POV-Ray : Newsgroups : povray.binaries.scene-files : ior.pov Server Time
10 Apr 2026 03:23:37 EDT (-0400)
  ior.pov (Message 1 to 9 of 9)
Subject: ior.pov
Date: 22 Jan 2002 11:43:03
Message: <3C4D967A.1A0CB16D@spiritone.com>
This file shows the path of light as it passes through mediums with
different index of refractions. There are three lenses that I've written
into the file, and the variables mu1 and mu2 are the index of
refractions for the "open area" and the lens.
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Download 'us-ascii' (4 KB)
Subject: Re: ior.pov
Date: 22 Jan 2002 12:41:27
Message: <3c4da447$1@news.povray.org>
"Josh English" <eng### [at] spiritonecom> wrote
> // Persistence of Vision Ray Tracer Scene Description File
> // File: ?.pov
> // Vers: 3.5
> // Desc: Basic Scene Example
> // Date: mm/dd/yy
> // Auth: ?
> #version 3.5;
> #include "colors.inc"
> #include "math.mcr"
       !!! What is "math.mcr"???
Date: 22 Jan 2002 15:50:36
Message: <3c4dd09c$1@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3c4da447$1@news.povray.org...
> > // File: ?.pov
> > // Vers: 3.5
> > // Date: mm/dd/yy
> > // Auth: ?
> > #version 3.5;
> > #include "math.mcr"
    Ah... math.inc... and a few more changes...
    I'm anxious for the Beta period to be over....
Date: 24 Mar 2002 21:50:54
Message: <3c9e908e@news.povray.org>
Dear Josh,
 I've been fascinated by your idea of having two IOR values in the lens.
I've also been trying to catch your implemetation of this scene files in the
binaries.images. Well, I could not find it so far. I'll appreciate it if you
could possibly where I could find the image.
One more favor to ask of you:
 I seem to have minor errors when I run your scene file IOR.POV.
Is there  any clues to this?
Thank you again,
Jong
"Josh English" <eng### [at] spiritonecom> wrote in message
news:3C4D967A.1A0CB16D@spiritone.com...
> Josh English
> // File: ?.pov
> // Vers: 3.5
> // Date: mm/dd/yy
> // Auth: ?
> #version 3.5;
> #include "math.mcr"
> global_settings {
>   assumed_gamma 1.0
> camera {
>   location  <-0.0, 7.5, -0.001>
>   direction 1*z
>   right     x*image_width/image_height
>   look_at   <0.0, 0.0,  0.0>
> sky_sphere {
>   pigment {
>     gradient y
>     color_map {
>       [0.0 rgb <0.6,0.7,1.0>]
>       [0.7 rgb <0.0,0.1,0.8>]
> light_source {
>   <0, 0, 0>            // light's position (translated below)
>   color rgb <1, 1, 1>  // light's color
>   translate <-30, 30, -30>
> #macro Snell(Vi,N,m1,m2)
>   #local ang = VAng(Vi,N);
>   #if ((ang = 0 ) | (ang = 180))
>      #local t3 = vnormalize(Vi);
>   #else
>     #local uv = vnormalize(vcross(Vi,N));
>     #debug vstr(3,uv," : ",0,1)
>     #local sinr = (m1/m2)*sin(ang);
>     #debug concat ("Angle of incoming ray is " , str(degrees(ang),4,4))
>     #debug concat ("Sine of Refracted ray is " , str(sinr,4,4))
>     #if (abs(sinr) > 1)
>        #debug "Critical Angle?"
