POV-Ray : Newsgroups : povray.binaries.scene-files : Newbee question Server Time
16 May 2026 23:39:50 EDT (-0400)
  Newbee question (Message 1 to 3 of 3)
Subject: Newbee question
Date: 15 Jan 1998 01:51:33
Message: <34bdbfd2.0@news.povray.org>
G'day from Vancouver BC, I've just started working with Povray ( within the
last 2 weeks ), following examples, reading the docs and reading the news
groups. I've come upon a problem with using the, "union", modifier to join
multiple meshes. Here's the code for one mesh, ( sorry it's so big but I was
using Rhino to create the object and then exported as a POV mesh object .The
whole .pov is about 360Kbytes.
As you can see from the end statements I'm trying to combine 6 objects into
one object, which I can then modify as a single entity. Povray stops at the
second line in the union statement and says, "...no matching } in union,
object identifier found instead "
Is the union statement incorrect or can I not use meshes in this manner ?
Flag6_mesh and all the other objects do work properly if I don't define them
as objects and then use union or merge.
Any ideas ?
#declare Flag6_mesh = object {
mesh {
   smooth_triangle { <-16.565, 20.5055, 9.01536>, <7.10543e-014, 1,
1.7053e-013>, <-17.2134, 20.5055, 8.27083>, <1.42109e-014, 1, -1.7053e-013>,
<-16.444, 20.5055, 8.42997>, <1.13687e-013, 1, -1.06581e-014> }
1.7053e-013>, <-17.3345, 20.5055, 8.85622>, <-1.42109e-014, 1,
1.93623e-013>, <-17.2134, 20.5055, 8.27083>, <1.42109e-014,
1, -1.7053e-013> }
   smooth_triangle { <-5.7642, 20.5055, 10.0197>, <-5.32907e-015,
1, -1.77636e-013>, <-6.39292, 20.5055, 9.27061>, <1.24345e-013,
1, -3.19744e-014>, <-5.64142, 20.5055, 9.42603>, <8.17124e-014,
1, -9.76996e-014> }
1, -1.77636e-013>, <-6.5157, 20.5055, 9.86427>, <-4.9738e-014, 1,
5.15143e-014>, <-6.39292, 20.5055, 9.27061>, <1.24345e-013,
1, -3.19744e-014> }
   smooth_triangle { <-8.62577, 20.5055, 12.4886>, <1.19016e-013, 1,
2.30926e-013>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013>, <-8.5047, 20.5055, 11.9032>, <7.99361e-014,
1, -5.15143e-014> }
2.30926e-013>, <-9.37727, 20.5055, 12.3332>, <6.92779e-014, 1,
4.79616e-014>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013> }
   smooth_triangle { <-8.38363, 20.5055, 11.3179>, <7.81597e-014,
1, -2.80664e-013>, <-8.5047, 20.5055, 11.9032>, <7.99361e-014,
1, -5.15143e-014>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013> }
   smooth_triangle { <-17.9857, 20.5055, 8.12537>, <-4.76064e-013,
1, -1.20792e-013>, <-17.3904, 20.5055, 7.42812>, <1.56319e-013,
1, -7.37188e-014>, <-17.2134, 20.5055, 8.27083>, <1.42109e-014,
1, -1.7053e-013> }
   smooth_triangle { <-17.3904, 20.5055, 7.42812>, <1.56319e-013,
1, -7.37188e-014>, <-16.7951, 20.5055, 6.73088>, <1.20792e-013, 1,
9.0683e-013>, <-16.2126, 20.5055, 7.42942>, <-1.06581e-013,
1, -9.68114e-014> }
   smooth_triangle { <-16.2126, 20.5055, 7.42942>, <-1.06581e-013,
1, -9.68114e-014>, <-15.63, 20.5055, 8.12797>, <7.10543e-014,
1, -2.13163e-014>, <-16.444, 20.5055, 8.42997>, <1.13687e-013,
1, -1.06581e-014> }
   smooth_triangle { <-15.63, 20.5055, 8.12797>, <7.10543e-014,
1, -2.13163e-014>, <-14.6386, 20.5055, 6.83428>, <2.84217e-014, 1,
7.99361e-015>, <-13.7803, 20.5055, 8.40506>, <3.73035e-014, 1,
5.86198e-014> }
   smooth_triangle { <-14.6386, 20.5055, 6.83428>, <2.84217e-014, 1,
7.99361e-015>, <-13.6472, 20.5055, 5.5406>, <-9.05942e-014,
1, -3.01981e-014>, <-12.7843, 20.5055, 7.2696>, <-1.42109e-014, 1,
9.76996e-014> }
   smooth_triangle { <-13.6472, 20.5055, 5.5406>, <-9.05942e-014,
1, -3.01981e-014>, <-12.6558, 20.5055, 4.24691>, <3.53495e-013,
1, -1.06937e-012>, <-11.8522, 20.5055, 5.94001>, <2.32703e-013,
1, -1.32339e-013> }
   smooth_triangle { <-11.8522, 20.5055, 5.94001>, <2.32703e-013,
1, -1.32339e-013>, <-11.0487, 20.5055, 7.63312>, <5.86198e-014,
1, -6.66134e-014>, <-12.7843, 20.5055, 7.2696>, <-1.42109e-014, 1,
9.76996e-014> }
   smooth_triangle { <-11.0487, 20.5055, 7.63312>, <5.86198e-014,
1, -6.66134e-014>, <-10.2451, 20.5055, 9.32622>, <-8.88178e-015, 1,
1.06581e-013>, <-11.9825, 20.5055, 9.12187>, <-5.15143e-014,
1, -1.10134e-013> }
   smooth_triangle { <-10.2451, 20.5055, 9.32622>, <-8.88178e-015, 1,
1.06581e-013>, <-9.44159, 20.5055, 11.0193>, <4.08562e-014,
1, -2.27374e-013>, <-11.1807, 20.5055, 10.9741>, <-7.99361e-014, 1,
2.06057e-013> }
   smooth_triangle { <-9.44159, 20.5055, 11.0193>, <4.08562e-014,
1, -2.27374e-013>, <-8.69627, 20.5055, 10.0706>, <5.15143e-014, 1,
1.29674e-013>, <-8.38363, 20.5055, 11.3179>, <7.81597e-014,
1, -2.80664e-013> }
   smooth_triangle { <-8.69627, 20.5055, 10.0706>, <5.15143e-014, 1,
1.29674e-013>, <-7.95094, 20.5055, 9.12187>, <-3.55271e-015, 1,
1.75859e-013>, <-7.63474, 20.5055, 9.57365>, <-4.61853e-014, 1,
3.35731e-013> }
   smooth_triangle { <-7.63474, 20.5055, 9.57365>, <-4.61853e-014, 1,
3.35731e-013>, <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
1.29674e-013> }
   smooth_triangle { <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
2.27374e-013>, <-6.16668, 20.5055, 8.51198>, <-1.26121e-013,
1, -3.09086e-013>, <-6.39292, 20.5055, 9.27061>, <1.24345e-013,
1, -3.19744e-014> }
   smooth_triangle { <-6.16668, 20.5055, 8.51198>, <-1.26121e-013,
1, -3.09086e-013>, <-5.01482, 20.5055, 6.99853>, <1.54987e-012,
1, -1.66178e-012>, <-3.99091, 20.5055, 8.08313>, <1.32605e-012,
1, -9.69891e-013> }
   smooth_triangle { <-3.99091, 20.5055, 8.08313>, <1.32605e-012,
1, -9.69891e-013>, <-2.96699, 20.5055, 9.16772>, <1.33404e-012,
1, -1.0818e-012>, <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013> }
   smooth_triangle { <-2.96699, 20.5055, 9.16772>, <1.33404e-012,
1, -1.0818e-012>, <-2.97451, 20.5055, 10.4535>, <2.27374e-013, 1,
3.90799e-013>, <-4.21677, 20.5055, 10.1148>, <-8.26006e-014,
1, -5.32907e-015> }
   smooth_triangle { <-2.97451, 20.5055, 10.4535>, <2.27374e-013, 1,
3.90799e-013>, <-2.98203, 20.5055, 11.7394>, <-3.57048e-013,
1, -1.19194e-012>, <-3.5994, 20.5055, 10.9271>, <1.96287e-013, 1,
8.17124e-014> }
   smooth_triangle { <-3.5994, 20.5055, 10.9271>, <1.96287e-013, 1,
8.17124e-014>, <-4.21677, 20.5055, 10.1148>, <-8.26006e-014,
1, -5.32907e-015>, <-2.97451, 20.5055, 10.4535>, <2.27374e-013, 1,
