POV-Ray : Newsgroups : povray.binaries.scene-files : Window macro v 1.1 Server Time
14 Jul 2025 18:04:21 EDT (-0400)
  Window macro v 1.1 (Message 1 to 3 of 3)
Subject: Window macro v 1.1
Date: 14 Jul 1999 11:55:12
Message: <378CB28F.B7F95597@skynet.be>
//   2-parts window macro (v 1.1), by Fabien Mosen 1999,
//        features :
//        - totally incompatible with previous window macro (v 1) !!
//        - more control of final aspect, especially the thickness of
divisions
//        - the middle piece of wood has a better thickness now (main
fault in v 1.0)
//        - hinges
//        - you can now use any handle you like, the origin of the
handle will
//          be placed at the center of the middle post.
//        - the lower-left-inside point of the window is at the origin
//        - frame and glass texture may both be specified
//        - if you use a wood texture (log lies along Z axis), every
piece
//          of the window will have the veins in the right direction
//        - the macro is not foolproof, you could get strange results
//          with inapproprite dimensionning
// some scenery...
#include "woods.inc"
//#include "mestex.inc"
camera {location <180,62,10> angle 70 look_at <0,60,30>}
//preliminary macro
#macro Cadre (Haut,Larg,Epaiss,Prof,Tex1) //tout en positif a partir de
0
 union {
 box {<0,0,0>,<Prof,Haut,Epaiss> texture {Tex1 rotate x*90}}
 box {<0,0,Larg>,<Prof,Haut,Larg-Epaiss> texture {Tex1 rotate x*90}}
 box {<0,0,Epaiss>,<Prof,Epaiss,Larg-Epaiss> texture {Tex1}}
 box {<0,Haut,Epaiss>,<Prof,Haut-Epaiss,Larg-Epaiss> texture {Tex1}}
//      the window macro itself
#macro Dbl_Open_Window_1_1
(Bay_W,Bay_H,A,B,C,D,E,F,G,NbGlassW,NbGlassH,FenTex,GlassTex,LeftAngle,RightAngle,Handle)
union {
#declare X=((D/2)-C);
#declare Ouvrant=union {
object {Cadre (
                Bay_H-(2*A),
                (Bay_W-(2*A)-X)/2,
                B,
                -X,
                texture {FenTex}
object {Cadre (
              Bay_H-(2*A)-(2*X),
              ((Bay_W-(2*A)-X)/2)-(2*X),
              B-X,
              -X,
              texture {FenTex}
              ) translate <-X,X,X>
#declare Width_internal_frame=((Bay_W-(2*A)-X)/2)-(2*B);
#declare Height_internal_frame=Bay_H-(2*A)-(2*B);
#declare Profil1=prism {linear_spline 0,1,4,<0,0>,<-X+G,0>,<0,F>,<0,0>
pigment {Wheat}}
#declare BaguetteV=union {
 box {<0,0,0>,<E,Height_internal_frame,F> texture {FenTex rotate x*90}}
 object {Profil1 scale <1,Height_internal_frame,1> translate x*-G}
#declare BaguetteH=union {
 box {<0,0,0>,<E,Width_internal_frame,F> texture {FenTex rotate x*90}}
 object {Profil1 scale <1,Width_internal_frame,1> translate x*-G}
 rotate x*-90 translate z*Width_internal_frame
box {<-X,B,B>,<-X-G,Height_internal_frame+B,B+Width_internal_frame>
material {GlassTex}}
object {BaguetteV translate <-X,B,B>}
object {BaguetteV scale <1,1,-1> translate <-X,B,((Bay_W-(2*A)-X)/2)-B>}
object {BaguetteH translate <-X,B,B>}
object {BaguetteH scale <1,-1,1> translate
<-X,B+Height_internal_frame,B>}
#declare SeparV=union {
 box {<E,0,F/2>,<-X,Height_internal_frame,-F/2> texture {FenTex rotate
x*90}}
 object {BaguetteV translate <0,0,F/2>}
 object {BaguetteV scale <1,1,-1> translate <0,0,-F/2>}
