POV-Ray : Newsgroups : povray.binaries.scene-files : Cristal.inc : cristals (as in LiquidGlass) Server Time
29 Sep 2024 18:14:58 EDT (-0400)
  Cristal.inc : cristals (as in LiquidGlass) (Message 1 to 7 of 7)
Subject: Cristal.inc : cristals (as in LiquidGlass)
Date: 13 Jun 2002 11:48:36
Message: <3d08bed4$1@news.povray.org>
Ok
min_sides: the minimum number of sides your cristal will have
max_sides: the maximum;
diam: the edges are on a circle of diameter diam
height: the heigth of the crown
var: the variance of the points
top: the absolute topmost points
rand_seed... welll
ex:
mesh_cristal(4,7, 1, 3, 0.1, 4, s)
produces a cristal of 4 to 7 faces, contained in a cylinder of diameter 1,
that have its pointy end starting at 3 +- 0.1, and culminates at 4.
Same with the two-ended version
best,
    S.
#macro mesh_cristal(min_sides,max_sides,diam, height,var,top,rand_seed)
 #local nb_sides = min_sides+floor (0.5 +
(max_sides-min_sides)*rand(rand_seed) );
 #declare angles = array [ nb_sides ]; // angles
 #declare bases  = array [ nb_sides ];
 #declare mi_hauteurs = array [ nb_sides ];
 #declare sommets = array [ nb_sides] ;
 // some random values
 #local i=0;
 #while (i<nb_sides)
  #declare angles[i]=rand(rand_seed) * 360;
  #declare i=i+1;
 // sort them
 #local i=0;
 #while (i < nb_sides - 1 )
  #local j=i+1;
  #while (j < nb_sides )
   #if (angles[i]>angles[j])
    #local temp = angles[i];
    #declare angles[i]=angles[j];
    #declare angles[j]=temp;
   #end //if
   #declare j=j+1;
  #end // while (j
  #declare i=i+1;
 #end // while (i
 #local i=0;
 #while (i<nb_sides)
  #declare bases[i] = vrotate( < 0,0,diam>, <0,angles[i],0 >);
  #declare mi_hauteurs[i]=bases[i]+<0,height+rand(rand_seed)*var,0>;
  #declare i=i+1;
 mesh
   #local i=0;
   #while (i<nb_sides)
    triangle { bases[i],mi_hauteurs[i],mi_hauteurs[mod(i+1,nb_sides)] }
    triangle { bases[i],bases[mod(i+1,nb_sides)],
    #declare i=i+1;
   #declare sommets = bases ;
   #local random_vect = vrotate(<0,0,10>,rand(rand_seed)*360); // some
vector in the x-z plane
   #local random_angle = rand(rand_seed)*15;
   #local i=0;
   #while (i<nb_sides)
    #declare sommets[i]=vaxis_rotate(sommets[i]/2,random_vect,random_angle)
+ <0,top,0>;
    #declare i=i+1;
   #local i=0;
   #while (i<nb_sides)
    triangle { sommets[i],mi_hauteurs[i],mi_hauteurs[mod(i+1,nb_sides)] }
    triangle { sommets[i],sommets[mod(i+1,nb_sides)],
    #declare i=i+1;
   #local i=0;
   #while (i<nb_sides)
    triangle { bases[0],bases[i],bases[mod(i+1,nb_sides)] }
    triangle { sommets[0],sommets[i],sommets[mod(i+1,nb_sides)] }
    #declare i=i+1;
  } // mesh
#end // macro
#macro two_ended_mesh_cristal(min_sides,max_sides,diam,
 #declare mi_profondeurs = array[ nb_sides ];
 #declare sommets = array [ nb_sides ] ;
 #declare fonds   = array [ nb_sides ];
 #local i=0;
 #while (i<nb_sides)
  #declare i=i+1;
 // sort them
 #local i=0;
  #local j=i+1;
   #end //if
   #declare j=j+1;
  #end // while (j
  #declare i=i+1;
 #end // while (i
 #local i=0;
 #while (i<nb_sides)
  #declare mi_profondeurs[i]=bases[i]-<0,height+rand(rand_seed)*var,0>;
  #declare i=i+1;
 mesh
   #local i=0;
   #while (i<nb_sides)
    triangle {
mi_profondeurs[i],mi_hauteurs[i],mi_hauteurs[mod(i+1,nb_sides)] }
    triangle { mi_profondeurs[i],mi_profondeurs[mod(i+1,nb_sides)],
    #declare i=i+1;
   // sommets
   #local i=0;
   #while (i<nb_sides)
+ <0,top,0>;
    #declare i=i+1;
   #local i=0;
   #while (i<nb_sides)
    #local i=i+1;
   #local i=0;
   #while (i<nb_sides)
    #local i=i+1;
   // fonds
   #declare fonds = bases ;
   #local i=0;
   #while (i<nb_sides)
    #declare fonds[i]=vaxis_rotate(fonds[i]/2,random_vect,random_angle) -
<0,top,0>;
    #local i=i+1;
   #local i=0;
   #while (i<nb_sides)
    triangle {
fonds[i],mi_profondeurs[i],mi_profondeurs[mod(i+1,nb_sides)] }
    triangle { fonds[i],mi_profondeurs[mod(i+1,nb_sides)],
fonds[mod(i+1,nb_sides)] }
    #local i=i+1;
   #local i=0;
   #while (i<nb_sides)
    triangle { fonds[0],fonds[i],fonds[mod(i+1,nb_sides)] }
    #local i=i+1;
  } // mesh
#end // macro
Subject: Re: Cristal.inc : cristals (as in LiquidGlass)
Date: 13 Jun 2002 13:35:05
Message: <3D08D7C2.2020902@bellsouth.net>
That seems a little complex for li'l ol' me...I was hoping for a CSG
^_^;
Tim Cook
Version: 3.12
Date: 13 Jun 2002 15:00:34
Message: <3d08ebd2@news.povray.org>
"Timothy R. Cook" <z99### [at] bellsouthnet> wrote in message
news:3D0### [at] bellsouthnet...