3.90799e-013> }
   smooth_triangle { <-4.21677, 20.5055, 10.1148>, <-8.26006e-014,
1, -5.32907e-015>, <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013>, <-2.96699, 20.5055, 9.16772>, <1.33404e-012,
1, -1.0818e-012> }
   smooth_triangle { <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013>, <-5.986, 20.5055, 10.816>, <-1.803e-013, 1, 9.59233e-014>,
<-5.7642, 20.5055, 10.0197>, <-5.32907e-015, 1, -1.77636e-013> }
   smooth_triangle { <-5.986, 20.5055, 10.816>, <-1.803e-013, 1,
9.59233e-014>, <-7.13786, 20.5055, 12.3295>, <1.29674e-013,
1, -2.13163e-014>, <-7.43147, 20.5055, 11.9003>, <1.75859e-013,
1, -4.26326e-014> }
   smooth_triangle { <-7.43147, 20.5055, 11.9003>, <1.75859e-013,
1, -4.26326e-014>, <-7.72509, 20.5055, 11.4711>, <1.15463e-013,
1, -1.93623e-013>, <-5.986, 20.5055, 10.816>, <-1.803e-013, 1,
9.59233e-014> }
   smooth_triangle { <-7.72509, 20.5055, 11.4711>, <1.15463e-013,
1, -1.93623e-013>, <-8.34243, 20.5055, 12.5403>, <9.9476e-014, 1,
2.64677e-013>, <-8.5047, 20.5055, 11.9032>, <7.99361e-014,
1, -5.15143e-014> }
   smooth_triangle { <-8.34243, 20.5055, 12.5403>, <9.9476e-014, 1,
2.64677e-013>, <-8.95976, 20.5055, 13.6095>, <2.6823e-013, 1, 4.26326e-014>,
<-8.62577, 20.5055, 12.4886>, <1.19016e-013, 1, 2.30926e-013> }
   smooth_triangle { <-8.95976, 20.5055, 13.6095>, <2.6823e-013, 1,
4.26326e-014>, <-9.5771, 20.5055, 14.6787>, <-3.58824e-013, 1,
2.50466e-013>, <-10.3789, 20.5055, 12.8264>, <-4.88498e-013, 1,
1.9007e-013> }
   smooth_triangle { <-10.3789, 20.5055, 12.8264>, <-4.88498e-013, 1,
1.9007e-013>, <-11.1807, 20.5055, 10.9741>, <-7.99361e-014, 1,
2.06057e-013>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013> }
   smooth_triangle { <-11.1807, 20.5055, 10.9741>, <-7.99361e-014, 1,
2.06057e-013>, <-11.9825, 20.5055, 9.12187>, <-5.15143e-014,
1, -1.10134e-013>, <-10.2451, 20.5055, 9.32622>, <-8.88178e-015, 1,
1.06581e-013> }
   smooth_triangle { <-11.9825, 20.5055, 9.12187>, <-5.15143e-014,
1, -1.10134e-013>, <-12.7843, 20.5055, 7.2696>, <-1.42109e-014, 1,
9.76996e-014>, <-11.0487, 20.5055, 7.63312>, <5.86198e-014,
1, -6.66134e-014> }
   smooth_triangle { <-12.7843, 20.5055, 7.2696>, <-1.42109e-014, 1,
9.76996e-014>, <-13.7803, 20.5055, 8.40506>, <3.73035e-014, 1,
5.86198e-014>, <-14.6386, 20.5055, 6.83428>, <2.84217e-014, 1,
7.99361e-015> }
   smooth_triangle { <-13.7803, 20.5055, 8.40506>, <3.73035e-014, 1,
5.86198e-014>, <-14.7764, 20.5055, 9.54053>, <-6.39488e-014,
1, -1.33227e-013>, <-15.63, 20.5055, 8.12797>, <7.10543e-014,
1, -2.13163e-014> }
   smooth_triangle { <-14.7764, 20.5055, 9.54053>, <-6.39488e-014,
1, -1.33227e-013>, <-15.7725, 20.5055, 10.676>, <5.15143e-013, 1,
5.48894e-013>, <-16.2885, 20.5055, 9.9667>, <2.84217e-014,
1, -9.76996e-014> }
   smooth_triangle { <-16.2885, 20.5055, 9.9667>, <2.84217e-014,
1, -9.76996e-014>, <-16.8045, 20.5055, 9.2574>, <4.9738e-014, 1,
1.77636e-013>, <-16.565, 20.5055, 9.01536>, <7.10543e-014, 1, 1.7053e-013> }
   smooth_triangle { <-16.8045, 20.5055, 9.2574>, <4.9738e-014, 1,
1.77636e-013>, <-17.196, 20.5055, 9.72424>, <-3.55271e-014, 1, 0>,
<-17.3345, 20.5055, 8.85622>, <-1.42109e-014, 1, 1.93623e-013> }
   smooth_triangle { <-17.196, 20.5055, 9.72424>, <-3.55271e-014, 1, 0>,
<-17.5874, 20.5055, 10.1911>, <-2.13163e-013, 1, -3.67706e-013>, <-17.9823,
20.5055, 9.39164>, <-1.49214e-013, 1, 1.61648e-013> }
   smooth_triangle { <-17.5874, 20.5055, 10.1911>, <-2.13163e-013,
1, -3.67706e-013>, <-17.9789, 20.5055, 10.6579>, <-5.61329e-013,
1, -4.76064e-013>, <-17.9823, 20.5055, 9.39164>, <-1.49214e-013, 1,
1.61648e-013> }
   smooth_triangle { <-17.9823, 20.5055, 9.39164>, <-1.49214e-013, 1,
1.61648e-013>, <-17.9857, 20.5055, 8.12537>, <-4.76064e-013,
1, -1.20792e-013>, <-17.3345, 20.5055, 8.85622>, <-1.42109e-014, 1,
1.93623e-013> }
   smooth_triangle { <-17.3345, 20.5055, 8.85622>, <-1.42109e-014, 1,
1.93623e-013>, <-16.565, 20.5055, 9.01536>, <7.10543e-014, 1, 1.7053e-013>,
<-16.8045, 20.5055, 9.2574>, <4.9738e-014, 1, 1.77636e-013> }
   smooth_triangle { <-17.2134, 20.5055, 8.27083>, <1.42109e-014,
1, -1.7053e-013>, <-17.3345, 20.5055, 8.85622>, <-1.42109e-014, 1,
1.93623e-013>, <-17.9857, 20.5055, 8.12537>, <-4.76064e-013,
1, -1.20792e-013> }
   smooth_triangle { <-16.444, 20.5055, 8.42997>, <1.13687e-013,
1, -1.06581e-014>, <-17.2134, 20.5055, 8.27083>, <1.42109e-014,
1, -1.7053e-013>, <-16.2126, 20.5055, 7.42942>, <-1.06581e-013,
1, -9.68114e-014> }
1.7053e-013>, <-16.444, 20.5055, 8.42997>, <1.13687e-013, 1, -1.06581e-014>,
<-15.63, 20.5055, 8.12797>, <7.10543e-014, 1, -2.13163e-014> }
   smooth_triangle { <-6.5157, 20.5055, 9.86427>, <-4.9738e-014, 1,
5.15143e-014>, <-5.7642, 20.5055, 10.0197>, <-5.32907e-015,
1, -1.77636e-013>, <-5.986, 20.5055, 10.816>, <-1.803e-013, 1,
9.59233e-014> }
   smooth_triangle { <-6.39292, 20.5055, 9.27061>, <1.24345e-013,
1, -3.19744e-014>, <-6.5157, 20.5055, 9.86427>, <-4.9738e-014, 1,
5.15143e-014>, <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
2.27374e-013> }
   smooth_triangle { <-5.64142, 20.5055, 9.42603>, <8.17124e-014,
1, -9.76996e-014>, <-6.39292, 20.5055, 9.27061>, <1.24345e-013,
1, -3.19744e-014>, <-6.16668, 20.5055, 8.51198>, <-1.26121e-013,
1, -3.09086e-013> }
1, -1.77636e-013>, <-5.64142, 20.5055, 9.42603>, <8.17124e-014,
1, -9.76996e-014>, <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013> }
   smooth_triangle { <-9.37727, 20.5055, 12.3332>, <6.92779e-014, 1,
4.79616e-014>, <-8.62577, 20.5055, 12.4886>, <1.19016e-013, 1,
2.30926e-013>, <-8.95976, 20.5055, 13.6095>, <2.6823e-013, 1,
4.26326e-014> }
   smooth_triangle { <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013>, <-9.37727, 20.5055, 12.3332>, <6.92779e-014, 1,
4.79616e-014>, <-10.3789, 20.5055, 12.8264>, <-4.88498e-013, 1,
1.9007e-013> }
2.30926e-013>, <-8.5047, 20.5055, 11.9032>, <7.99361e-014,
1, -5.15143e-014>, <-8.34243, 20.5055, 12.5403>, <9.9476e-014, 1,
2.64677e-013> }
   smooth_triangle { <-8.5047, 20.5055, 11.9032>, <7.99361e-014,
1, -5.15143e-014>, <-8.38363, 20.5055, 11.3179>, <7.81597e-014,
1, -2.80664e-013>, <-7.72509, 20.5055, 11.4711>, <1.15463e-013,
1, -1.93623e-013> }
