 0.01/2
> camera {
>  location <5, 5, 5>
>  look_at <0, 0, 0>
> union {
> 0.0}}
Remove the light and there is absolutely NO difference. The light is at
the center of the opaque sphere.
Subject: Re: How do you make a light source glow using radiosity ... thisdoesn'twork - GOT IT
Date: 3 Apr 2004 13:19:20
Message: <406f0028$1@news.povray.org>
> Alain
I know, but I forgot it !