>        #local t3 = <0,0,0>;
>     #else
>       #local ang2 = degrees(asin(sinr));
>       #debug concat ("Angle of Refracted ray is " , str(ang2,4,4))
>       #local t3 = vaxis_rotate(vnormalize(-N),uv,ang2);
>       //sphere { t3 0.06 pigment { blue 1 } }
>     #end
>   #end
>   t3
> #end
> plane {
>   y, -1
>   pigment { color rgb <0.7,0.5,0.3> }
> // Three different Lens shapes for testing
> #declare Lens0 =
>   box { <-1,-1,-4> <1,1,4>
>         pigment { rgbt <0.5,0.5,1,0.6> }
>         rotate 15*y
>         translate 1*x }
> #declare Lens2 =
>   difference {
>   cylinder { <7,-1,0> <7,1,0> 9  }
>   cylinder { <-7,-1.1,0> <-7,1.1,0> 8 }
>   rotate 15*y}
> #declare Lens1 =
> difference {
>   sphere { <3,0,0> 4 }
>   sphere { <2,0,0> 2.5 }
>   box { <1,-5,-5> <8,5,5> }
>   box { <-2,0.5,-5> <3,5.1,5> }
>   pigment { rgbt <0.5,0.5,1,0.7> } }
> #declare Lens = object { Lens0 translate <0,0,0.1> }
> object { Lens }
> #declare CrownGlass = <1.52,1.526,1.531>;
> #declare mu1 = 1; // IOR value for "open area"
> #declare mu2 = 1.9; // IOR value for lens
> #declare zp = -2;
> #while (zp < 2 )
>   #declare light_start = <-10,0,zp>;
>   #declare light_direction = <1,0,0>;
>   #declare norm = <0,0,0>;
>   #declare p1 = trace(Lens,light_start,light_direction,norm);
>   #declare miss = VNull(norm);
>   #if (miss)
>       #debug "Missed"
>       cylinder { light_start, (light_start + light_direction*10) 0.05
>                  pigment { red 1 } }
>   #else
>       cylinder { light_start, p1 0.05 pigment { rgb 1 } }
>       #declare Refr = Snell(-light_direction,norm,mu1,mu2);
>       #if (VNull(Refr))
>         #debug "Problem"
>       #else
>         #declare p2 = trace(Lens,p1,Refr,norm);
>         #declare exit = VNull(norm);
>         #if (exit)
>             #debug "Trapped"
>             cylinder { p1, p1 + Refr * 2 0.05 pigment { red 1 } }
>         #else
>             #declare Refr2 = Snell(-Refr,-norm,mu2,mu1);
>             #if (VNull(Refr2))
>             #else
>               cylinder { p1, p2 0.05 pigment { rgb <0,1,0> } }
>               cylinder { p2, p2 + Refr2 * 6, 0.05 pigment { rgb 1 } }
>             #end
>         #end
>       #end
>   #end
>   #declare zp = zp+0.5;
> #end
Date: 29 Mar 2002 18:36:14
Message: <3CA4F9C6.DD3820D1@spiritone.com>
The scene requires POV-Ray 3.5, I don't know if it will work with
MegaPov, and it won't work with POV-Ray 3.1, since it requires the
trace() function. Also, it calls for "math.mcr" and this might need to
be changed to "math.inc" in your implementaion, like Bill had to do. Let
me know what the errors are and I will try to help.
I didn't post an image using this technique, and I didn't even post an
example image from this file.
Josh English
Jong wrote:
> Dear Josh,
> Thank you again,
> Jong
Date: 31 Mar 2002 22:45:20
Message: <3ca7d7d0$1@news.povray.org>
Dear Josh,
 I really thank you for your help. This morning, I reinstalled POV-Ray 3.5
version 15. As per your suggestion, the math.mcr was changed to math.inc.
When it was executed, it says
     Parse Error: Cannot assing uninitialized identifier.
at the line(with yellow background)
Since I have not much knowledge about POV programming, I have hard time
finishing the execution.
I'll be more than happy if you could possibly help me with this.
Thank you again,
Jong
news:3CA4F9C6.DD3820D1@spiritone.com...
> Josh English
Date: 1 Apr 2002 18:59:18
Message: <3ca8f456@news.povray.org>
"Jong" <jjk### [at] mmewhaackr> wrote in message
news:3ca7d7d0$1@news.povray.org...
> Dear Josh,
I'm not Josh but I think I know what change is needed, just not absolutely
sure.
In the ior.pov file, try changing VNull to VZero and VAng to VAngle. I get a
render but I don't know what to expect. Logic tells me this is probably the
answer though.
bob h
Date: 2 Apr 2002 05:55:32
Message: <3ca98e24@news.povray.org>
Dear Bob,
 I really appreciate your help. The ior.pov file was changed as per your
suggestions, changing VNull to VZero and VAng to VAngle.
And it worked fine. I've got an image rendered quite quick.
Thank you again.
Jong
"bob h" <omn### [at] charternet> wrote in message
news:3ca8f456@news.povray.org...
a
the
> answer though.
> bob h
Date: 3 Apr 2002 12:16:21
Message: <3cab38e5@news.povray.org>
news:3ca98e24@news.povray.org...
> Dear Bob,
> Thank you again.
Glad to have helped, in my usual haphazard sort of way.
bob h
