POV-Ray : Newsgroups : povray.binaries.programming : Call pov-render to picturebox Server Time
12 Jan 2026 22:47:57 EST (-0500)
  Call pov-render to picturebox (Message 1 to 6 of 6)
Subject: Call pov-render to picturebox
Date: 1 Jan 2011 22:03:39
Message: <op.vonur8vk0819q0@gdsentropy.nc.rr.com>
Hello,
How do you call povray to render in a PictureBox from c# in the way that
Moray does?
Is this a matter of something like this (Then loading the output image
into the PictureBox):
Process myProc = new Process();
myProc.StartInfo.Filename = "dir\abc.exe";
myProc.StartInfo.Arguments = "file1, file2, file3";
myProc.Start();
Or is there any api documentation (or code sample in any language) someone
can point me to?
Thanks!
Ian McDonald
Lean Agile .NET 4.0/MVC
Senior Application Architect,
Developer and Security Analyst
Subject: Re: Call pov-render to picturebox
Date: 1 Jan 2011 22:10:57
Message: <4d1fecc1$1@news.povray.org>
Am 02.01.2011 04:03, schrieb [GDS|Entropy]:
> Hello,
> Moray does?
> someone can point me to?
Yes: The Moray code :-P
There is a plug-in API for POV-Ray, which allows you to plug-in other
software (like Moray) into POV-Ray. There must be some kind of
documentation /somewhere/ on the web pages.
Date: 1 Jan 2011 22:25:01
Message: <web.4d1fefa6390f6d9db33ef0180@news.povray.org>
> > Hello,
> > Moray does?
You may also want to look for 'GUI Extension'.
Stephen S
Date: 2 Jan 2011 00:38:25
Message: <op.von1x6vw0819q0@gdsentropy.nc.rr.com>
>> Hello,
>> Moray does?
Oh...so that is open source now? Well...damn..I had no idea and will have
to look around for the source repository then..wherever that is..
Ok..I'll look for that then. Is that on the main pov site?
Keep in mind I do not have just all of the time in the world to look this
stuff up..I am a very busy person..so please forgive me if I ask questions
that may be answered "easily" if I were to have more of that precious
resource.. ;)
Ian McDonald
Date: 2 Jan 2011 00:42:34
Message: <op.von143js0819q0@gdsentropy.nc.rr.com>
>> > Hello,
>> that
>> > Moray does?
Very good then..I will look for that in Google too.
Failing my finding anything I can use there, I will just initiate a new
command-line process and pass the requisite variables, then load the
output to the picturebox...though that is a horribly kludgey solution. :|
> Stephen S
Ian McDonald
Date: 2 Jan 2011 10:05:01
Message: <web.4d20938f390f6d9dbba08f230@news.povray.org>
This does seem to come up every so often. There should be a FAQ. (Maybe there
is. I'll look after I post this.) Anyway, here are a couple of earlier
references.
http://news.povray.org/web.4c0165e33f4c95c6bba08f230%40news.povray.org
http://news.povray.org/web.4c5df3ad7c1e70dfbba08f230%40news.povray.org
Good luck.
