POV-Ray : Newsgroups : povray.binaries.scene-files : SISray Server Time
18 Apr 2026 15:47:41 EDT (-0400)
  SISray (Message 1 to 1 of 1)
Subject: SISray
Date: 2 Feb 2003 11:40:23
Message: <3e3d49f7@news.povray.org>
Here is what I have so far in my SISray code used to generate the images in
p.b.i. You'll have to supply your own depthmap. The Ptrn() function is
completely arbitrary. The example in p.b.i. is perhaps not the best.
A few things to note here:
    If you need wider eyeseparation try increasing the dpi variable.
    There are two variables, depthFac and depthOffset, that are used
        scale the 0-1 range of your depthmap and place it in the place
        it within the range. These are really broken at the moment and
        should be set to 1 and 0 respectively. That's not how they are
        set in this file but that's so you can see the problem I'm having.
    If you make the SLR() function return all 1 or -1 then you can make
        the pattern skew to one side or the other. Those two 'depth'
        variables I just mentioned should behave properly then, but, you
        will also have to greatly increase the LinkFac variable to avoid
        garbage at the side. This also dramatically slows the rendertime.
    The depthmap is declared as a pigment function called H(). 1-H() creates
        the standard wall-eyed version while H() alone generates the
        cross-eyed version. This seems backwards to me, but I don't question
        results.
    For best results, limit your depthmap to the 0-0.5 or possibly 0.75
        range.
    SISray generates it's own include file so make write permissions are on
        for the current directory.
I'm sure there are lots of optimizations for this code. If anyone can solve my
depthOffset problems or wants to make and share any changes, that would make me
very happy. If not, then just have fun. I'm happy to answer any questions I'm
able.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Download 'SISray.zip' (2 KB)
