POV-Ray : Newsgroups : povray.binaries.scene-files : .inc for generating axes Server Time
11 Jun 2026 02:39:51 EDT (-0400)
  .inc for generating axes (Message 1 to 1 of 1)
Subject: .inc for generating axes
Date: 23 Apr 1998 02:16:02
Message: <353EDCA2.2C5F8DFE@ssvec.org>
This is the inc I should have used for the program I posted over in
binaries.utilities, but I didn't make it until I had finished the
program. (sigh all that work gone to waste ;(.
    Oh well, anyway all  the instructions are right inside the inc, any
comments, questions, abuse etc..... are most welcome.
//Axes by KillFile
#include "colors.inc" // Standard Color definitions
#include "textures.inc" // Standard Texture definitions
#include "jewels.inc"
#include "gem.inc"
//Just declare a blade (single or double) a holder, and a haft, and a
gem if you want.
declare Double_Blade =
//This union makes the enitire blade
union{
//this makes the blade
difference{
// create a sphere shape
sphere
  <0, 1, 0> // center of sphere <X Y Z>
  2       // radius of sphere
  scale <1,1,.3> // <= Note: Spheres can become ellipses by uneven
scaling
//This creates the edge of the blade on one side
torus
  2.05,
  0.75
rotate 90*x
translate -.6*z
translate 1*y}
//This creates the edge of the blade on the other side
torus
  2.05,
  0.75
rotate 90*x
translate .6*z
translate 1*y}
//These two cylinders create the cutous from the blade so it's not just
a complete circle
cylinder
  1*z,  -1*z, 1
  translate -.2*y
  // open
cylinder
  1*z,  -1*z, 1
  translate 2.2*y
  // open
scale .25*z}
//the blade ends here
declare Holder =
//the holder for the haft
cylinder
  .5*y,  1.5*y, .3
declare Single_Blade =
union{
difference{
sphere
scaling
torus
  2.05,
  0.75
rotate 90*x
translate -.6*z
translate 1*y}
torus
  2.05,
  0.75
rotate 90*x
translate .6*z
translate 1*y}
a complete circle
cylinder
  1*z,  -1*z, 1
  translate -.2*y
  // open
cylinder
  1*z,  -1*z, 1
  translate 2.2*y
box
  <-1, -2, -1>  // one corner position <X1 Y1 Z1>
  < 1,  2,  1>  // other corner position <X2 Y2 Z2>
translate 1*x
translate 1*y
scale .25*z}}
//This is the declaration for the gem
#declare facets=union{
#declare facet=box
  <-1, .8, -1>  // one corner position <X1 Y1 Z1>
  < 1,  1,  1>  // other corner position <X2 Y2 Z2>
rotate 55*z
translate .35*y
object {facet}
object {facet rotate 90*y}
object {facet rotate 180*y}
object {facet rotate 270*y}
object {facet rotate 45*y}
object {facet rotate 135*y}
object {facet rotate 225*y}
object {facet rotate 315*y}
#declare facet2=box
rotate 40*z
translate .52*y
object {facet2}
object {facet2 rotate 90*y}
object {facet2 rotate 180*y}
object {facet2 rotate 270*y}
object {facet2 rotate 45*y}
object {facet2 rotate 135*y}
object {facet2 rotate 225*y}
object {facet2 rotate 315*y}
#declare facet3=box
rotate 15*z
translate .65*y
object {facet3}
object {facet3 rotate 90*y}
object {facet3 rotate 180*y}
object {facet3 rotate 270*y}
object {facet3 rotate 45*y}
object {facet3 rotate 135*y}
object {facet3 rotate 225*y}
object {facet3 rotate 315*y}
#declare GEM=difference{
difference{
sphere
  0.5       // radius of sphere
object {facets}
object {facets rotate 15*y}}
// create a box that extends between the 2 specified points
box
  <-1, -1, -1>  // one corner position <X1 Y1 Z1>
  translate .1*y
scale <.6,1,.6>
translate .4*y}
//The Gem Declaration End here
declare Haft =
//This is the haft
union{
cylinder
  -6*y,  1.5*y, .2
sphere {
<0,-6,0>,.2}}