1, -2.80664e-013>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013>, <-9.44159, 20.5055, 11.0193>, <4.08562e-014,
1, -2.27374e-013> }
1, -1.7053e-013>, <-17.3904, 20.5055, 7.42812>, <1.56319e-013,
1, -7.37188e-014>, <-16.2126, 20.5055, 7.42942>, <-1.06581e-013,
1, -9.68114e-014> }
9.76996e-014>, <-13.6472, 20.5055, 5.5406>, <-9.05942e-014,
1, -3.01981e-014>, <-11.8522, 20.5055, 5.94001>, <2.32703e-013,
1, -1.32339e-013> }
2.06057e-013>, <-9.44159, 20.5055, 11.0193>, <4.08562e-014,
1, -2.27374e-013>, <-9.2562, 20.5055, 11.7478>, <1.06581e-014,
1, -1.58096e-013> }
1, -2.80664e-013>, <-8.69627, 20.5055, 10.0706>, <5.15143e-014, 1,
1.29674e-013>, <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
2.27374e-013> }
1, -3.09086e-013>, <-3.99091, 20.5055, 8.08313>, <1.32605e-012,
1, -9.69891e-013>, <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013> }
9.59233e-014>, <-7.72509, 20.5055, 11.4711>, <1.15463e-013,
1, -1.93623e-013>, <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
2.27374e-013> }
4.26326e-014>, <-10.3789, 20.5055, 12.8264>, <-4.88498e-013, 1,
1.9007e-013>, <-9.37727, 20.5055, 12.3332>, <6.92779e-014, 1,
4.79616e-014> }
1, -2.13163e-014>, <-14.7764, 20.5055, 9.54053>, <-6.39488e-014,
1, -1.33227e-013>, <-16.565, 20.5055, 9.01536>, <7.10543e-014, 1,
1.7053e-013> }
1, -1.33227e-013>, <-16.2885, 20.5055, 9.9667>, <2.84217e-014,
1, -9.76996e-014>, <-16.565, 20.5055, 9.01536>, <7.10543e-014, 1,
1.7053e-013> }
1.93623e-013>, <-17.196, 20.5055, 9.72424>, <-3.55271e-014, 1, 0>,
<-17.9823, 20.5055, 9.39164>, <-1.49214e-013, 1, 1.61648e-013> }
5.15143e-014>, <-5.986, 20.5055, 10.816>, <-1.803e-013, 1, 9.59233e-014>,
<-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1, 2.27374e-013> }
1, -9.76996e-014>, <-6.16668, 20.5055, 8.51198>, <-1.26121e-013,
1, -3.09086e-013>, <-4.83414, 20.5055, 9.30258>, <-1.29674e-013, 1,
1.10134e-013> }
1, -1.93623e-013>, <-8.38363, 20.5055, 11.3179>, <7.81597e-014,
1, -2.80664e-013>, <-7.31855, 20.5055, 10.0254>, <-1.20792e-013, 1,
2.27374e-013> }
   smooth_triangle { <-16.565, 21.4924, 9.01536>,
<-7.10543e-014, -1, -1.7053e-013>, <-17.2134, 21.4924, 8.27083>,
<-7.10543e-015, -1, 1.66978e-013>, <-17.3345, 21.4924, 8.85622>,
<1.42109e-014, -1, -1.93623e-013> }
<-7.10543e-014, -1, -1.7053e-013>, <-16.444, 21.4924, 8.42997>,
<-1.13687e-013, -1, 1.06581e-014>, <-17.2134, 21.4924, 8.27083>,
<-7.10543e-015, -1, 1.66978e-013> }
   smooth_triangle { <-5.7642, 21.4924, 10.0197>, <5.32907e-015, -1,
1.75859e-013>, <-6.39292, 21.4924, 9.27061>, <-1.24345e-013, -1,
3.55271e-014>, <-6.5157, 21.4924, 9.86427>,
<4.9738e-014, -1, -5.15143e-014> }
1.75859e-013>, <-5.64142, 21.4924, 9.42603>, <-8.17124e-014, -1, 9.59233e-01
4>, <-6.39292, 21.4924, 9.27061>, <-1.24345e-013, -1, 3.55271e-014> }
   smooth_triangle { <-8.62577, 21.4924, 12.4886>,
<-1.19016e-013, -1, -2.30926e-013>, <-9.2562, 21.4924, 11.7478>,
<-1.06581e-014, -1, 1.58096e-013>, <-9.37727, 21.4924, 12.3332>,
<-6.92779e-014, -1, -4.79616e-014> }
<-1.19016e-013, -1, -2.30926e-013>, <-8.5047, 21.4924, 11.9032>,
<-7.99361e-014, -1, 5.15143e-014>, <-9.2562, 21.4924, 11.7478>,
<-1.06581e-014, -1, 1.58096e-013> }
   smooth_triangle { <-8.38363, 21.4924, 11.3179>, <-7.81597e-014, -1,
2.80664e-013>, <-9.2562, 21.4924, 11.7478>, <-1.06581e-014, -1,
1.58096e-013>, <-8.5047, 21.4924, 11.9032>, <-7.99361e-014, -1,
5.15143e-014> }
   smooth_triangle { <-17.9857, 21.4924, 8.12537>, <4.68958e-013, -1,
1.20792e-013>, <-17.2134, 21.4924, 8.27083>, <-7.10543e-015, -1,
1.66978e-013>, <-17.3904, 21.4924, 7.42812>, <-1.63425e-013, -1,
7.4607e-014> }
   smooth_triangle { <-17.3904, 21.4924, 7.42812>, <-1.63425e-013, -1,
7.4607e-014>, <-16.2126, 21.4924, 7.42942>, <1.06581e-013, -1,
9.59233e-014>, <-16.7951, 21.4924, 6.73088>,
<-1.27898e-013, -1, -9.0683e-013> }
   smooth_triangle { <-16.2126, 21.4924, 7.42942>, <1.06581e-013, -1,
9.59233e-014>, <-16.444, 21.4924, 8.42997>, <-1.13687e-013, -1,
1.06581e-014>, <-15.63, 21.4924, 8.12797>, <-7.10543e-014, -1,
2.13163e-014> }
   smooth_triangle { <-15.63, 21.4924, 8.12797>, <-7.10543e-014, -1,
2.13163e-014>, <-13.7803, 21.4924, 8.40506>,
<-3.73035e-014, -1, -5.86198e-014>, <-14.6386, 21.4924, 6.83428>,
<-2.4869e-014, -1, -9.76996e-015> }
   smooth_triangle { <-14.6386, 21.4924, 6.83428>,
<-2.4869e-014, -1, -9.76996e-015>, <-12.7843, 21.4924, 7.2696>,
<1.59872e-014, -1, -9.76996e-014>, <-13.6472, 21.4924, 5.5406>,
<9.05942e-014, -1, 3.01981e-014> }
   smooth_triangle { <-13.6472, 21.4924, 5.5406>, <9.05942e-014, -1,
3.01981e-014>, <-11.8522, 21.4924, 5.94001>, <-2.32703e-013, -1,
1.32339e-013>, <-12.6558, 21.4924, 4.24691>, <-3.53495e-013, -1,
1.06937e-012> }
   smooth_triangle { <-11.8522, 21.4924, 5.94001>, <-2.32703e-013, -1,
1.32339e-013>, <-12.7843, 21.4924, 7.2696>,
<1.59872e-014, -1, -9.76996e-014>, <-11.0487, 21.4924, 7.63312>,
<-6.03961e-014, -1, 6.66134e-014> }
   smooth_triangle { <-11.0487, 21.4924, 7.63312>, <-6.03961e-014, -1,
6.66134e-014>, <-11.9825, 21.4924, 9.12187>, <4.9738e-014, -1,
1.10134e-013>, <-10.2451, 21.4924, 9.32622>,
<8.88178e-015, -1, -1.10134e-013> }
   smooth_triangle { <-10.2451, 21.4924, 9.32622>,
<8.88178e-015, -1, -1.10134e-013>, <-11.1807, 21.4924, 10.9741>,
<8.17124e-014, -1, -2.04281e-013>, <-9.44159, 21.4924, 11.0193>,
<-3.90799e-014, -1, 2.27374e-013> }
   smooth_triangle { <-9.44159, 21.4924, 11.0193>, <-3.90799e-014, -1,
2.27374e-013>, <-8.38363, 21.4924, 11.3179>, <-7.81597e-014, -1,
2.80664e-013>, <-8.69627, 21.4924, 10.0706>,
<-4.9738e-014, -1, -1.29674e-013> }
   smooth_triangle { <-8.69627, 21.4924, 10.0706>,
<-4.9738e-014, -1, -1.29674e-013>, <-7.63474, 21.4924, 9.57365>,
<4.79616e-014, -1, -3.33955e-013>, <-7.95094, 21.4924, 9.12187>,
<3.55271e-015, -1, -1.75859e-013> }
   smooth_triangle { <-7.63474, 21.4924, 9.57365>,
<4.79616e-014, -1, -3.33955e-013>, <-8.69627, 21.4924, 10.0706>,
<-4.9738e-014, -1, -1.29674e-013>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013> }
   smooth_triangle { <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-6.39292, 21.4924, 9.27061>,
<-1.24345e-013, -1, 3.55271e-014>, <-6.16668, 21.4924, 8.51198>,
<1.25233e-013, -1, 3.10862e-013> }
