POV-Ray : Newsgroups : povray.binaries.scene-files : Stupid math problem, HELP!!!!! Server Time
15 May 2024 03:10:01 EDT (-0400)
  Stupid math problem, HELP!!!!! (Message 1 to 7 of 7)
Subject: Stupid math problem, HELP!!!!!
Date: 9 Feb 1999 21:52:10
Message: <36C0F5C2.400D03A5@earthlink.net>
Trying to use POV to generate columns with x number grooves, forget my
math (to many years ago.....).  this is the code I used but not working,
can someone enlighten me please.  I know it has something to do with the
sin/cos stuff but can't figure it out with the remaining 3 brain cells
in my skull.
#declare grooves = 36
#declare vector = 360/grooves
#declare groove_now = 1
difference{
  cylinder{  <0,0,0>,  <0,3,0>,  1  pigment {Red}  }
  #while (groove_now <= grooves)
    cylinder{  <sin(vector), -1, cos(vector)>  <sin(vector), 4,
cos(vector)>,  .1  pigment {Blue}  }
    #declare groove_now = groove_now + 1
    #declare vector = vector + 360/grooves
Subject: Re: Stupid math problem, HELP!!!!!
Date: 9 Feb 1999 23:27:31
Message: <36c108d5.864491@news.povray.org>
On Tue, 09 Feb 1999 18:58:11 -0800, Mark Palmquist
>in my skull.
<code>
As I see it, you are using degrees instead of radians. POV's trig
funcitons take radians as parameters.  I think this should work.
#declare vector = 2*pi/grooves
#declare Angle=0;
#declare groove_radius=0.1
#declare groove_center=1.05
difference
  #while (Angle < 2*pi )
    cylinder
      <groove_ center*cos(Angle),-1, groove_center* sin(Angle))>,
      <groove_ center*cos(Angle),4, groove_center* sin(Angle))>,
      groove_radius
      pigment {Blue}
    #declare Angle=Angle+vector;
Should work except for a typo or two (or three). Didn't test it
though.
Peter
Date: 10 Feb 1999 00:00:15
Message: <36C1120F.769CF0C0@pacbell.net>
> >in my skull.
> <code>
> #declare Angle=0;
> difference
>     cylinder
>       groove_radius
>       pigment {Blue}
>   #end
> though.
> Peter
You math guy's make me laugh. As I see it he want's 10 grooves
equaly spaced around a cylinder right ?
camera{location<0,0,-7> look_at 0}
light_source{<0, 35,-400>rgb 1}
#declare a = 0;
#while  (a < 10)
difference {
cylinder{y*0.00, y*3.0, 1.0 pigment {red 1}}
cylinder{y*-0.1, y*3.1, 0.1 pigment {blue 1} translate x*1 rotate y*36*a}}
#declare a = a + 1;
Unfortunatly the above positioned the differencing cylinders
correctly around the cylinder but does not perform the csg operation.
Is this a bug ?
The situation below places the differencing cylinders in the exact
same positions and does the csg operation correctly.
#declare DiffObject =
cylinder{y*-.1,y*3.1,.1 pigment{blue 1}translate x*1}
difference{
cylinder{y*0,y*3,1 pigment {red 1}}
object{DiffObject rotate y*  0}
object{DiffObject rotate y* 36}
object{DiffObject rotate y* 72}
object{DiffObject rotate y*108}
object{DiffObject rotate y*144}
object{DiffObject rotate y*180}
object{DiffObject rotate y*216}
object{DiffObject rotate y*252}
object{DiffObject rotate y*288}
object{DiffObject rotate y*324}}
Would someone care to elaborate as to why one method works
and the other does not ?
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Feb 1999 00:42:48
Message: <36C11DC0.66599660@earthlink.net>
Thanks guys, Ken it's not a 'bug' just need to move the 1st difference outside
the loop.
new code below.
#declare grooves = 16
#declare base = 0
#declare top = 5
#declare a = 0;
difference {
cylinder{y*base, y*top, 1.0 pigment {red 1}}
#while  (a < grooves)
  cylinder{y*(base - .01) , y*(top + .1) , 0.1 pigment {blue 1} translate x*1
rotate y*(360/grooves)*a}
  #declare a = a + 1;
> #declare a = 0;
> #while  (a < 10)
> difference {
> #declare a = a + 1;
> #end
> Is this a bug ?
> difference{
> Ken Tyler
Date: 10 Feb 1999 00:56:11
Message: <36c31cd5.5985409@news.povray.org>
On Tue, 09 Feb 1999 20:58:55 -0800, Ken <tyl### [at] pacbellnet> wrote:
<snip>
You mean my method doesn't work? Then the original poster can use
yours, as I see it will works. The simplicity of true genius, right?
Date: 10 Feb 1999 05:23:19
Message: <36C15DD8.142085AD@pacbell.net>
> <snip>
In fairness to you yes it did work once the typo's were removed.
Sure seemed like an awfull lot of extra typing to get the job done
is all.
 About the true genius part I was wondering when somebody would notice :)
Ken Tyler
Subject: Re: Stupid math problem, HELP!!!!! (2.8 .INC File Attached)
Date: 20 Feb 1999 02:40:47
Message: <36ce66ff.0@news.povray.org>
Mark Palmquist wrote in message <36C0F5C2.400D03A5@earthlink.net>...
>in my skull.
>difference{
>  #end
No need to use trig... translate and rotate work just fine.  Put the column
at the xz origin and cut the grooves out using translate and rotate.
Attached find an include file I made for 3.02 (should work with 3.1).  It's
kinda crude, but it works.  Instructions in the header of the file.
See some examples of my column at:
http://www.geocities.com/SiliconValley/Heights/2354/gallery/columns.jpg
http://www.geocities.com/SiliconValley/Heights/2354/gallery/column_field.jpg
http://www.geocities.com/SiliconValley/Heights/2354/gallery/column_fancy.jpg
Eric
Download 'column.inc.txt' (3 KB)
