POV-Ray : Newsgroups : povray.binaries.scene-files : Platonic solids Server Time
29 Sep 2024 20:14:46 EDT (-0400)
  Platonic solids (Message 1 to 10 of 13)
Subject: Platonic solids
Date: 14 Jan 2002 00:50:25
Message: <3C42719F.9BD9A7FF@sw-tech.com>
As mentioned in p.b.i...
Download 'us-ascii' (13 KB) Download 'soliddemo.pov.txt' (4 KB)
Subject: Re: Platonic solids
Date: 14 Jan 2002 00:52:31
Message: <3C42721D.934CED4D@sw-tech.com>
Nice.  It inlines some plain text attachments but not others.  Sorry.  I
will keep kicking Netscape.
Deaken
Date: 14 Jan 2002 01:59:20
Message: <3c4281c8@news.povray.org>
Hi Deaken,
first of all, good work so far.
>// Bugs: The math is slightly off on both the Dodecahedron and the
>//       Icosahedron.  I am still tracking this down, I'm afraid.
As i read this i thought my source could be helpful to you, feel free
to use it in your include-file if you like it.
Some explanations:
r is the radius of the outer bounding sphere of the icosahedron
h,a,b,c,d are some precalculated constants.
P1 - P12 are the vertexes of the Icosahedron
P1 is the top vertex
P2-P6 is the upper pentagon-shaped layer
P7 is the bottom vertex
P8-P12 is the lower pentagon-shaped layer
I hope you find it useful.
Greetings
    Thies Heidecke
// Icosahedron - Vertex - Definitions :
#declare r     = 1.0;
#declare sqrt5 = sqrt(5.0);
#declare h     = 1.0/sqrt5;
#declare a     = 2.0*sqrt((5.0+sqrt5)/40.0);
#declare b     = 2.0*sqrt((5.0-sqrt5)/40.0);
#declare c     = (5.0-sqrt5)/10.0;
#declare d     = (5.0+sqrt5)/10.0;
#declare P0    = < 0.0,  0.0,      0.0>;
#declare P1    = < 0.0,    r,      0.0>;
#declare P2    = < 0.0,  h*r,  2.0*h*r>;
#declare P3    = < a*r,  h*r,      c*r>;
#declare P4    = < b*r,  h*r,     -d*r>;
#declare P5    = <-b*r,  h*r,     -d*r>;
#declare P6    = <-a*r,  h*r,      c*r>;
#declare P7    = < 0.0,   -r,      0.0>;
#declare P8    = < b*r, -h*r,      d*r>;
#declare P9    = < a*r, -h*r,     -c*r>;
#declare P10   = < 0.0, -h*r, -2.0*h*r>;
#declare P11   = <-a*r, -h*r,     -c*r>;
#declare P12   = <-b*r, -h*r,      d*r>;
Date: 14 Jan 2002 02:43:20
Message: <3C428C12.41C7D55D@sw-tech.com>
Thies Heidecke wrote:
> Hi Deaken,
Hello.
Thanks.
> Some explanations:
I use 1 for this, like your default.  "Bounded by the unit sphere", as
they say.
Hm.  You seem to have a much better grasp on the geometry involved than
I do.  I was foolish, and trusted reference pages which I found on the
web.  :)
Indeed.  Many thanks.
> #declare r     = 1.0;
Interesting.  I must study this.  Thanks again.
Deaken
Date: 14 Jan 2002 08:42:12
Message: <3C42E03E.26BF4F96@pandora.be>
Hello,
This is very well done. I appreciate that you are putting the sources
available.
The macros to define a square and a pentagon as a mesh of triangles are
a very good idea!
I also have some include files concerning polyhedra and using "polygon"
often gives problems concerning the planarity. I think it's better to
use triangles.
I see you're inscribing the platonic solids in a sphere. That's the most
symetrical way to do it but startin from a cube is mathematically more
easy.
You can find some examples on my website.
Friendly greetings.
> // Persistence of Vision Ray Tracer Include File
> // File: platonic.inc
> // Vers: 0.9
> // Desc: This file provides untextured versions of the five Platonic solids,
... skipped
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Date: 14 Jan 2002 09:53:42
Message: <3C42F0E3.7FAF75DE@sw-tech.com>
Herman Serras wrote:
> Hello,
Hi there.
Thank you.
> available.
Well, there is no other choice, as far as I'm concerned.  I learn from
the group, so I give back to the group, in my inexperienced (and
currently mostly useless) manner.  I hope to change that over time and
actually present something useful.
> a very good idea!
It struck me as the easiest and most uniform way to do it.  It could
have been easier if I had used box{} for the cube, but then it would not
have been constructed similar to the other polyhedra.
> use triangles.
