POV-Ray : Newsgroups : povray.binaries.scene-files : Realistic radiosity Server Time
17 Dec 2025 01:25:11 EST (-0500)
  Realistic radiosity (Message 1 to 1 of 1)
Subject: Realistic radiosity
Date: 12 Jun 2000 11:33:30
Message: <39450341.610E8FC3@kivisalo.net>
#version unofficial megapov 0.5;
/* This scene produces image that, with Display_Gamma 2.2, matches
   the image of the Cornell box available at
http://www.graphics.cornell.edu/online/box/box.jpg. It was
   rendered using some fancy software. POV-Ray renders
   the scene at 300x300 in 1 minute with AMD 400MHz.
   The radiosity settings are not critical for realistic results.
   More important are assumed_gamma, fade_power, fade_distance and
   light source intensity distribution (spotlight). You can see this
   for yourself by removing the lines marked IMPORTANT. You will find
   that it is absolutely impossible to get even close to the reference
   image without those statements. For this reason I present the recipe
   for realistic radiosity scenes:
   1. Use assumed_gamma 1.0 and set Display_Gamma in povray.ini
      to a value that you measured using a test image. Adjust
      monitor brightness and contrast using
      http://hammer.prohosting.com/~kkivisal/adjust.gif
   2. Use fade_power 2 and try 1.4*light_source_diameter as the
      value for fade_distance first. Don't set it too high though.
   3. If the light source is a flat panel use
      spotlight radius 1 falloff 90 tightness -0.8.
      For other shapes you'll have to improvise. Remember that large area_lights
      don't produce correct direct llumination, you'll have to use several
      area_lights or point sources instead to cover the area.
   Tips.
   If the shadows are too bright multiply light source colors by a factor
   and divide diffuse by the same factor. Do the inverse if there is not
   enough diffused light. Generally low diffuse values are more realistic,
   try 0.5 first.
   If you extract a color from an image or from some color selector remember
   to inverse gamma correct it ( pow(color.x,Display_Gamma) ) before using it
   in a scene file. This way the color looks more or less the same. The same
   goes for image maps also. In PSP for example set gamma to 1/Display_Gamma.
   Scene geometry from Cornell data by alb### [at] wanadoofr.
   June 11 2000 kar### [at] kivisalonet
   http://www.kivisalo.net
$Q=1;
global_settings{
  assumed_gamma 1.0 // IMPORTANT, set also Display_Gamma in povray.ini
  ini_option "+qr"
  radiosity{
    pretrace_start 0.04
    pretrace_end 0.02/Q
    count 150*Q
    recursion_limit 4
    nearest_count 3+(Q-1)*10
    error_bound 1/Q
#declare Finish=finish{diffuse 0.75 brilliance 0.5 ambient 0}
#declare White=texture{pigment{rgb<1,1,1>} finish{Finish}}
#declare Red=texture{pigment{rgb<0.565,0,0>} finish{Finish}}
#declare Green=texture{pigment{rgb<0.02,0.236,0.002>} finish{Finish}}
 * light patch
 * Spotlight used to simulate cos(angle) intensity falloff of
 * planar light source (area_light only takes care of the shadows).
  light_source {
    <27.8,54.88,27.95>
    color <1,0.673,0.19>*2.81
    area_light <13.0, 0, 0>, <0, 0, 10.5>, 10, 10 adaptive 0
    /* -----------------IMPORTANT--------------------------- */
    spotlight radius 1 falloff 90 tightness -0.8 point_at 55/2
    fade_power 2 fade_distance (13+10.5)/2*1.4
  box{
    <21.3,54.87,33.2><34.3,54.88,22.7> no_shadow
    pigment{rgb<1,1,1>} finish{ambient 1 diffuse 0}
// ------------------------ OBJECTS ----------------------------
camera{
   location  <27.8, 27.3,-80.0>
   direction <0, 0, 1>
   up        <0, 1, 0>
   right     <-1, 0, 0>
   angle 39.5
union {
 * floor
  triangle {
    <55.28, 0.0, 0.0>,
    <0.0, 0.0, 0.0>,
    <0.0, 0.0, 55.92>
  triangle {
    <55.28, 0.0, 0.0>,
    <0.0, 0.0, 55.92>,
    <54.96, 0.0, 55.92>
 * ceiling
  triangle {
    <55.60, 54.88, 0.0>,
    <55.60, 54.88, 55.92>,
    <0.0, 54.88, 55.92>
  triangle {
    <0.0, 54.88, 55.92>,
    <0.0, 54.88, 0.0>
 * back wall
  triangle {
    <54.96, 0.0, 55.92>
  triangle {
    <54.96, 0.0, 55.92>,
    <0.0, 0.0, 55.92>
  texture {White}
union {
 * right wall
  triangle {
    <0.0, 54.88, 0.0>,
    <0.0, 0.0, 55.92>
  triangle {
    <0.0, 54.88, 0.0>,
    <0.0, 0.0, 55.92>,
    <0.0, 0.0, 0.0>
  texture {Green}
union {
 * left wall
  triangle {
    <55.28, 0.0, 0.0>,
  triangle {
    <55.28, 0.0, 0.0>,
    <55.60, 54.88, 0.0>
  texture {Red}
union {
 * short block
  triangle {
    <13.00, 16.50, 6.50>,
    <8.20, 16.50, 22.50>,
    <24.00, 16.50, 27.20>
  triangle {
    <24.00, 16.50, 27.20>,
    <29.00, 16.50, 11.40>
  triangle {
    <29.00, 0.0, 11.40>,
    <29.00, 16.50, 11.40>,
  triangle {
    <24.00, 0.0, 27.20>
  triangle {
    <13.00, 0.0, 6.50>,
  triangle {
    <13.00, 0.0, 6.50>,
    <29.00, 0.0, 11.40>
  triangle {
    <8.20, 0.0, 22.50>,
  triangle {
    <8.20, 0.0, 22.50>,
    <13.00, 0.0, 6.50>
  triangle {
    <24.00, 0.0, 27.20>,
  triangle {
    <8.20, 0.0, 22.50>
  texture { White }
union {
 * tall block
  triangle {
    <42.30, 33.00, 24.70>,
    <26.50, 33.00, 29.60>,
    <31.40, 33.00, 45.60>
  triangle {
    <31.40, 33.00, 45.60>,
    <47.20 33.00 40.60>
  triangle {
    <42.30, 0.0, 24.70>,
    <47.20, 33.00, 40.60>
  triangle {
    <47.20, 33.00, 40.60>,
    <47.20, 0.0, 40.60>
  triangle {
    <47.20, 0.0, 40.60>,
  triangle {
    <31.40, 0.0 45.60>
  triangle {
    <31.40, 0.0, 45.60>,
  triangle {
    <26.50, 0.0, 29.60>
  triangle {
    <26.50, 0.0, 29.60>,
  triangle {
    <42.30, 0.0, 24.70>
  texture {White}
_______________________________________________________________________
Kari Kivisalo                                          www.kivisalo.net
