POV-Ray : Newsgroups : povray.binaries.scene-files : Virtual Real Estate Plots FREE!! Server Time
11 Jun 2026 02:03:47 EDT (-0400)
  Virtual Real Estate Plots FREE!! (Message 31 to 40 of 83)
Subject: Re: Virtual Real Estate Plots FREE!!
Date: 27 Dec 1997 02:04:04
Message: <34A4A864.1F45@aol.nonet.com>
Brook Monroe wrote:
> The Y axis is UP?  What country did YOU study geometry in? <G> This is
> going to ruddy well make things difficult to produce in Moray, you know.
Yes.  Hold up sheet of paper.  Draw x-y graph... x goes across the
bottom, y goes up the page... now add z... that goes on sheets of paper
placed in front of or behind your first page.
Y is UP.
Robert J Becraft
aka cas### [at] aolcom
Date: 28 Dec 1997 03:43:52
Message: <34A61148.33CB@cityscape.co.uk>
> Y is UP.
> Regards,
> Robert J Becraft
Personally I agree - Up with Y.
The only thing is that there is no sensible argument either way: so to
counter my own opinion, and your argument, lets say you leave this piece
of paper on the table where you drew your X and Y axis. Surely the
sensible place for the Z is perpendicular to the other two lines heading
Up.
My argument is asfloorless as the previous one, and therfore equally
floored.
Think on...
Rob
(actually rox### [at] geocitiescom)
Date: 28 Dec 1997 23:11:37
Message: <34A722F9.BF233C6A@worldnet.att.net>
> > Y is UP.
> > Regards,
> > Robert J Becraft
> Up.
> floored.
> Think on...
> Rob
  BearFace and I have agreed that he and I both are right, that Z is up AND that
Y is up, and from now on, we're just going to split the difference and say X is
up, just to keep things simple. <G>
jbm!
Date: 29 Dec 1997 20:02:40
Message: <34a84806.4540198@news.povray.org>
On Sun, 28 Dec 1997 23:11:37 -0500, Brook Monroe
Why not just add in a W vector?
Date: 22 Jan 1998 17:46:48
Message: <34c7da88.0@news.povray.org>
Daniel Beeston wrote in message <34a84806.4540198@news.povray.org>...
I think the 4th vector is T (time).
Eric Freeman
"Either this man is dead or my watch has stopped."
- Groucho Marx
http://www.geocities.com/SiliconValley/Heights/2354/
http://www.datasync.com/~reba/
Date: 23 Jan 1970 09:49:12
Message: <01bd2807$95d09980$08316dc2@test>
And we already have that in POV
Please also reply by E-mail.
Please remove the 'no spam' # from my address when replying by E-mail
Eric Freeman <eri### [at] geocitiescom> schreef in artikel
<34c7da88.0@news.povray.org>...
> Eric Freeman
> - Groucho Marx
Date: 28 Dec 1997 23:13:29
Message: <34A72368.237A4499@worldnet.att.net>
> Y is UP.
> Regards,
> Robert J Becraft
  Study format of U.S. Geological Survey data.  X and Y comprise map surface,
Z is altitude.  We're building a city--geography, not geometry. I rest my
case.
jbm!
Date: 29 Dec 1997 14:34:12
Message: <34A7FB34.EFD912BE@geocities.com>
> > Y is UP.
> > Regards,
> > Robert J Becraft
> case.
> jbm!
 I say who cares.  What's important is that our scenes look good.
Maybe there should be a separate POV-City for those who want to do it the other
way.  I'd be willing to manage it, and I could usually update it once a day, if
needed.
Opinions?
~Kardal~
http://www.geocities.com/SiliconValley/2352/povpage.html
Date: 11 Dec 1997 20:22:37
Message: <3490a099.0@news.povray.org>
Just some ideas I have.....
So have it so that everybody uses the vartiable "Detail" to be able to
remove parts, or the detail of the parts of their scene,
Ie, have say detail = 1 to be the highest, and so one down.
so for my current scene I could say something like
#if(Detail <3)
    do the fence
#else
   do some boxes that approximate the fence
So if the Detail level is 2 or more then the fence will be created in all of
it's glory, or just four boxes that will go where the fence is.
Now if all the plots use the same method for the detail, then you could have
the Detail level defined at the top and have the value trickle down through
the plots.
Another way of doing the detail, so that everybody stays with in the same
boundies, would to make the detail level a distance, so if this part of the
plot is only move into the higher detail level if the camera is within  X
units of the object.
To do this, have the camera position defined as a vector = CameraPos
Then inside each plot use the vlength(thisobjectpos-CameraPos) to provide a
dist from the object inside the plot to the camera, so with the above
example I could change that to,
#if(vlength(FencePos-CameraPos)<5) // 5 units
    lets show the whole fence
#else
    just use the less detailed version
Anyway this is just an idea.......
Now for something slightly different.....
For a river... Would this work...
Create a heightfield, flip it upside down. This would now define the river
bed.
Intersect it with a blue box that has been textured etc, and this would give
the water flowing through the river. I think ??? Not sure . Haven't tried...
Now for the axis bit.  I use the left-handed system, as I have always used a
text editor, and never bothered with a modeler. For me I have always thought
of Y as height, Don't know why, just have so for me I find it easier that
way.
And for the diminsions - I use 1 unit = 1 meter, so to make it work within
the system of 1 unit = 25 meters, I have defined a var called ScaleValue = 1
/25, and at the bottom of my file put
#declare FransPlot =
union {
    object {bit1}
    object {bit2}
    scale ScaleValue
    translate PlotPos
Now when I'm testing my plot I define a var called Testing and use in my
plot file
#ifdef(Testing)
    #declare ScaleValue = 1
#else
    #declare ScaleValue = 1/25
etc.
BTW the usable unit range I have found in POVRay is ~ 1,000,000
Objects that are further than 1,000,000 units away from the camera
disappear, no matter how large they are. Most of the time for a small object
when it is 1,000,000 units away you wouldn't be able to see it anyway, but
if there is a large object like (eg a sun/planet) then suddenly is goes
away. I don't know yet what the smallest part of a unit that is useable, but
I don't think 25 meters to 1 unit is unrealistic. This should mean that you
could model down to around the 1cm region, or (.00004 of a unit), and that
is alot more resolution than I will probably need.
Also if you wanted to do a more detailed part of your own plot on your own
page, then change the above ScaleValue to 1 and render and wot ever you
modeled at.
Just my thoughts on the subject
Till next time.... Fran.
Date: 12 Dec 1997 19:07:09
Message: <3491D1AD.EE653824@bigfoot.com>
Great thinking, suits me fine if ever I'm going to design a plot.
But young lads not up to that sort of thinking might burn a fuse there
;-) ye know who I'm talking about I guess.
Fran Firman wrote:
> #if(Detail <3)
>     do the fence
> #else
> #end
> #else
> #end