> easy.
Wow.
"Easy", you say?  You are far beyond me in math, I'm afraid.
I did, however, find a link to already-provided polyhedral include files
(on mac.povray.org) from your site.  I KNEW I was reinventing the
wheel.  :/
Interesting that Mr. Towle seems (I have not been able to examine the
include files yet; I still need something to unpack .SIT and .HQX files)
to have provided the "pipes-and-balls" structures, too.  There is
nothing new under the sun.
It also occurs to me that I should have used a unit cube.  I would not
have found the bug in the icosa- and dodecahedra.  Heh.
> Friendly greetings.
Back at you.  :)
Deaken
Date: 14 Jan 2002 10:54:23
Message: <3C42FF39.DEA4AEB5@pandora.be>
Hello,
I think it's a good idea to try to obtain a uniform way to describe the
platonic solids. So I don't mean you should use "box" for the cube. But
the nice thing I learned from your include file is to avoid "polygon" by
using your macros. As I wrote, there can be difficulties if the 3D
polygon is not a planar one, and this can be a matter of rounding off.
The only polygon we're sure that it is a planar one is the triangle!
> wheel.  :/
The .hqx files can be expanded using "stuffit". You can find this
program on the web.
I also examined some of the files from Mr. Towle. But being a
mathematician I want to construct the polyhedra (or obtain their data)
myself. I think Mr. Towle obtained his data using an other programme:
all his data are written in decimal form (not using square roots
etc...).
One of the advantages starting from the cube and deriving the other four
platonic polyhedra form it is that one doesn't need to use spherical
geometry (or spherical trigonometry). I think most young people don't
study those things at school and the whole thing can be done starting
from the cube and using some analytical geometry. And... you see very
well the nice relations using the golden section that exist ex. in the
dodecahedron!
> > Friendly greetings.
> Back at you.  :)
> Deaken
Greetings from Ghent!
Herman Serras
Herman Serras
Gent (Belgium)
Date: 14 Jan 2002 17:35:16
Message: <3C435D07.A990D0EA@sw-tech.com>
> Hello,
Sorry.  I was unclear.  I was just explaining my methods and reasoning.
I didn't mean to say that I thought you had suggested it.
> But
> using your macros.
I am an almost-decent Forth programmer.  I find the overlap between
factoring code in Forth nicely similar to building POV scenes out of
primitives.  I try to use Forth's "simplify as much as possible, and
remove everything that can be removed" strategy as often as I can.
This is why I did something relatively simple, instead of, say, all the
rest of the polyhedra.  :)
> program on the web.
Yes, I used to be a Mac person.  I recognize the file type.  I once had
a toolkit for such files that worked on unix, but I am having a hard
time finding it again.
> etc...).
I am not a mathematician, just someone who wants to better his SDL
skills.
[I've actually got a problem relating to that, but I'm not sure if
povray.programming is the right place, or if it should go in
povray.newusers.  It involves translating something from C to a macro.
It's rather nasty.]
To be honest, I took a look at your site last night and I haven't the
faintest idea how I would, for example, construct a dodecahedron out of
a cube in POV-Ray, the way you describe it on your page.
Or, in my case, have studied it far too long ago to remember any of it.
Deaken
Date: 15 Jan 2002 19:51:01
Message: <chrishuff-28BB44.19520015012002@netplex.aussie.org>
In article <3C435D07.A990D0EA@sw-tech.com>, Deaken <dwy### [at] sw-techcom>
I've never seen any Forth code...what's it like?
> > program on the web.
StuffIt does work on Unix, it runs on Mac OS X. ;-)
Ok, I'm assuming that's not quite what you had in mind...though if you
want, I could make a .tgz of the files for you, just send them to me.
BTW, what are you using now? Your X-Mailer header says Win95, which I
assume is incorrect...
> It's rather nasty.]
Sounds like an interesting problem, povray.advanced-users might be a
better place...
povray.programming is more for discussion of the program source code
than the scene language.
Date: 16 Jan 2002 18:13:51
Message: <1103_1011222959@selliot>
On Tue, 15 Jan 2002 19:52:01 -0500, Christopher James Huff <chr### [at] maccom> wrote:
Except for some minor syntax differences, like using FORMAT to print formated
output, instead of PRINT USING, .OR. instead of simple OR and similar things
the code in Forth appears to be very similar to that of QBASIC, which also allows
you to use line numbers only when you need them.
It probably is a lot better at doing math though, since the last time I tried to port
the code from one into a version of basic, the results where off by quite a bit. I
may have forgot to convert to radians or something though, so I can't be sure
and I am stopped fiddling with that code a while back. ;)
Some examples are at http://www.ngs.noaa.gov/PC_PROD/pc_prod.shtml