ah ah ah
well... uh.... you can toy with it anyway :)
I used to have a csg-based version but it ate up lots of
memory and was much slower than this mesh-based
version. In another scence, there are like, say, 100 000
cristals... every K you save starts to be important :)
Best,
    S.
> ^_^;
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 13 Jun 2002 18:30:06
Message: <3d091cee$1@news.povray.org>
Could you post a sample .pov file?
thanks,
.d
"Steven Pigeon" <pig### [at] iroumontrealca> wrote in message
news:3d08ebd2@news.povray.org...
> ah ah ah
> Best,
>     S.
> > ^_^;
> > Tim Cook
> > Version: 3.12
Date: 17 Jun 2002 13:41:07
Message: <3d0e1f33@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3d091cee$1@news.povray.org...
Nope. Absolutely not.
But of course!!!
#include "Colors.inc"
#include "Glass.inc"
#include "cristals.inc"
#declare PHOTONS=1;
global_settings
  ambient_light 0.1
  assumed_gamma 1
  radiosity
    recursion_limit 3
    pretrace_start 0.08
    pretrace_end   0.01
    count 350
    nearest_count 5
    error_bound 0.2
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 1/1024 // 0.015
    brightness 1
    adc_bailout 0.01/2
  photons
    #if (PHOTONS=1)
     max_trace_level 5
    #else
     max_trace_level 0
    count 2000000
    spacing 0.005
    gather 40,50
    autostop 0
    jitter 0
camera
  location <5,15,-10>      // <5,15,-10>
  look_at <0,5,0>
#if (PHOTONS=0)
 light_source { <10,10,10> color White }
light_source
  <0,5,0> color White*5
  //fade_power 2
  //fade_distance 4
  #if (PHOTONS=1)
   photons
     refraction on
     reflection on
light_source
  <10,10,10>
  color White
  spotlight
  point_at <0,7,0>
  radius 2
  falloff 3
  #if (PHOTONS=1)
   photons
     refraction on
     reflection on
plane { y, 0 pigment { rgb <0.5,0.5,1.0> } finish { reflection 0.1 } photons
{ collect on } }
#macro CRISTAL()
  texture { pigment { color rgbf<0.7, 0.7, 1, 0.8> } } // slightly bluish
  interior
    ior 2.5
    dispersion 1.10
    dispersion_samples 20
  finish
    ambient 0
    diffuse 0
    reflection 0.25
    phong 0.3
    phong_size 60
  #if (PHOTONS=1)
   photons
     target
     reflection on
     refraction on
     collect on
#end // macro CRISTAL
#declare rand_seed = seed(1);
#declare ECHELLE = 40;
blob
  #local i=0;
  #while (i<200)
   #local _x = (rand(rand_seed)-rand(rand_seed))*ECHELLE;
   #local _z = (rand(rand_seed)-rand(rand_seed))*ECHELLE;
   #local _y = log( _x * _x + _z * _z );
   #local _d = 1 + sqrt( _x * _x + _z * _z )/5.5;
   //component _d, _d, <_x,_y,_z>
   sphere { <_x,_y,_z> , _d, _d }
   #local i=i+1;
  threshold 0.5
  //pigment { Yellow }
  //texture { T_Glass2 }
  CRISTAL()
  normal { wrinkles }
  normal { ripples scale 0.5 }
object
  two_ended_mesh_cristal(5,5,1, 2,1,4,seed(2))
  translate <0, 5, 0>
  //texture { pigment { Green }  }
  CRISTAL()
Date: 30 Jul 2002 07:56:59
Message: <3d467f0b@news.povray.org>
> But of course!!!
Thank you, I render it now, but it is verrry slow :-) Even with PHOTONS=0.
BTW, on this side of the pond, in English we write crystals, in French we
write cristaux...
Regards.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 12 Aug 2002 16:57:28
Message: <3d582138$1@news.povray.org>
"Philippe Lhoste" <Phi### [at] GMXnet> wrote in message
news:3d467f0b@news.povray.org...
> > But of course!!!
The glass texture is very slow as soon as you specify refraction /
diffraction.
Something to optimize in new versions of pov ?
> write cristaux...
    S.
> Regards.