   smooth_triangle { <-6.16668, 21.4924, 8.51198>, <1.25233e-013, -1,
3.10862e-013>, <-3.99091, 21.4924, 8.08313>, <-1.32605e-012, -1,
9.69891e-013>, <-5.01482, 21.4924, 6.99853>, <-1.54987e-012, -1,
1.66267e-012> }
   smooth_triangle { <-3.99091, 21.4924, 8.08313>, <-1.32605e-012, -1,
9.69891e-013>, <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013>, <-2.96699, 21.4924, 9.16772>,
<-1.33493e-012, -1, 1.0818e-012> }
   smooth_triangle { <-2.96699, 21.4924, 9.16772>, <-1.33493e-012, -1,
1.0818e-012>, <-4.21677, 21.4924, 10.1148>, <8.34888e-014, -1,
5.32907e-015>, <-2.97451, 21.4924, 10.4535>,
<-2.27374e-013, -1, -3.90799e-013> }
   smooth_triangle { <-2.97451, 21.4924, 10.4535>,
<-2.27374e-013, -1, -3.90799e-013>, <-3.5994, 21.4924, 10.9271>,
<-1.97176e-013, -1, -8.17124e-014>, <-2.98203, 21.4924, 11.7394>,
<3.57048e-013, -1, 1.19194e-012> }
   smooth_triangle { <-3.5994, 21.4924, 10.9271>,
<-1.97176e-013, -1, -8.17124e-014>, <-2.97451, 21.4924, 10.4535>,
<-2.27374e-013, -1, -3.90799e-013>, <-4.21677, 21.4924, 10.1148>,
<8.34888e-014, -1, 5.32907e-015> }
   smooth_triangle { <-4.21677, 21.4924, 10.1148>, <8.34888e-014, -1,
5.32907e-015>, <-2.96699, 21.4924, 9.16772>, <-1.33493e-012, -1,
1.0818e-012>, <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013> }
   smooth_triangle { <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013>, <-5.7642, 21.4924, 10.0197>,
<5.32907e-015, -1, 1.75859e-013>, <-5.986, 21.4924, 10.816>,
<1.82077e-013, -1, -9.41469e-014> }
   smooth_triangle { <-5.986, 21.4924, 10.816>,
<1.82077e-013, -1, -9.41469e-014>, <-7.43147, 21.4924, 11.9003>,
<-1.75859e-013, -1, 4.08562e-014>, <-7.13786, 21.4924, 12.3295>,
<-1.3145e-013, -1, 2.13163e-014> }
   smooth_triangle { <-7.43147, 21.4924, 11.9003>, <-1.75859e-013, -1,
4.08562e-014>, <-5.986, 21.4924, 10.816>, <1.82077e-013, -1, -9.41469e-014>,
<-7.72509, 21.4924, 11.4711>, <-1.15463e-013, -1, 1.95399e-013> }
   smooth_triangle { <-7.72509, 21.4924, 11.4711>, <-1.15463e-013, -1,
1.95399e-013>, <-8.5047, 21.4924, 11.9032>, <-7.99361e-014, -1,
5.15143e-014>, <-8.34243, 21.4924, 12.5403>,
<-1.01252e-013, -1, -2.64677e-013> }
   smooth_triangle { <-8.34243, 21.4924, 12.5403>,
<-1.01252e-013, -1, -2.64677e-013>, <-8.62577, 21.4924, 12.4886>,
<-1.19016e-013, -1, -2.30926e-013>, <-8.95976, 21.4924, 13.6095>,
<-2.70006e-013, -1, -4.44089e-014> }
   smooth_triangle { <-8.95976, 21.4924, 13.6095>,
<-2.70006e-013, -1, -4.44089e-014>, <-10.3789, 21.4924, 12.8264>,
<4.88498e-013, -1, -1.9007e-013>, <-9.5771, 21.4924, 14.6787>,
<3.58824e-013, -1, -2.50466e-013> }
   smooth_triangle { <-10.3789, 21.4924, 12.8264>,
<4.88498e-013, -1, -1.9007e-013>, <-9.2562, 21.4924, 11.7478>,
<-1.06581e-014, -1, 1.58096e-013>, <-11.1807, 21.4924, 10.9741>,
<8.17124e-014, -1, -2.04281e-013> }
   smooth_triangle { <-11.1807, 21.4924, 10.9741>,
<8.17124e-014, -1, -2.04281e-013>, <-10.2451, 21.4924, 9.32622>,
<8.88178e-015, -1, -1.10134e-013>, <-11.9825, 21.4924, 9.12187>,
<4.9738e-014, -1, 1.10134e-013> }
   smooth_triangle { <-11.9825, 21.4924, 9.12187>, <4.9738e-014, -1,
1.10134e-013>, <-11.0487, 21.4924, 7.63312>, <-6.03961e-014, -1,
6.66134e-014>, <-12.7843, 21.4924, 7.2696>,
<1.59872e-014, -1, -9.76996e-014> }
   smooth_triangle { <-12.7843, 21.4924, 7.2696>,
<1.59872e-014, -1, -9.76996e-014>, <-14.6386, 21.4924, 6.83428>,
<-2.4869e-014, -1, -9.76996e-015>, <-13.7803, 21.4924, 8.40506>,
<-3.73035e-014, -1, -5.86198e-014> }
   smooth_triangle { <-13.7803, 21.4924, 8.40506>,
<-3.73035e-014, -1, -5.86198e-014>, <-15.63, 21.4924, 8.12797>,
<-7.10543e-014, -1, 2.13163e-014>, <-14.7764, 21.4924, 9.54053>,
<6.39488e-014, -1, 1.33227e-013> }
   smooth_triangle { <-14.7764, 21.4924, 9.54053>, <6.39488e-014, -1,
1.33227e-013>, <-16.2885, 21.4924, 9.9667>, <-2.13163e-014, -1,
9.76996e-014>, <-15.7725, 21.4924, 10.676>,
<-5.15143e-013, -1, -5.48894e-013> }
   smooth_triangle { <-16.2885, 21.4924, 9.9667>, <-2.13163e-014, -1,
9.76996e-014>, <-16.565, 21.4924, 9.01536>,
<-7.10543e-014, -1, -1.7053e-013>, <-16.8045, 21.4924, 9.2574>,
<-5.68434e-014, -1, -1.75859e-013> }
   smooth_triangle { <-16.8045, 21.4924, 9.2574>,
<-5.68434e-014, -1, -1.75859e-013>, <-17.3345, 21.4924, 8.85622>,
<1.42109e-014, -1, -1.93623e-013>, <-17.196, 21.4924, 9.72424>,
<3.55271e-014, -1, -1.77636e-015> }
   smooth_triangle { <-17.196, 21.4924, 9.72424>,
<3.55271e-014, -1, -1.77636e-015>, <-17.9823, 21.4924, 9.39164>,
<1.42109e-013, -1, -1.59872e-013>, <-17.5874, 21.4924, 10.1911>,
<2.20268e-013, -1, 3.69482e-013> }
   smooth_triangle { <-17.5874, 21.4924, 10.1911>, <2.20268e-013, -1,
3.69482e-013>, <-17.9823, 21.4924, 9.39164>,
<1.42109e-013, -1, -1.59872e-013>, <-17.9789, 21.4924, 10.6579>,
<5.54223e-013, -1, 4.76064e-013> }
   smooth_triangle { <-17.9823, 21.4924, 9.39164>,
<1.42109e-013, -1, -1.59872e-013>, <-17.3345, 21.4924, 8.85622>,
<1.42109e-014, -1, -1.93623e-013>, <-17.9857, 21.4924, 8.12537>,
<4.68958e-013, -1, 1.20792e-013> }
   smooth_triangle { <-17.3345, 21.4924, 8.85622>,
<1.42109e-014, -1, -1.93623e-013>, <-16.8045, 21.4924, 9.2574>,
<-5.68434e-014, -1, -1.75859e-013>, <-16.565, 21.4924, 9.01536>,
<-7.10543e-014, -1, -1.7053e-013> }
   smooth_triangle { <-17.2134, 21.4924, 8.27083>, <-7.10543e-015, -1,
1.66978e-013>, <-17.9857, 21.4924, 8.12537>, <4.68958e-013, -1,
1.20792e-013>, <-17.3345, 21.4924, 8.85622>,
   smooth_triangle { <-16.444, 21.4924, 8.42997>, <-1.13687e-013, -1,
1.06581e-014>, <-16.2126, 21.4924, 7.42942>, <1.06581e-013, -1,
9.59233e-014>, <-17.2134, 21.4924, 8.27083>, <-7.10543e-015, -1,
1.66978e-013> }
<-7.10543e-014, -1, -1.7053e-013>, <-15.63, 21.4924, 8.12797>,
<-7.10543e-014, -1, 2.13163e-014>, <-16.444, 21.4924, 8.42997>,
<-1.13687e-013, -1, 1.06581e-014> }
   smooth_triangle { <-6.5157, 21.4924, 9.86427>,
<4.9738e-014, -1, -5.15143e-014>, <-5.986, 21.4924, 10.816>,
<1.82077e-013, -1, -9.41469e-014>, <-5.7642, 21.4924, 10.0197>,
<5.32907e-015, -1, 1.75859e-013> }
   smooth_triangle { <-6.39292, 21.4924, 9.27061>, <-1.24345e-013, -1,
3.55271e-014>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-6.5157, 21.4924, 9.86427>,
   smooth_triangle { <-5.64142, 21.4924, 9.42603>, <-8.17124e-014, -1,
