POV-Ray : Newsgroups : povray.binaries.scene-files : REQ: old povs ... Server Time
19 Apr 2026 12:54:58 EDT (-0400)
  REQ: old povs ... (Message 1 to 4 of 4)
Subject: REQ: old povs ...
Date: 14 Mar 1999 08:10:13
Message: <36ebb535.0@news.povray.org>
The Roman.pov,rocket.pov and tomb.pov that came with older versions
i really want to get these back as i liked them.
MiGHTY FiNGERS
icq #30079601
Subject: Re: REQ: old povs ...
Date: 14 Mar 1999 09:09:54
Message: <36EBC234.E289D61B@pacbell.net>
> MiGHTY FiNGERS
> icq #30079601
Below is the 2.0 version of Roman.pov. I'll take a look through my
other archives and see if I can find the other two for you.
Ken Tyler
mailto://tylereng@pacbell.net
// Persistence Of Vision raytracer version 2.0 sample file.
// By Rick Mallett of Carleton University,  Ottowa.
// First stage of the Tower of Pisa
// Warning:  This picture can take a very long time to ray trace
// due to the large number of objects.  You have been warned :->
#include "shapes.inc"
#include "textures.inc"
   location <0.0, 25.0, -150.0>
   direction <0.0, 0.1, 1.0>
   up <0.0, 1.0, 0.0>
   right <4/3, 0.0, 0.0>
#declare Beam = object {
   Cylinder_Y
   scale <0.5, 20.0, 0.5>
   translate 2.0*x
/* create a sample column for the base of the structure */
#declare BaseColumn = intersection {
   union {
      object { Beam }
      object { Beam rotate  -25.7*y }
      object { Beam rotate  -51.4*y }
      object { Beam rotate  -77.1*y }
      object { Beam rotate -102.8*y }
      object { Beam rotate -128.5*y }
      object { Beam rotate -154.2*y }
      object { Beam rotate -179.9*y }
      object { Beam rotate -205.6*y }
      object { Beam rotate -231.3*y }
      object { Beam rotate -257.0*y }
      object { Beam rotate -282.7*y }
      object { Beam rotate -308.4*y }
      object { Beam rotate -334.1*y }
   plane { y, 40.0 }
   plane { -y, 0.0 }
   bounded_by {
      intersection {
         plane { y, 40.0 }
         plane { -y, 0.0 }
         object { Cylinder_Y scale <2.51 1.0 2.51> }
         Red_Marble
         scale 10.0
         quick_color red 0.8 green 0.0 blue 0.0
      finish {
         ambient 0.2
         diffuse 0.7
         reflection 0.1
/* and a rectangular pad to serve as a footing for the column */
#declare BasePad = object {
   UnitBox
   scale <4, 1, 4>
         Red_Marble
         scale 10.0
         quick_color red 0.6 green 0.6 blue 0.4
      finish {
         ambient 0.2
         diffuse 0.7
         reflection 0.1
/* and define a basic arch to span the columns */
#declare BaseArch = intersection {
   object { Cylinder_X scale <1.0, 12.5, 12.5> }
   object { Cylinder_X scale <1.0, 8.5, 8.5> inverse }
   plane { x, 2.0 }
   plane { -x, 2.0 }
   plane { -y, 0.0 }
   bounded_by {
      sphere { <0, 0, 0>, 1 scale <5.0, 13.0, 13.0> }
         Red_Marble
         scale 10.0
         quick_color red 0.8 green 0.8 blue 0.8
      finish {
         ambient 0.2
         diffuse 0.7
         reflection 0.1
/* and finally define the first floor floor */
#declare BaseFloor = intersection {
   object { Cylinder_Y scale 50.0 }
   object { Cylinder_Y scale 40.0 inverse }
   plane { y, 2.0 }
   plane { -y, 2.0 }
         Red_Marble
         scale 10.0
         quick_color red 0.8 green 0.8 blue 0.6
      finish {
         ambient 0.2
         diffuse 0.7
         reflection 0.1
/* place a ring of 14 columns with footings around the base */
#declare FullColumn = union {
   object { BaseColumn translate <45.0, 0.0, 0.0> }
   object { BasePad    translate <45.0, -1.0, 0.0> }
   object { BasePad    translate <45.0, 41.0, 0.0> }
   object { BaseArch   translate <45.0, 42.0, 2.0> rotate <0.0, -12.85, 0.0> }
#declare Level1 = union {
   object { FullColumn }
   object { FullColumn rotate  -25.7*y }
   object { FullColumn rotate  -51.4*y }
   object { FullColumn rotate  -77.1*y }
   object { FullColumn rotate -102.8*y }
   object { FullColumn rotate -128.5*y }
   object { FullColumn rotate -154.2*y }
   object { FullColumn rotate -179.9*y }
   object { FullColumn rotate -205.6*y }
   object { FullColumn rotate -231.3*y }
   object { FullColumn rotate -257.0*y }
   object { FullColumn rotate -282.7*y }
   object { FullColumn rotate -308.4*y }
   object { FullColumn rotate -334.1*y }
   object { BaseFloor translate 56.5*y }
   bounded_by {
      intersection {
         object { Cylinder_Y scale <55.0, 1.0, 55.0> }
         plane { -y, 0.0 }
         plane { y, 60.0 }
object { Level1 }
/* Add the sky to the picture */
sphere {
   <0.0, 0.0, 0.0>, 300.0
         bozo
         turbulence 0.5
         colour_map {
            [0.0 0.6   colour red 0.5 green 0.5 blue 1.0
                       colour red 0.5 green 0.5 blue 1.0]
            [0.6 0.8   colour red 0.5 green 0.5 blue 1.0
                       colour red 1.0 green 1.0 blue 1.0]
            [0.8 1.001 colour red 1.0 green 1.0 blue 1.0
                       colour red 0.8 green 0.8 blue 0.8]
         scale <100.0, 20.0, 100.0>
         quick_color red 0.5 green 0.5 blue 1.0
      finish {
         ambient 0.8
         diffuse 0.0
/* Define the desert floor */
plane {
   y, -2.0
      pigment { colour red 1.0 green 0.66 blue 0.2 }
      normal {
         ripples 0.5
         frequency 2000.0
         scale 50000.0
      finish {
         crand 0.05  /* This value dithers the colours */
         ambient 0.3
         diffuse 0.7
/* Add a light source */
light_source { <60.0, 50.0, -110.0> colour White }
Date: 14 Mar 1999 09:18:43
Message: <36EBC441.21B8F985@pacbell.net>
> MiGHTY FiNGERS
> icq #30079601
Here are the other two you requested from version v2.2
Enjoy,
Ken Tyler
Download 'rocket.zip' (2 KB) Download 'tomb.pov.txt' (14 KB)
Date: 14 Mar 1999 10:21:55
Message: <36ebd413.0@news.povray.org>
Thanks a lot
MiGHTY FiNGERS
icq #30079601
Ken wrote in message <36EBC441.21B8F985@pacbell.net>...
>> MiGHTY FiNGERS
>> icq #30079601
>Enjoy,
>Ken Tyler
