POV-Ray : Newsgroups : povray.binaries.scene-files : Virtual Real Estate Plots FREE!! Server Time
11 Jun 2026 00:21:46 EDT (-0400)
  Virtual Real Estate Plots FREE!! (Message 21 to 30 of 83)
Subject: Re: Virtual Real Estate Plots FREE!!
Date: 29 Dec 1970 10:21:58
Message: <01bd1467$05d6eb80$1b316dc2@test>
To get around your problem, maybe this will help: 1 unit is (about) 10
inches.
Please also reply by E-mail.
Please remove the 'no spam' # from my address when replying by E-mail
Brook Monroe <rin### [at] worldnetattnet> schreef in artikel
<3490208C.C0FE5858@worldnet.att.net>...
> Alain CULOS wrote:
> > Hi Pals,
> > Sorry to say you are all besides the point.
> Principles are never besides the point.
> > POV-Ray handles very well both left and right handed systems, just
check
> > your docs, in WinPov 3.01 check sections :
> > ==> 4.1.1 Understanding POV-Ray's Coordinate System
> > and
> > ==>7.4.4.5.2 Handedness
> Whatever.
> > That being said, a choice as been made by the main contractor to build
a
> > left handed world, not a single problem, the one who builds a right
> > handed system will simply have to scale his model to <1, 1, -1> then
> > rotate it appropriately so that it matches the right directions, then
> > translate to the plot - easy.
> Great, then I'll just send my scene files to you and you can do it.  It's
> already going to be hard enough to create something at the microscopic
scale
> of 1 unit = 25m (= 82 ft), without having to re-do the scaling and
rotation
> at the end.
> And I still say Z is altitude.
> jbm!
Date: 11 Jan 1998 04:31:15
Message: <34B89163.58E0@netonecom.net>
The fun everyone is having.  GEESH!
I just put my monitor on the floor facing up and sit really, really
close.  Z is up and working in miniture is easy.
Date: 11 Jan 1998 13:42:09
Message: <34B91281.3A41@aol.nonet.com>
Actually, wouldn't you need to hang it from the ceiling to be accurate??
Robert J Becraft
aka cas### [at] aolcom  <--- the real me.
Date: 11 Jan 1970 18:46:02
Message: <01bd1ee1$f3606e60$be163acb@Ambient>
That could lead to some interesting headlines:  Man killed after monitor
falls from the sky! ;-)
Date: 11 Dec 1997 12:12:06
Message: <34901EE6.35AD09D3@worldnet.att.net>
Kardal wrote:
> Up until today I was doing my geometry wrong also, until I asked my math
> teacher which was axis should be pointing.
> It really shouldn't be that much trouble.  Just model it in Moray like you
> always would, but keep it centered on <0,0,0>.  You can then fix it with a
> couple rotate and translate commands.
> Being an American, using the metric system (1 unit = 25 meters) will be alien
> to me as well.  That is not so easily fixed.
> Don't be suprised if my residence is scaled wrong. : )
> ~Kardal~
Your geometry teacher supported the idea that the Y axis is altitude in a 3-axis
system?  No wonder the American education system is going to Hell...<G>
I'm not happy with 1 unit=25 meters, either.  I usually use a 1 unit = 1 meter or
1 unit = 1 foot scale (depending on what I'm creating); our entire house would
fit into 1/5 of a unit square at his scale.  I'm not used to drawing things so
small.  That's a lot of detail to cram into a small space, I'm thinking.
jbm!
Date: 11 Dec 1997 16:14:14
Message: <349057A6.59CE255C@geocities.com>
> jbm!
I agree with you 100%!  : )
It really should be 1 unit = 1 meter or whatever, even if you do have 5 or 6 digit
numbers after the city starts to get put together, it will make the dimesions seem
more realistic.  This should be fixed asap before this city gets set up too much.
Also, the city uses an ordinary flat plane for the ground.  This could be a problem
if you want a basement.  I think it would be better if you had to have a green cube
underneath your house and you could difference it as needed.  Plus, it adds the
creativity options of being able to set up a desert palace or a volcano fortress by
changing the color and texture of the ground.  Hmm...
~Kardal~
Date: 15 Dec 1997 09:28:05
Message: <34953E75.C1C805EB@cs.byu.edu>
Yah, I'm an american too and the metric stuff always gets me.  so what
i did was make a few defines, as follows:
  // in case i want to conform with the world...
  #declare jgbMeter      = 1/25
  #declare jgbCentimeter = jgbMeter * 0.01
  #declare jgbMillimeter = jgbMeter * 0.001
  // in case i don't... :)
  #declare jgbFoot       = jgbMeter / 3.281
  #declare jgbYard       = jgbFoot * 3
  #declare jgbInch       = jgbFoot / 12
(my initials are jgb, so i append all my variables for my plot with them
so that I can avoid conflicts with someone elses variables).  Then,
whenever I specify sizes & translations & positions, I just say, for
examples, "5*jgbFoot" and voila! i get five feet in the scale
specified.  and i can even mix metric and imperial since the definition
of jgbFoot is based on the definition of jgbMeter.
Anyway.  Just a suggestion i thought might help some people, since it
has saved my hide many times!
- ciao!
Jamis Buck
buc### [at] csbyuedu
> ~Kardal~
> George Hunt wrote:
> > On Tue, 09 Dec 1997 21:42:01 -0500, Brook Monroe
> > <rin### [at] worldnetattnet> wrote:
> > >The Y axis is UP?  What country did YOU study geometry in? <G> This is
> > >going to ruddy well make things difficult to produce in Moray, you know.
> > Well, you know, that was my first thought.  I'm a long time user and
> > strong supporter of MORAY.   And although Y=UP is a bit alien to me
> > now too, it shouldn't be a problem.  I intend to use MORAY (for
> > Windows) and just build everything so that Y is UP, even if MORAY
> > thinks Z is up.   I could be wrong --- I havn't tried it yet --- but
> > it should work.
> > George Hunt --- Raytracer Obsessivo
> > http://ourworld.compuserve.com/homepages/lightsword
> > 102### [at] compuservecom
Date: 28 Dec 1997 03:29:26
Message: <34A60DE6.4D50@cityscape.co.uk>
There is no "correct" way - just go with the rules specified, as you
say, all it does is give you a tiny bit of hassle at the end before you
post your efforts.
Surely you realise that scaling is just arbitary - if you are using 1
metre not 25, then the whole scene (probably unioned) simply requires a
"scale 1/25".
Mind you, thats all a bit daft now, as the scale has been changed to 1
unit = 1 metre anyway.
> ~Kardal~
i'm actualy using my dads machine at the minute, and my own address is
rox### [at] geocitiescom
Regards Rob
Date: 28 Dec 1997 14:24:07
Message: <34A6A757.5BDB8D43@geocities.com>
> "scale 1/25".
That's what I meant.
You should check the date on the message you reply to before wording a sentence
that way.
> > ~Kardal~
> Regards Rob
 ~Kardal~
Date: 11 Dec 1997 12:09:09
Message: <34901E35.6C21133B@worldnet.att.net>
> it should work.
Well, it MIGHT--but that don't make it right.  Most navigational systems use
X/Y for surface coordinates and Z for altitudes.  Maybe I'm just being too,
um, retentive here, but it bothers me.
jbm!
