POV-Ray : Newsgroups : povray.binaries.scene-files : Virtual Real Estate Plots FREE!! Server Time
11 Jun 2026 02:03:47 EDT (-0400)
  Virtual Real Estate Plots FREE!! (Message 54 to 63 of 83)
Subject: Re: Virtual Real Estate Plots FREE!!
Date: 18 Dec 1997 18:12:02
Message: <3499ADC2.C1305BE0@worldnet.att.net>
Kardal wrote:
> Brook Monroe wrote:
> I've been spoiled by the powerful and expensive CADKey 97 (www.cadkey.com).
Oh, ~expensive~.  Well, I was going to look, but I can't afford expensive right now.
> Unfortunatley, I can't use it for pov because there is no cheap direct, or even
> indirect, way to export to pov.  It exports Autocad DXF files, but I haven't found
> a good DXF to Anything I Can Use converter.
Any of the DXF-to-POV converters I've seen produce less than useful results because
you can't tag different parts of the object with different textures--everything comes
out as a monolithic mesh.  That's not much use when you're rendering an F-14 or
what-have-you.  The Win32 version still sports the 4-view interface, which is what
attracted me to Moray in the first place.  (That, and the lack of that annoying
"command-line" thing that AutoCad and MNM do.)
jbm!
Date: 19 Dec 1997 00:17:43
Message: <349A0377.63DA@coastlink.com.au>
There is one out there, I had it a while ago and lost the zip of
it...you can export dxf-pov and either label parts with a texture
(pov-original) before export or in the pov code the parts are either
union triangles or bicubics, separate, and can be re textured.
It very much depends on the original dxf, I've found - some let you
export parts, other seem to be one unit...???
** Lets clean up the world - kill a politician today!!
** The only good politician is a dead politician.
** To email me: bay### [at] coastlinkcomau
** Believe 1% of what you see or hear.
** Always read between the lines.
Date: 17 Dec 1997 22:51:54
Message: <34989DDA.16A8@clara.net>
Actually it really depends on the program you are importing the dxf
into. dxf supports both layers and different colours for the various
parts. For example: Extreme 3d imports dxf files but for some reason
totaly ignores the layers. If you want sperate the pieces you need to
make them different colours even although extreme 3d supports layers??!!
On the other hand, Breeze Designer just imports the dxf file as a big
mesh(actually as a 2d dxf extrusion I think but its about the same
thing) and so you can't texturize the seperate parts.
what it all sums up as is that I personally hate the dxf format because
the files are large and clumsy. I'd have prefered it if the .3ds format
was standard as its files are more compact. Admittedly it is binary and
I think there may be problems with transfering it between to types of
computers but then you can just use .asc files which are the plain text
versions of 3ds files....
Cheers, Matthew
P.S. Have you tried WCVT2POV? Wriiten by Keith Rule. Try a serach on
altavista as I've lost the url to his webpage....
Date: 23 Dec 1997 16:40:33
Message: <34A02FD0.C42D7314@geocities.com>
> Cheers, Matthew
 Tried it, did not work.  Shame.
~Kardal~
Date: 3 Jan 1998 01:23:03
Message: <34ADD947.EE38FE54@primary.net>
I would bet that Crossroads(the new and improved version of WCVT2POV) would
convert it. Try it out.
> > Cheers, Matthew
> ~Kardal~
                    Bryan Cool
       http://xoom.com/Cool3d/ - Cool3D
       http://www.geocities.com/Area51/Cavern/5621/
             Bryan Cool's Web of Spider-Man
Date: 10 Jan 1998 12:38:35
Message: <34B7B21B.A44@emc.com>
Michael,
	If you see this please give me a city block number!  I
	have sent email twice, perhaps it did not get through.
_John Miskinis_
Date: 13 Jan 1998 15:35:49
Message: <34bbcabc.2283284@news.povray.org>
John,
On Sat, 10 Jan 1998 12:38:35 -0500, John Miskinis <mis### [at] emccom>
wrote:
>Michael,
>_John Miskinis_
I have replied twice !
Did you get any of them ?  If not, what is your e-mail address?
I've tried mis### [at] emccom, which bounced, and mis### [at] milemccom
and mis### [at] docmilemccom which didn't bounce.
Bye for now
Michael
Copied message:-
Hello John,
John Miskinis wrote:
> Hi,
>         This was/is a very cool idea.  I would like to join this
>         effort.  Please assign me a "spot", and I'll create a
>         basic scene, and build on it over time.
Thanks John.
Your block has been claimed.  I'll be updating my homepage soon with a
guide for builders, but briefly, this is all you should need to get
started.
The blocks are +112.5 units in the X and Z directions( 225m square),
+Y is up,and yours is the block whose centre is translated < -125, 0,
-875 >
from the origin. The scale is 1 unit = 1 metre.
The ground for the city is a plane with a 1000 unit deep box cut from
it
under the city to allow cunstruction below ground level.  This means
that your file will need to contain your own ground, with a line
something
like this:-
box {<-112.5,0,-112.5> <112.5,-.1,112.5> translate < -125, 0, -875 >
pigment
 {color rgb <0.1,0.8,0.1>}}
Your contribution can use bitmaps and multiple .inc files, but should
be
sent as one compressed file if possible.  To avoid file name clashes I
am
allocating everyone a prefix for their filenames, yours is "bb".
Please
start all of your filenames with this, and please use only lower case
in
your filenames.
I look forward to seeing your contribution,
Bye for now
Michael
Date: 13 Jan 1998 16:19:58
Message: <34BBDA7E.7EC876D0@geocities.com>
I think that maybe it's time to start a new VR Plot thread, this one is 15
messages deep!
~Kardal~
P.S.  My plot update is coming in a week or so.
Michael Kent wrote:
> John,
> wrote:
> >Michael,
> >_John Miskinis_
> Bye for now
> Michael
> Copied message:-
> Hello John,
> > Hi,
> Thanks John.
> started.
> -875 >
> it
> something
> like this:-
> pigment
> be
> am
> Please
> in
> your filenames.
> Bye for now
> Michael
Date: 14 Jan 1998 19:01:10
Message: <34BD51C6.12ED989E@mordor.tho.org>
> one is 15 messages deep!
Or possibly a newsgroup to itself since this is an ongoing project.
Andy McCoy
Date: 26 Jan 1970 05:38:52
Message: <01bd2a40$29bd7e80$0f316dc2@test>
Sound good to me.
Please also reply by E-mail.
Please remove the 'no spam' # from my address when replying by E-mail
Andy McCoy <sau### [at] mordorthoorg> schreef in artikel
<34BD51C6.12ED989E@mordor.tho.org>...
> Andy McCoy
