POV-Ray : Newsgroups : povray.binaries.scene-files : Views macro Server Time
20 Dec 2025 03:26:49 EST (-0500)
  Views macro (Message 1 to 4 of 4)
Subject: Views macro
Date: 20 Sep 2001 02:48:59
Message: <3ba9915b@news.povray.org>
here is an include file for pov3.5 to render an object with 4 views as in a
modeler
to use it you have to include "views.inc" , declare your object and call the
macro Views (you don't need camera or lights, but the object must have a
texture)
Views (my_object,view1,view2,view3,view4,same_scale,bounding_box,samples)
parameters :
-my_object : the object you want to visualize
-view1 to view4 : the four views, for each you choose among "front", "back",
"top", "bottom", "left", "right", "perspective"
-same_scale : use the same scale for the 4 views if yes, and if no use
different scale
-bounding_box : render the bounding box if yes
-samples : if 0 use the min/max extent from povray, else the macro attempts
to find a better bounding using the trace function (sometimes the bounding
of pov is not very good for csg object), don t use a too large number anyway
, the algorithm is not very good (around 30 should be ok)
ex: Views(obj,"front","left","top","perspective",yes,no,0)
M
Download 'views.inc.txt' (10 KB)
Subject: Re: Views macro
Date: 20 Sep 2001 04:36:06
Message: <3ba9aa76@news.povray.org>
Thanks. Will take a look at it.
- Nekar
"Mael" <mae### [at] hotmailcom> wrote in message news:3ba9915b@news.povray.org...
> modeler
> texture)
> parameters :
> different scale
> M
Date: 3 Oct 2001 14:47:44
Message: <3bbb5d50$1@news.povray.org>
Can I suggest you to add a parameter to globally control the illumination
(which it's a bit dim now).
Nice work. I find it usefull.
Jonathan.
"Mael" <mae### [at] hotmailcom> ha scritto nel messaggio
a
> modeler
the
> texture)
> parameters :
"back",
> different scale
attempts
anyway
> M
Date: 7 Dec 2001 00:42:39
Message: <3C10575B.9558319B@saber.net>
Hi, Mael,
[snip]
> here is an include file for pov3.5 to render an object with 4 views as > in a
modeler
[snip]
Thank you,  I will try it out and post a sample (next week?)
Blessings,
         Brendan
Michael Brendan Hurley           ShadowDancerEnterprizes, LTD.
POV Site: http://www.geocities.com/mbrendanh/indxx01.html
Family:   http://www.saber.net/~mbhcgc/index.shtml
mbh### [at] sabernet
