POV-Ray : Newsgroups : povray.binaries.scene-files : Dakota Red Granite macro - beta #1.2 : Re: Dakota Red Granite macro - beta #1.2 Server Time
17 Dec 2025 05:57:25 EST (-0500)
Date: 24 May 2021 06:25:00
Message: <web.60ab7e4cc1167ed21f9dae3025979125@news.povray.org>
> Right. I was sure I would get this comment! ;-)
> I was lazy of course and pushed it forwards.
Sometimes it's best to just push it back out into the wild.
> > But maybe to alert the user to the fact that they may have inadvertently left
> > out a parameter or used a misspelling/typo, issue a warning in the #ifndef
> > block.
> Hmm... yes, that might be smart. I need to think about this a bit.
> The following, I want to comment on separately. Needs more thoughts.
> In the meantime, I am also working on a working sslt set... Not so easy!
> For instance, a layered texture (veins!) makes sslt go bad.
I went looking for sslt scene code, and that rotating pyramid again...
and got sidetracked.
Here's some granite with HDR lighting and radiosity.
I noticed that I probably didn't scale the texture properly, and so I can't
really see any of the veins.  In my readings, clipka mentioned that having the
mm_per_unit setting was there to decouple the texture from POV-units and so be
independent of scaling effects.  We might want to do similar with a
default-if-not-supplied, and a debug/warning message saying what it got set to.
I think that sometimes it is a bit slow to render - depending on how the scene
is set up.   Maybe have some quick-color definitions set up.  For ridiculously
high quality, I'm guessing we'd want some switchable reflection built in as well
for the same not0 reasons.
Download 'dakotaredradiosity.png' (3990 KB)
Preview of image 'dakotaredradiosity.png'
