POV-Ray : Newsgroups : povray.binaries.scene-files : soft prisms Server Time
14 Jul 2025 18:18:29 EDT (-0400)
  soft prisms (Message 1 to 5 of 5)
Subject: soft prisms
Date: 8 Aug 1999 18:48:23
Message: <37AE08A6.B371B39F@xs4all.nl>
I wasn't exactly sure whether to post this here or in the utilities-group, but
here it is.
I needed a prism with soft edges. I remember wanting to make such a macro some
time ago. I vaguely remember someone mentioning a thing like that here so there
is a chance I'm reinventing the wheel.
With this macro you can make only linear sweeps and splines.
This is a first version which seems to do what I want but I can imagine you can
find some mistakes in it or have suggestions for improvement. Comments are
welcome.
There is something weird though. The test-scene included renders fine, but I
tested it with an orthographic camera and there are thin white lines on some
objects which shouldn't be there. With a normal camera you can also see some,
depending on the location of the camera. I have no idea what's causing this. It
may well be a bug in the macro but I can't find it. Anyone any ideas?
Remco
http://www.xs4all.nl/~remcodek/
Download 'softpris.zip' (2 KB)
Subject: Re: soft prisms
Date: 9 Aug 1999 10:24:09
Message: <37aee489@news.povray.org>
This is a bug in POV.  I first reported it back in version 3.0, but I
have had no luck actually finding the problem.  It's similar to the bug
that Truetype fonts used to have, which Kochin Chang fixed.  I sent him
my code that duplicates the problem you see here and he never found a
solution either, to my knowledge.  What's happening is that POV is
counting crossings (the Jordan Curve Theorem) to see whether the ray/
object intersection point is inside or outside the object, but it's
accidentally counting a crossing twice due to numerical inaccuracies
or segment overlap or both, and thus thinking it's inside the object
when it shouldn't be.
Date: 9 Aug 1999 12:23:54
Message: <37AF00C6.C1E2F046@xs4all.nl>
Is it a bug in the prism-object or somewhere else?
I found another bug in my inc-file I can't solve.
Try rendering this:
#include "softpris.inc"
camera{location <0,0,-12> look_at <0,0,0> orthographic}
light_source{<-100,20,-100> color rgb 1}
light_source{<100,20,-100> color rgb .7 shadowless}
light_source{<-100,-20,-100> color rgb .4 shadowless}
light_source{<100,-20,-100> color rgb .1 shadowless}
#declare pp=array[3]
{ < 0,-2>,
  <-3, 3>,
  < 3, 3>}
object{soft_prism(-2,2,3,pp,.25)
  pigment{rgb 1}
  rotate y*225
  rotate x*-45
  translate<-3,0,0>
{ < 0, 2>,
  <-3,-3>,
  < 3,-3>}
  pigment{rgb 1}
  rotate y*45
  rotate x*-45
  translate<5,0,0>
//eof
Both objects should look the same, but they don't. I can't find what I'm doing
wrong and where I'm doing it. If anyone has any ideas please let me know.
Meanwhile if a soft prism looks screwy the only solution is to create a another
soft prism and rotate that to get the prism you want. Not really very elegant...
Remco
Date: 9 Aug 1999 13:05:30
Message: <37af0a5a@news.povray.org>
It's in the prism object.  For your purpose, since your prisms
are always convex, you could just intersect a bunch of planes and
bound them apropriately.
>Try rendering this:
[code elided]
The problem is in your calculation of nn.  Its sign seems to be dependent on
the direction you go around the prism.  I find that if I put a
#declare nn=-nn;
in the right place, the bad prism becomes good and the good one becomes bad.
Date: 9 Aug 1999 18:07:22
Message: <37AF513E.72E90B40@xs4all.nl>
> >Try rendering this:
> [code elided]
> #declare nn=-nn;
Okay, thank you.
I guess I'll leave it at this for now.
Remco
