POV-Ray : Newsgroups : povray.binaries.scene-files : AT Devil Plate : Re: AT Devil Plate Server Time
6 Mar 2026 18:22:46 EST (-0500)
  Re: AT Devil Plate
Date: 13 May 2025 10:20:00
Message: <web.68235495d1f5ea8e5e45bf3825979125@news.povray.org>
"Droj" <803### [at] drojde> wrote:
> When you mentioned to use the function f_r (x, y, z) - although I do not have a
> clue what it does (there is no comment in functions.inc)
You need to check the wiki entry under functions.inc
f_r(x,y,z): When used alone, the R function gives a surface that consists of all
the points that are a specific distance (threshold value) from the origin,
So basically you're just comparing your surface to a spherical shell.
At least you were able to work something out and get a decent result.
Isosurfaces can certainly be tricky, especially since we don't have vector
functions and certain inbuilt functions that other software packages pull from
libraries.
Chris R does everything with isosurfaces - maybe he can focus his highly trained
mind on it.
- BW