9.59233e-014>, <-6.16668, 21.4924, 8.51198>, <1.25233e-013, -1,
3.10862e-013>, <-6.39292, 21.4924, 9.27061>, <-1.24345e-013, -1,
3.55271e-014> }
1.75859e-013>, <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013>, <-5.64142, 21.4924, 9.42603>,
<-8.17124e-014, -1, 9.59233e-014> }
   smooth_triangle { <-9.37727, 21.4924, 12.3332>,
<-6.92779e-014, -1, -4.79616e-014>, <-8.95976, 21.4924, 13.6095>,
<-2.70006e-013, -1, -4.44089e-014>, <-8.62577, 21.4924, 12.4886>,
<-1.19016e-013, -1, -2.30926e-013> }
   smooth_triangle { <-9.2562, 21.4924, 11.7478>, <-1.06581e-014, -1,
1.58096e-013>, <-10.3789, 21.4924, 12.8264>,
<4.88498e-013, -1, -1.9007e-013>, <-9.37727, 21.4924, 12.3332>,
<-1.19016e-013, -1, -2.30926e-013>, <-8.34243, 21.4924, 12.5403>,
<-1.01252e-013, -1, -2.64677e-013>, <-8.5047, 21.4924, 11.9032>,
<-7.99361e-014, -1, 5.15143e-014> }
   smooth_triangle { <-8.5047, 21.4924, 11.9032>, <-7.99361e-014, -1,
5.15143e-014>, <-7.72509, 21.4924, 11.4711>, <-1.15463e-013, -1,
1.95399e-013>, <-8.38363, 21.4924, 11.3179>, <-7.81597e-014, -1,
2.80664e-013> }
2.80664e-013>, <-9.44159, 21.4924, 11.0193>, <-3.90799e-014, -1,
2.27374e-013>, <-9.2562, 21.4924, 11.7478>, <-1.06581e-014, -1,
1.58096e-013> }
1.66978e-013>, <-16.2126, 21.4924, 7.42942>, <1.06581e-013, -1,
9.59233e-014>, <-17.3904, 21.4924, 7.42812>, <-1.63425e-013, -1,
7.4607e-014> }
<1.59872e-014, -1, -9.76996e-014>, <-11.8522, 21.4924, 5.94001>,
<-2.32703e-013, -1, 1.32339e-013>, <-13.6472, 21.4924, 5.5406>,
<8.17124e-014, -1, -2.04281e-013>, <-9.2562, 21.4924, 11.7478>,
<-1.06581e-014, -1, 1.58096e-013>, <-9.44159, 21.4924, 11.0193>,
2.80664e-013>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-8.69627, 21.4924, 10.0706>,
3.10862e-013>, <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013>, <-3.99091, 21.4924, 8.08313>,
<-1.32605e-012, -1, 9.69891e-013> }
<1.82077e-013, -1, -9.41469e-014>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-7.72509, 21.4924, 11.4711>,
<-2.70006e-013, -1, -4.44089e-014>, <-9.37727, 21.4924, 12.3332>,
<-6.92779e-014, -1, -4.79616e-014>, <-10.3789, 21.4924, 12.8264>,
<4.88498e-013, -1, -1.9007e-013> }
2.13163e-014>, <-16.565, 21.4924, 9.01536>,
<-7.10543e-014, -1, -1.7053e-013>, <-14.7764, 21.4924, 9.54053>,
1.33227e-013>, <-16.565, 21.4924, 9.01536>,
<-7.10543e-014, -1, -1.7053e-013>, <-16.2885, 21.4924, 9.9667>,
<-2.13163e-014, -1, 9.76996e-014> }
<1.42109e-014, -1, -1.93623e-013>, <-17.9823, 21.4924, 9.39164>,
<1.42109e-013, -1, -1.59872e-013>, <-17.196, 21.4924, 9.72424>,
<4.9738e-014, -1, -5.15143e-014>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-5.986, 21.4924, 10.816>,
9.59233e-014>, <-4.83414, 21.4924, 9.30258>,
<1.30562e-013, -1, -1.10134e-013>, <-6.16668, 21.4924, 8.51198>,
1.95399e-013>, <-7.31855, 21.4924, 10.0254>,
<1.20792e-013, -1, -2.27374e-013>, <-8.38363, 21.4924, 11.3179>,
<-7.81597e-014, -1, 2.80664e-013> }
   smooth_triangle { <-17.9857, 20.5055, 8.12537>, <0.760525, 0, 0.649309>,
<-17.9857, 21.4924, 8.12537>, <0.760525, 0, 0.649309>, <-17.3904, 20.5055,
7.42812>, <0.760525, 0, 0.649309> }
   smooth_triangle { <-17.3904, 20.5055, 7.42812>, <0.760525, 0, 0.649309>,
<-17.3904, 21.4924, 7.42812>, <0.760525, 0, 0.649309>, <-16.7951, 20.5055,
6.73088>, <0.760525, 0, 0.649309> }
   smooth_triangle { <-16.7951, 21.4924, 6.73088>, <0.760525, 0, 0.649309>,
<-16.7951, 20.5055, 6.73088>, <0.760525, 0, 0.649309>, <-17.3904, 21.4924,
   smooth_triangle { <-17.3904, 21.4924, 7.42812>, <0.760525, 0, 0.649309>,
<-17.3904, 20.5055, 7.42812>, <0.760525, 0, 0.649309>, <-17.9857, 21.4924,
8.12537>, <0.760525, 0, 0.649309> }
   smooth_triangle { <-16.7951, 20.5055, 6.73088>, <-0.767986, 0, 0.640467>,
<-16.2126, 21.4924, 7.42942>, <-0.767986, 0, 0.640467>, <-16.2126, 20.5055,
7.42942>, <-0.767986, 0, 0.640467> }
   smooth_triangle { <-16.2126, 20.5055, 7.42942>, <-0.767986, 0, 0.640467>,
<-15.63, 21.4924, 8.12797>, <-0.767986, 0, 0.640467>, <-15.63, 20.5055,
8.12797>, <-0.767986, 0, 0.640467> }
   smooth_triangle { <-15.63, 21.4924, 8.12797>, <-0.767986, 0, 0.640467>,
<-16.2126, 20.5055, 7.42942>, <-0.767986, 0, 0.640467>, <-16.2126, 21.4924,
   smooth_triangle { <-16.2126, 21.4924, 7.42942>, <-0.767986, 0, 0.640467>,
<-16.7951, 20.5055, 6.73088>, <-0.767986, 0, 0.640467>, <-16.7951, 21.4924,
6.73088>, <-0.767986, 0, 0.640467> }
   smooth_triangle { <-15.63, 20.5055, 8.12797>, <0.793728, 0, 0.608273>,
<-15.63, 21.4924, 8.12797>, <0.793728, 0, 0.608273>, <-14.6386, 20.5055,
6.83428>, <0.793728, 0, 0.608273> }
   smooth_triangle { <-14.6386, 20.5055, 6.83428>, <0.793728, 0, 0.608273>,
<-13.6472, 21.4924, 5.5406>, <0.793728, 0, 0.608273>, <-13.6472, 20.5055,
5.5406>, <0.793728, 0, 0.608273> }
   smooth_triangle { <-13.6472, 20.5055, 5.5406>, <0.793728, 0, 0.608273>,
<-13.6472, 21.4924, 5.5406>, <0.793728, 0, 0.608273>, <-12.6558, 20.5055,
4.24691>, <0.793728, 0, 0.608273> }
   smooth_triangle { <-12.6558, 21.4924, 4.24691>, <0.793728, 0, 0.608273>,
<-12.6558, 20.5055, 4.24691>, <0.793728, 0, 0.608273>, <-13.6472, 21.4924,
   smooth_triangle { <-13.6472, 21.4924, 5.5406>, <0.793728, 0, 0.608273>,
<-14.6386, 20.5055, 6.83428>, <0.793728, 0, 0.608273>, <-14.6386, 21.4924,
   smooth_triangle { <-14.6386, 21.4924, 6.83428>, <0.793728, 0, 0.608273>,
<-14.6386, 20.5055, 6.83428>, <0.793728, 0, 0.608273>, <-15.63, 21.4924,
8.12797>, <0.793728, 0, 0.608273> }
   smooth_triangle { <-12.6558, 20.5055, 4.24691>, <-0.903417, 0, 0.428762>,
<-11.8522, 21.4924, 5.94001>, <-0.903417, 0, 0.428762>, <-11.8522, 20.5055,
5.94001>, <-0.903417, 0, 0.428762> }
   smooth_triangle { <-11.8522, 20.5055, 5.94001>, <-0.903417, 0, 0.428762>,
<-11.0487, 21.4924, 7.63312>, <-0.903417, 0, 0.428762>, <-11.0487, 20.5055,
7.63312>, <-0.903417, 0, 0.428762> }
   smooth_triangle { <-11.0487, 20.5055, 7.63312>, <-0.903417, 0, 0.428762>,
<-10.2451, 21.4924, 9.32622>, <-0.903417, 0, 0.428762>, <-10.2451, 20.5055,
9.32622>, <-0.903417, 0, 0.428762> }
   smooth_triangle { <-10.2451, 20.5055, 9.32622>, <-0.903417, 0, 0.428762>,
<-9.44159, 21.4924, 11.0193>, <-0.903417, 0, 0.428762>, <-9.44159, 20.5055,
11.0193>, <-0.903417, 0, 0.428762> }
   smooth_triangle { <-9.44159, 21.4924, 11.0193>, <-0.903417, 0, 0.428762>,