#declare SeparH=union {
 box {<E,F/2,0>,<-X,-F/2,Width_internal_frame> texture {FenTex}}
 object {BaguetteH translate <0,F/2,0>}
 object {BaguetteH scale <1,-1,1> translate <0,-F/2,0>}
#declare Boucle=1;
#while (Boucle < NbGlassW)
 #declare Step=Width_internal_frame/NbGlassW;
 object {SeparV translate <-X,B,B+(Boucle*Step)>}
 #declare Boucle=Boucle+1;
#declare Boucle=1;
#while (Boucle < NbGlassH)
 #declare Step=Height_internal_frame/NbGlassH;
 object {SeparH translate <-X,B+(Boucle*Step),B>}
}//fin de Ouvrant
#declare Ouvrant_Left=union {
 object {Ouvrant}
 box
{<-X,X,B+Width_internal_frame+B-X>,<-2*X,B+Height_internal_frame+B-X,B+Width_internal_frame+B+X>
 rotate y*LeftAngle
#declare Ouvrant_Right=union {
 object {Ouvrant}
 box
{<-X,X,B+Width_internal_frame+B-X>,<-2*X,B+Height_internal_frame+B-X,B+Width_internal_frame+B>
 box
{<-X,X,B+Width_internal_frame+B-X>,<0,B+Height_internal_frame+B,B+Width_internal_frame+B+X>
 box
{<C,0,B+Width_internal_frame+B-X>,<0,B+Height_internal_frame+B,B+Width_internal_frame+B+X>
 object {Handle translate
<C,B+(Height_internal_frame/2),B+Width_internal_frame+B>}
 scale <1,1,-1>
 rotate y*-RightAngle
 object {Cadre (Bay_H,Bay_W,A,-D/2,FenTex)}
 object {Cadre (Bay_H,Bay_W,A+X,-D/2,FenTex) translate x*-D/2}
 object {Ouvrant_Left translate <-C,A,A>}
 object {Ouvrant_Right translate <-C,A,Bay_W-A>}
union {
cylinder {<-C/2,0,(A+C/2)>,<-C/2,B,(A+C/2)>,C/2 translate y*(A+B)
pigment {Gray50}}
cylinder {<-C/2,0,(A+C/2)>,<-C/2,B,(A+C/2)>,C/2 translate y*(Bay_H/2)
pigment {Gray50}}
y*(Bay_H-(A+B)) pigment {Gray50}}
union {
pigment {Gray50}}
pigment {Gray50}}
scale <1,1,-1> translate z*Bay_W
 }//fin de l'union de la macro
#end //
        //MACRO ENDS HERE
//      SOME SAMPLES...
#declare Glass1=material {
texture {pigment {LightBlue filter .95} finish {reflection .4} normal
{wrinkles .1}}
interior {ior 1.5}
texture {pigment {LightBlue filter .99} finish {reflection .2}}
interior {ior 1.1}
object {
Dbl_Open_Window_1_1 (80,120,  4,5,1,5,1.2,.8,.4,  2,3,texture {T_Wood23
scale 5},Glass1, 150,30,sphere {<2,0,0>,2})
translate y*-15
object {
Dbl_Open_Window_1_1 (80,120,  4,5,1,5,1.2,.8,.4,  1,2,texture {T_Wood23
scale 5},Glass1, 0,0,sphere {<2,0,0>,2})
translate <-100,15,30>
object {
Dbl_Open_Window_1_1 (100,140,  6,5,.8,5,1,.8,.4,  3,8,texture {T_Wood21
scale 8},Glass1, 40,0,sphere {<2,0,0>,2})
translate z*90
object {
Dbl_Open_Window_1_1 (100,140,  6,5,.8,5,1,1.3,.4,  1,6,pigment
{MediumForestGreen},Glass1, 20,30,cylinder {<2,-5,0>,<2,5,0>,1 pigment
{MediumForestGreen}})
translate z*-100
light_source {<480,1022,1000> White*3}
light_source {<180,42,10> White*1}
fog {distance 1000 rgb <.2,.3,.4>}
Download 'graphic1.jpg' (40 KB)
Preview of image 'graphic1.jpg'
Subject: Re: Window macro v 1.1
Date: 18 Jul 1999 08:51:47
Message: <3793cc19.211988194@news.povray.org>
On Wed, 14 Jul 1999 17:53:51 +0200, Fabien Mosen <fab### [at] skynetbe>
  Thanks for posting your window macro, Fabien.
Alan
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
Date: 18 Jul 1999 13:22:15
Message: <37920d47@news.povray.org>
Merci pour ceci  !
Superbe macro  .
Martial.
mar### [at] multimaniacom
http://www.multimania.com/martialrameaux
