POV-Ray : Newsgroups : povray.binaries.scene-files : Polyhedra include file Server Time
16 Dec 2025 00:52:03 EST (-0500)
  Polyhedra include file (Message 1 to 5 of 5)
Subject: Polyhedra include file
Date: 10 Jan 2001 23:20:43
Message: <3A5D35C4.9677F832@hotmail.com>
Include file with many shapes, and a scene file that uses all of them.
Download 'polyhedra_demo.pov.txt' (8 KB) Download 'us-ascii' (25 KB)
Subject: Revised demo file
Date: 12 Jan 2001 00:01:39
Message: <3A5E9098.CECF6A5B@hotmail.com>
Revised demo for my include file.  Text is easier to read in rendered image.
Dan Johnson
Subject: Re: Polyhedra include file
Date: 13 Jan 2001 14:46:46
Message: <3A60AF53.49F05C6E@online.no>
Dan Johnson wrote:
> #macro Arrange_3d (A,B,C,N)
>        ( (mod(N+A-1,A))*x + (B-mod(div(N+A-1,A)+B-1,B))*y +
(mod(div(N+B*A-1,B*A)+C-1,C))*z -<A-1,B+1,C-1>/2)
> #end  // use only natural numbers aka 1,2,3,4,5,6... no fractions 0 or negative
numbers
A little nit-picking from me follows ...
The above macro could be slightly simplified like this:
#macro Arrange_3d(A, B, C, N)
  (< mod(N+A-1,A),
    -mod(div(N+A-1,A)+B-1,B),
     mod(div(N+B*A-1,B*A)+C-1,C)>-
   <A-1,-B+1,C-1>/2)
#end // macro Arrange_3d
Or like this:
#macro MM(M,N)
  mod(N+M-1,M)
#end // macro MM
#macro DD(M,N)
  div(N+M-1,M)
#end // macro DD
#macro Arrange_3d(A,B,C,N)
  (<MM(A,N),MM(B,DD(A,N)),MM(C,DD(A*B,N))>-<A-1,B-1,C-1>/2)*(x-y+z)
> #declare Golden2 = (Golden -1); // the golden ratio is the only ratio where one is
the difference between it and its inverse
I didn't know that. Interesting fact.
It's a lot of math work you have done with this include !
Maybe you could make some more general macros that
handles arrays containing the coordinates for the
different cylinders, spheres, torii and planes and
then "spreads" them around to their positions ?
E.g.
If you declared and array like this:
#declare IcosahedronVertexArray =
array [12] {
  < Golden2,        0,  Golden3>,
  < Golden2,        0, -Golden3>,
  < Golden3,  Golden2,        0>,
  < Golden3, -Golden2,        0>,
  <       0,  Golden3,  Golden2>,
  <       0,  Golden3, -Golden2>,
  <       0, -Golden3,  Golden2>,
  <       0, -Golden3, -Golden2>,
  <-Golden3,  Golden2,        0>,
  <-Golden3, -Golden2,        0>,
  <-Golden2,        0,  Golden3>,
  <-Golden2,        0, -Golden3>
Then you could write things like this:
#include "glass.inc"
#declare SphereCentreArray =
  ScaleArray(IcosahedronVertexArray, 3);
#declare SphereRadii = 0.5;
merge {
  SphereSpread(SphereCenterArray, SphereRadii)
  interior { I_Glass }
  texture { T_Glass3 }
The ScaleArray macro just multiplies every
vector in the array by a scalar.
And the SphereSpread macro just puts a sphere
in every position given in the array.
I hope this triggers some ideas...  :)
Tor Olav
mailto:tor### [at] hotmailcom
Date: 19 Jan 2001 02:17:22
Message: <3A67EB4C.EFE1B3BD@hotmail.com>
numbers
>   (< mod(N+A-1,A),
>    <A-1,-B+1,C-1>/2)
> Or like this:
> #macro MM(M,N)
>   mod(N+M-1,M)
> #end // macro MM
> #macro DD(M,N)
>   div(N+M-1,M)
> #end // macro DD
I think it took me three days to figure out how to make that macro work.  After that I
didn't want to look at it anymore.  Do you
understand what it does, and how?
This function started when I made my fist cube out of cylinders, and I looked at the
resulting points.
<0,0,0>
<0,0,1>
<0,1,0>
<0,1,1>
<1,0,0>
<1,0,1>
<1,1,0>
<1,1,1>
Hmm binary.  So I made a little macro based on base10 to binary conversion.
//macro Cube_points returns a vector for a corner of a cube given an integer 1-8
periodic after 8
#macro Cube_points (N)
        (mod(N,2)*2*z + mod(div(N+1,2),2)*2*y + mod(div(N+3,4),2)*2*x -1)
Then I realized that it could be made much more versatile, and I set out to make a
cubic lattice of any dimensions.  Since the
order of placement was still based on my binary algorithm it arranged things in a way
people don't usually think.  I changed
things around until it went left to right, top to bottom, front to back ( like a
book).  The arrange 3d function is the result.
More recently I figured out that it could be made even more versatile.  I could do
things like have three in one row, and four in
the next, and continue alternating.  I think I may be able to make a macro that will
spit out the coordinates of icosahedron
vertexes.  That would go a long way towards simplifying the process of making an 8
frequency geodesic dome.
> E.g.
> array [12] {
> merge {
Didn't understand how the array function worked, makes sense now.
It has.
> Regards,
> Tor Olav
> http://www.crosswinds.net/~tok/tokrays.html
Dan Johnson
Date: 23 Jan 2001 19:55:35
Message: <3A6E27C8.5A71B161@online.no>
numbers
I didn't want to look at it anymore.  Do you
Yes, I understand what it does.
And now I also understand what's going on.
I think this macro is a clever idea !
resulting points.
> <0,0,0>
> <0,0,1>
> <0,1,0>
> <0,1,1>
> <1,0,0>
> <1,0,1>
> <1,1,0>
> <1,1,1>
periodic after 8
> #end
Of course I have to "twist" your code a little bit  ;)
<mod(div(N + 3, 4), 2), mod(div(N + 1, 2), 2), mod(N, 2)>*2 - <1, 1, 1>
Hmmm... so it would go on like this:
mod(div(N + (2^0 - 1), 2^0), 2) -> mod(div(N +  0,  1), 2) -> mod(N, 2)
mod(div(N + (2^1 - 1), 2^1), 2) -> mod(div(N +  1,  2), 2)
mod(div(N + (2^2 - 1), 2^2), 2) -> mod(div(N +  3,  4), 2)
mod(div(N + (2^3 - 1), 2^3), 2) -> mod(div(N +  7,  8), 2)
mod(div(N + (2^4 - 1), 2^4), 2) -> mod(div(N + 15, 16), 2)
way people don't usually think.  I changed
If you manage to do that (or even if you come close)
then please post your results !
Best regards,
Tor Olav