<-10.2451, 20.5055, 9.32622>, <-0.903417, 0, 0.428762>, <-10.2451, 21.4924,
   smooth_triangle { <-10.2451, 21.4924, 9.32622>, <-0.903417, 0, 0.428762>,
<-11.0487, 20.5055, 7.63312>, <-0.903417, 0, 0.428762>, <-11.0487, 21.4924,
   smooth_triangle { <-11.0487, 21.4924, 7.63312>, <-0.903417, 0, 0.428762>,
<-11.8522, 20.5055, 5.94001>, <-0.903417, 0, 0.428762>, <-11.8522, 21.4924,
   smooth_triangle { <-11.8522, 21.4924, 5.94001>, <-0.903417, 0, 0.428762>,
<-12.6558, 20.5055, 4.24691>, <-0.903417, 0, 0.428762>, <-12.6558, 21.4924,
4.24691>, <-0.903417, 0, 0.428762> }
   smooth_triangle { <-9.44159, 20.5055, 11.0193>, <0.78636, 0, 0.617768>,
<-8.69627, 21.4924, 10.0706>, <0.78636, 0, 0.617768>, <-8.69627, 20.5055,
10.0706>, <0.78636, 0, 0.617768> }
   smooth_triangle { <-8.69627, 20.5055, 10.0706>, <0.78636, 0, 0.617768>,
<-7.95094, 20.999, 9.12187>, <0.78636, 0, 0.617768>, <-7.95094, 20.5055,
9.12187>, <0.78636, 0, 0.617768> }
   smooth_triangle { <-7.95094, 21.4924, 9.12187>, <0.78636, 0, 0.617768>,
<-7.95094, 20.999, 9.12187>, <0.78636, 0, 0.617768>, <-8.69627, 21.4924,
   smooth_triangle { <-8.69627, 21.4924, 10.0706>, <0.78636, 0, 0.617768>,
<-9.44159, 20.5055, 11.0193>, <0.78636, 0, 0.617768>, <-9.44159, 21.4924,
11.0193>, <0.78636, 0, 0.617768> }
<-7.95094, 20.999, 9.12187>, <0.78636, 0, 0.617768>, <-8.69627, 20.5055,
   smooth_triangle { <-7.95094, 20.5055, 9.12187>, <-0.81927, 0, 0.573408>,
<-7.95094, 20.999, 9.12187>, <-0.81927, 0, 0.573408>, <-7.63474, 20.5055,
9.57365>, <-0.81927, 0, 0.573408> }
   smooth_triangle { <-7.63474, 20.5055, 9.57365>, <-0.81927, 0, 0.573408>,
<-7.31855, 20.999, 10.0254>, <-0.81927, 0, 0.573408>, <-7.31855, 20.5055,
10.0254>, <-0.81927, 0, 0.573408> }
   smooth_triangle { <-7.31855, 21.4924, 10.0254>, <-0.81927, 0, 0.573408>,
<-7.31855, 20.999, 10.0254>, <-0.81927, 0, 0.573408>, <-7.63474, 21.4924,
   smooth_triangle { <-7.63474, 21.4924, 9.57365>, <-0.81927, 0, 0.573408>,
<-7.95094, 20.999, 9.12187>, <-0.81927, 0, 0.573408>, <-7.95094, 21.4924,
9.12187>, <-0.81927, 0, 0.573408> }
   smooth_triangle { <-7.95094, 20.999, 9.12187>, <-0.81927, 0, 0.573408>,
<-7.63474, 21.4924, 9.57365>, <-0.81927, 0, 0.573408>, <-7.63474, 20.5055,
<-7.63474, 21.4924, 9.57365>, <-0.81927, 0, 0.573408>, <-7.31855, 20.999,
   smooth_triangle { <-6.16668, 21.2457, 8.51198>, <0.795745, 0, 0.605632>,
<-6.74262, 20.999, 9.2687>, <0.795745, 0, 0.605632>, <-6.74262, 21.2457,
9.2687>, <0.795745, 0, 0.605632> }
<-6.16668, 20.999, 8.51198>, <0.795745, 0, 0.605632>, <-6.74262, 20.999,
   smooth_triangle { <-6.16668, 20.999, 8.51198>, <0.795745, 0, 0.605632>,
<-6.74262, 20.7522, 9.2687>, <0.795745, 0, 0.605632>, <-6.74262, 20.999,
<-6.16668, 20.7522, 8.51198>, <0.795745, 0, 0.605632>, <-6.74262, 20.7522,
   smooth_triangle { <-7.31855, 20.5055, 10.0254>, <0.795745, 0, 0.605632>,
<-6.74262, 20.7522, 9.2687>, <0.795745, 0, 0.605632>, <-6.16668, 20.5055,
8.51198>, <0.795745, 0, 0.605632> }
   smooth_triangle { <-6.16668, 20.5055, 8.51198>, <0.795745, 0, 0.605632>,
<-6.16668, 20.7522, 8.51198>, <0.795745, 0, 0.605632>, <-5.01482, 20.5055,
6.99853>, <0.795745, 0, 0.605632> }
   smooth_triangle { <-5.01482, 21.4924, 6.99853>, <0.795745, 0, 0.605632>,
<-6.16668, 21.2457, 8.51198>, <0.795745, 0, 0.605632>, <-6.16668, 21.4924,
   smooth_triangle { <-6.16668, 21.4924, 8.51198>, <0.795745, 0, 0.605632>,
<-6.74262, 21.2457, 9.2687>, <0.795745, 0, 0.605632>, <-7.31855, 21.4924,
10.0254>, <0.795745, 0, 0.605632> }
   smooth_triangle { <-7.31855, 21.4924, 10.0254>, <0.795745, 0, 0.605632>,
<-6.74262, 21.2457, 9.2687>, <0.795745, 0, 0.605632>, <-7.31855, 20.999,
   smooth_triangle { <-7.31855, 20.999, 10.0254>, <0.795745, 0, 0.605632>,
<-6.74262, 20.7522, 9.2687>, <0.795745, 0, 0.605632>, <-7.31855, 20.5055,
   smooth_triangle { <-5.01482, 20.5055, 6.99853>, <0.795745, 0, 0.605632>,
<-6.16668, 20.999, 8.51198>, <0.795745, 0, 0.605632>, <-5.01482, 21.4924,
   smooth_triangle { <-6.74262, 21.2457, 9.2687>, <0.795745, 0, 0.605632>,
<-6.16668, 21.4924, 8.51198>, <0.795745, 0, 0.605632>, <-6.16668, 21.2457,
   smooth_triangle { <-6.74262, 20.999, 9.2687>, <0.795745, 0, 0.605632>,
<-7.31855, 20.999, 10.0254>, <0.795745, 0, 0.605632>, <-6.74262, 21.2457,
<-5.01482, 21.4924, 6.99853>, <0.795745, 0, 0.605632>, <-6.16668, 20.999,
   smooth_triangle { <-6.74262, 20.7522, 9.2687>, <0.795745, 0, 0.605632>,
<-7.31855, 20.999, 10.0254>, <0.795745, 0, 0.605632>, <-6.74262, 20.999,
   smooth_triangle { <-6.16668, 20.7522, 8.51198>, <0.795745, 0, 0.605632>,
<-6.16668, 20.5055, 8.51198>, <0.795745, 0, 0.605632>, <-6.74262, 20.7522,
<-5.01482, 20.5055, 6.99853>, <0.795745, 0, 0.605632>, <-6.16668, 20.7522,
   smooth_triangle { <-5.01482, 20.5055, 6.99853>, <-0.727155, 0, 0.686473>,
<-5.01482, 21.4924, 6.99853>, <-0.727155, 0, 0.686473>, <-3.99091, 20.5055,
8.08313>, <-0.727155, 0, 0.686473> }
   smooth_triangle { <-3.99091, 20.5055, 8.08313>, <-0.727155, 0, 0.686473>,
<-3.99091, 21.4924, 8.08313>, <-0.727155, 0, 0.686473>, <-2.96699, 20.5055,
9.16772>, <-0.727155, 0, 0.686473> }
   smooth_triangle { <-2.96699, 21.4924, 9.16772>, <-0.727155, 0, 0.686473>,
<-2.96699, 20.5055, 9.16772>, <-0.727155, 0, 0.686473>, <-3.99091, 21.4924,
   smooth_triangle { <-3.99091, 21.4924, 8.08313>, <-0.727155, 0, 0.686473>,
<-3.99091, 20.5055, 8.08313>, <-0.727155, 0, 0.686473>, <-5.01482, 21.4924,
6.99853>, <-0.727155, 0, 0.686473> }
   smooth_triangle { <-2.96699, 20.5055, 9.16772>, <-0.999983,
0, -0.00584703>, <-2.96699, 21.4924, 9.16772>, <-0.999983, 0, -0.00584703>,
<-2.97451, 20.5055, 10.4535>, <-0.999983, 0, -0.00584703> }
   smooth_triangle { <-2.97451, 20.5055, 10.4535>, <-0.999983,
0, -0.00584703>, <-2.97451, 21.4924, 10.4535>, <-0.999983, 0, -0.00584703>,
<-2.98203, 20.5055, 11.7394>, <-0.999983, 0, -0.00584703> }
   smooth_triangle { <-2.98203, 21.4924, 11.7394>, <-0.999983,
0, -0.00584703>, <-2.98203, 20.5055, 11.7394>, <-0.999983, 0, -0.00584703>,
<-2.97451, 21.4924, 10.4535>, <-0.999983, 0, -0.00584703> }
   smooth_triangle { <-2.97451, 21.4924, 10.4535>, <-0.999983,
0, -0.00584703>, <-2.97451, 20.5055, 10.4535>, <-0.999983, 0, -0.00584703>,
<-2.96699, 21.4924, 9.16772>, <-0.999983, 0, -0.00584703> }
   smooth_triangle { <-2.98203, 20.5055, 11.7394>, <0.79614, 0, -0.605113>,
<-2.98203, 21.4924, 11.7394>, <0.79614, 0, -0.605113>, <-3.5994, 20.5055,
10.9271>, <0.79614, 0, -0.605113> }
   smooth_triangle { <-3.5994, 20.5055, 10.9271>, <0.79614, 0, -0.605113>,
<-3.5994, 21.4924, 10.9271>, <0.79614, 0, -0.605113>, <-4.21677, 20.5055,
10.1148>, <0.79614, 0, -0.605113> }
   smooth_triangle { <-4.21677, 20.5055, 10.1148>, <0.79614, 0, -0.605113>,
<-4.83414, 21.4924, 9.30258>, <0.79614, 0, -0.605113>, <-4.83414, 20.5055,
9.30258>, <0.79614, 0, -0.605113> }
   smooth_triangle { <-4.83414, 21.4924, 9.30258>, <0.79614, 0, -0.605113>,
<-4.21677, 20.5055, 10.1148>, <0.79614, 0, -0.605113>, <-4.21677, 21.4924,
   smooth_triangle { <-4.21677, 21.4924, 10.1148>, <0.79614, 0, -0.605113>,
<-4.21677, 20.5055, 10.1148>, <0.79614, 0, -0.605113>, <-3.5994, 21.4924,
   smooth_triangle { <-3.5994, 21.4924, 10.9271>, <0.79614, 0, -0.605113>,
<-3.5994, 20.5055, 10.9271>, <0.79614, 0, -0.605113>, <-2.98203, 21.4924,
11.7394>, <0.79614, 0, -0.605113> }
   smooth_triangle { <-6.56193, 21.2457, 11.5727>, <-0.795745,
0, -0.605632>, <-5.986, 20.999, 10.816>, <-0.795745, 0, -0.605632>, <-5.986,
21.2457, 10.816>, <-0.795745, 0, -0.605632> }
0, -0.605632>, <-6.56193, 20.999, 11.5727>, <-0.795745, 0, -0.605632>,
<-5.986, 20.999, 10.816>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-6.56193, 20.999, 11.5727>, <-0.795745, 0, -0.605632>,
<-5.986, 20.7522, 10.816>, <-0.795745, 0, -0.605632>, <-5.986, 20.999,
<-6.56193, 20.7522, 11.5727>, <-0.795745, 0, -0.605632>, <-5.986, 20.7522,
   smooth_triangle { <-4.83414, 20.5055, 9.30258>, <-0.795745,
0, -0.605632>, <-5.986, 20.7522, 10.816>, <-0.795745, 0, -0.605632>,
<-5.986, 20.5055, 10.816>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-5.986, 20.5055, 10.816>, <-0.795745, 0, -0.605632>,
<-6.56193, 20.7522, 11.5727>, <-0.795745, 0, -0.605632>, <-7.13786, 20.5055,
12.3295>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-7.13786, 21.4924, 12.3295>, <-0.795745,
0, -0.605632>, <-6.56193, 21.2457, 11.5727>, <-0.795745, 0, -0.605632>,
<-5.986, 21.4924, 10.816>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-5.986, 21.4924, 10.816>, <-0.795745, 0, -0.605632>,
<-5.986, 21.2457, 10.816>, <-0.795745, 0, -0.605632>, <-4.83414, 21.4924,
9.30258>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-4.83414, 21.4924, 9.30258>, <-0.795745,
<-4.83414, 20.5055, 9.30258>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-7.13786, 20.5055, 12.3295>, <-0.795745,
0, -0.605632>, <-6.56193, 20.7522, 11.5727>, <-0.795745, 0, -0.605632>,
<-7.13786, 20.999, 12.3295>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-7.13786, 20.999, 12.3295>, <-0.795745, 0, -0.605632>,
<-6.56193, 21.2457, 11.5727>, <-0.795745, 0, -0.605632>, <-7.13786, 21.4924,
   smooth_triangle { <-5.986, 21.2457, 10.816>, <-0.795745, 0, -0.605632>,
<-5.986, 21.4924, 10.816>, <-0.795745, 0, -0.605632>, <-6.56193, 21.2457,
11.5727>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-5.986, 20.999, 10.816>, <-0.795745, 0, -0.605632>,
<-4.83414, 21.4924, 9.30258>, <-0.795745, 0, -0.605632>, <-5.986, 21.2457,
0, -0.605632>, <-7.13786, 20.999, 12.3295>, <-0.795745, 0, -0.605632>,
<-6.56193, 20.999, 11.5727>, <-0.795745, 0, -0.605632> }
   smooth_triangle { <-5.986, 20.7522, 10.816>, <-0.795745, 0, -0.605632>,
<-4.83414, 20.5055, 9.30258>, <-0.795745, 0, -0.605632>, <-5.986, 20.999,
   smooth_triangle { <-6.56193, 20.7522, 11.5727>, <-0.795745,
0, -0.605632>, <-5.986, 20.5055, 10.816>, <-0.795745, 0, -0.605632>,
<-5.986, 20.7522, 10.816>, <-0.795745, 0, -0.605632> }
<-7.13786, 20.999, 12.3295>, <-0.795745, 0, -0.605632>, <-6.56193, 20.7522,
   smooth_triangle { <-7.13786, 20.5055, 12.3295>, <0.825344, 0, -0.56463>,
<-7.13786, 20.999, 12.3295>, <0.825344, 0, -0.56463>, <-7.43147, 20.5055,
11.9003>, <0.825344, 0, -0.56463> }
   smooth_triangle { <-7.43147, 20.5055, 11.9003>, <0.825344, 0, -0.56463>,
<-7.72509, 20.999, 11.4711>, <0.825344, 0, -0.56463>, <-7.72509, 20.5055,
11.4711>, <0.825344, 0, -0.56463> }
   smooth_triangle { <-7.72509, 21.4924, 11.4711>, <0.825344, 0, -0.56463>,
<-7.72509, 20.999, 11.4711>, <0.825344, 0, -0.56463>, <-7.43147, 21.4924,
   smooth_triangle { <-7.43147, 21.4924, 11.9003>, <0.825344, 0, -0.56463>,
<-7.13786, 20.999, 12.3295>, <0.825344, 0, -0.56463>, <-7.13786, 21.4924,
12.3295>, <0.825344, 0, -0.56463> }
   smooth_triangle { <-7.13786, 20.999, 12.3295>, <0.825344, 0, -0.56463>,
<-7.72509, 20.999, 11.4711>, <0.825344, 0, -0.56463>, <-7.43147, 20.5055,
   smooth_triangle { <-7.72509, 20.999, 11.4711>, <0.825344, 0, -0.56463>,
<-7.13786, 20.999, 12.3295>, <0.825344, 0, -0.56463>, <-7.43147, 21.4924,
   smooth_triangle { <-7.72509, 20.5055, 11.4711>, <-0.866013,
0, -0.500022>, <-7.72509, 20.999, 11.4711>, <-0.866013, 0, -0.500022>,
<-8.34243, 20.5055, 12.5403>, <-0.866013, 0, -0.500022> }
   smooth_triangle { <-8.34243, 20.5055, 12.5403>, <-0.866013,
0, -0.500022>, <-8.95976, 21.4924, 13.6095>, <-0.866013, 0, -0.500022>,
<-8.95976, 20.5055, 13.6095>, <-0.866013, 0, -0.500022> }
   smooth_triangle { <-8.95976, 20.5055, 13.6095>, <-0.866013,
0, -0.500022>, <-9.5771, 21.4924, 14.6787>, <-0.866013, 0, -0.500022>,
<-9.5771, 20.5055, 14.6787>, <-0.866013, 0, -0.500022> }
   smooth_triangle { <-9.5771, 21.4924, 14.6787>, <-0.866013, 0, -0.500022>,
<-8.95976, 20.5055, 13.6095>, <-0.866013, 0, -0.500022>, <-8.95976, 21.4924,
   smooth_triangle { <-8.95976, 21.4924, 13.6095>, <-0.866013,
0, -0.500022>, <-8.34243, 20.5055, 12.5403>, <-0.866013, 0, -0.500022>,
<-8.34243, 21.4924, 12.5403>, <-0.866013, 0, -0.500022> }
   smooth_triangle { <-8.34243, 21.4924, 12.5403>, <-0.866013,
<-7.72509, 21.4924, 11.4711>, <-0.866013, 0, -0.500022> }
   smooth_triangle { <-7.72509, 20.999, 11.4711>, <-0.866013, 0, -0.500022>,
<-8.34243, 21.4924, 12.5403>, <-0.866013, 0, -0.500022>, <-8.34243, 20.5055,
   smooth_triangle { <-9.5771, 20.5055, 14.6787>, <0.917712, 0, -0.397246>,
<-10.3789, 21.4924, 12.8264>, <0.917712, 0, -0.397246>, <-10.3789, 20.5055,
12.8264>, <0.917712, 0, -0.397246> }
   smooth_triangle { <-10.3789, 20.5055, 12.8264>, <0.917712, 0, -0.397246>,
<-11.1807, 21.4924, 10.9741>, <0.917712, 0, -0.397246>, <-11.1807, 20.5055,
10.9741>, <0.917712, 0, -0.397246> }
   smooth_triangle { <-11.1807, 20.5055, 10.9741>, <0.917712, 0, -0.397246>,
<-11.9825, 21.4924, 9.12187>, <0.917712, 0, -0.397246>, <-11.9825, 20.5055,
9.12187>, <0.917712, 0, -0.397246> }
   smooth_triangle { <-11.9825, 20.5055, 9.12187>, <0.917712, 0, -0.397246>,
<-12.7843, 21.4924, 7.2696>, <0.917712, 0, -0.397246>, <-12.7843, 20.5055,
7.2696>, <0.917712, 0, -0.397246> }
   smooth_triangle { <-12.7843, 21.4924, 7.2696>, <0.917712, 0, -0.397246>,
<-11.9825, 20.5055, 9.12187>, <0.917712, 0, -0.397246>, <-11.9825, 21.4924,
   smooth_triangle { <-11.9825, 21.4924, 9.12187>, <0.917712, 0, -0.397246>,
<-11.1807, 20.5055, 10.9741>, <0.917712, 0, -0.397246>, <-11.1807, 21.4924,
   smooth_triangle { <-11.1807, 21.4924, 10.9741>, <0.917712, 0, -0.397246>,
<-10.3789, 20.5055, 12.8264>, <0.917712, 0, -0.397246>, <-10.3789, 21.4924,
   smooth_triangle { <-10.3789, 21.4924, 12.8264>, <0.917712, 0, -0.397246>,
<-9.5771, 20.5055, 14.6787>, <0.917712, 0, -0.397246>, <-9.5771, 21.4924,
14.6787>, <0.917712, 0, -0.397246> }
   smooth_triangle { <-12.7843, 20.5055, 7.2696>, <-0.751742, 0, -0.659457>,
<-13.7803, 21.4924, 8.40506>, <-0.751742, 0, -0.659457>, <-13.7803, 20.5055,
8.40506>, <-0.751742, 0, -0.659457> }
   smooth_triangle { <-13.7803, 20.5055, 8.40506>, <-0.751742,
0, -0.659457>, <-14.7764, 21.4924, 9.54053>, <-0.751742, 0, -0.659457>,
<-14.7764, 20.5055, 9.54053>, <-0.751742, 0, -0.659457> }
   smooth_triangle { <-14.7764, 20.5055, 9.54053>, <-0.751742,
0, -0.659457>, <-15.7725, 21.4924, 10.676>, <-0.751742, 0, -0.659457>,
<-15.7725, 20.5055, 10.676>, <-0.751742, 0, -0.659457> }
   smooth_triangle { <-15.7725, 21.4924, 10.676>, <-0.751742, 0, -0.659457>,
<-14.7764, 20.5055, 9.54053>, <-0.751742, 0, -0.659457>, <-14.7764, 21.4924,
   smooth_triangle { <-14.7764, 21.4924, 9.54053>, <-0.751742,
0, -0.659457>, <-13.7803, 20.5055, 8.40506>, <-0.751742, 0, -0.659457>,
<-13.7803, 21.4924, 8.40506>, <-0.751742, 0, -0.659457> }
   smooth_triangle { <-13.7803, 21.4924, 8.40506>, <-0.751742,
0, -0.659457>, <-12.7843, 20.5055, 7.2696>, <-0.751742, 0, -0.659457>,
<-12.7843, 21.4924, 7.2696>, <-0.751742, 0, -0.659457> }
   smooth_triangle { <-15.7725, 20.5055, 10.676>, <0.808656, 0, -0.588282>,
<-16.2885, 21.4924, 9.9667>, <0.808656, 0, -0.588282>, <-16.2885, 20.5055,
9.9667>, <0.808656, 0, -0.588282> }
   smooth_triangle { <-16.2885, 20.5055, 9.9667>, <0.808656, 0, -0.588282>,
<-16.8045, 20.999, 9.2574>, <0.808656, 0, -0.588282>, <-16.8045, 20.5055,
9.2574>, <0.808656, 0, -0.588282> }
   smooth_triangle { <-16.8045, 21.4924, 9.2574>, <0.808656, 0, -0.588282>,
<-16.8045, 20.999, 9.2574>, <0.808656, 0, -0.588282>, <-16.2885, 21.4924,
   smooth_triangle { <-16.2885, 21.4924, 9.9667>, <0.808656, 0, -0.588282>,
<-15.7725, 20.5055, 10.676>, <0.808656, 0, -0.588282>, <-15.7725, 21.4924,
10.676>, <0.808656, 0, -0.588282> }
<-16.8045, 20.999, 9.2574>, <0.808656, 0, -0.588282>, <-16.2885, 20.5055,
   smooth_triangle { <-16.8045, 20.5055, 9.2574>, <-0.766236, 0, -0.642559>,
<-16.8045, 20.999, 9.2574>, <-0.766236, 0, -0.642559>, <-17.196, 20.5055,
9.72424>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.196, 20.5055, 9.72424>, <-0.766236, 0, -0.642559>,
<-17.196, 21.4924, 9.72424>, <-0.766236, 0, -0.642559>, <-17.5874, 20.5055,
10.1911>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.5874, 20.5055, 10.1911>, <-0.766236,
0, -0.642559>, <-17.9789, 20.999, 10.6579>, <-0.766236, 0, -0.642559>,
<-17.9789, 20.5055, 10.6579>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.9789, 21.4924, 10.6579>, <-0.766236,
<-17.5874, 21.4924, 10.1911>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.5874, 21.4924, 10.1911>, <-0.766236,
0, -0.642559>, <-17.5874, 20.5055, 10.1911>, <-0.766236, 0, -0.642559>,
<-17.196, 21.4924, 9.72424>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.196, 21.4924, 9.72424>, <-0.766236, 0, -0.642559>,
<-16.8045, 20.999, 9.2574>, <-0.766236, 0, -0.642559>, <-16.8045, 21.4924,
9.2574>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-16.8045, 20.999, 9.2574>, <-0.766236, 0, -0.642559>,
<-17.196, 21.4924, 9.72424>, <-0.766236, 0, -0.642559>, <-17.196, 20.5055,
0, -0.642559>, <-17.5874, 21.4924, 10.1911>, <-0.766236, 0, -0.642559>,
<-17.9789, 20.999, 10.6579>, <-0.766236, 0, -0.642559> }
   smooth_triangle { <-17.9789, 20.5055, 10.6579>, <0.999996,
0, -0.0026778>, <-17.9789, 20.999, 10.6579>, <0.999996, 0, -0.0026778>,
<-17.9823, 20.5055, 9.39164>, <0.999996, 0, -0.0026778> }
   smooth_triangle { <-17.9823, 20.5055, 9.39164>, <0.999996,
0, -0.0026778>, <-17.9823, 21.4924, 9.39164>, <0.999996, 0, -0.0026778>,
<-17.9857, 20.5055, 8.12537>, <0.999996, 0, -0.0026778> }
   smooth_triangle { <-17.9857, 21.4924, 8.12537>, <0.999996,
0, -0.0026778>, <-17.9857, 20.5055, 8.12537>, <0.999996, 0, -0.0026778>,
<-17.9823, 21.4924, 9.39164>, <0.999996, 0, -0.0026778> }
   smooth_triangle { <-17.9823, 21.4924, 9.39164>, <0.999996,
<-17.9789, 21.4924, 10.6579>, <0.999996, 0, -0.0026778> }
   smooth_triangle { <-17.9789, 20.999, 10.6579>, <0.999996, 0, -0.0026778>,
<-17.9823, 21.4924, 9.39164>, <0.999996, 0, -0.0026778>, <-17.9823, 20.5055,
   texture { Flag6 }
#declare logo= union {
 Flag1_mesh
Flag2_mesh
Flag3_mesh
Flag4_mesh
Flag5_mesh
Flag6_mesh
Cube1_mesh }
Subject: Re: Newbee question
Date: 15 Jan 1970 14:50:44
Message: <01bd21e5$28c70180$cb681cce@arkansasusa.com.arkansasusa.com>
 { Flag1_mesh }
 { Flag2_mesh }
 { Flag3_mesh }
 { Flag4_mesh }
 { Flag5_mesh }
 { Flag6_mesh }
 { Cube1_mesh } }
 Should work :) Personally, I like to leave in all the object statements.
#declare logo= object { union {
object {  Flag1_mesh }
object { Flag2_mesh }
object { Flag3_mesh }
object { Flag4_mesh }
object {Flag5_mesh }
object { Flag6_mesh }
object { Cube1_mesh } } }
Paul Hinds
gri### [at] swbellnet
Date: 16 Jan 1998 00:57:16
Message: <34bf0486.0@news.povray.org>
Yepper, that did the trick..
Many thanks to all who responded. Just goes to show that sometimes, no
matter how many times you RTFM, it still does not explain EXACTLY how to do
it.
I'LL BE BACK !!
