POV-Ray : Newsgroups : povray.binaries.programming : Blurred transparence patch - BlurTrans.zip (1/1) Server Time
31 Aug 2024 20:18:35 EDT (-0400)
  Blurred transparence patch - BlurTrans.zip (1/1) (Message 1 to 1 of 1)
Subject: Blurred transparence patch - BlurTrans.zip (1/1)
Date: 26 Jan 2000 17:55:25
Message: <chrishuff_99-24522A.17542326012000@news.povray.org>
Here it is, the new version of my blurred transparence patch. It is
quite a bit different from my previous patch in both syntax and the way
it is coded. This version is based on the MegaPOV 0.3 source, so you
need to have a working compile of MegaPOV 0.3 in order to use it.
I haven't had the time to write any decent documentation, but this is
the syntax for the blurred transparence patch, it should be pretty
obvious:
finish {
    transparence {
        transparence_blur AMOUNT
        blur_samples SAMPLES
global_settings {
    transparence {
        blur_max_trace LEVEL
        blur_max_adc AMOUNT
These are the files I had to modify and a brief description of the
changes in each one.
frame.h (Finish_Struct data)
tokenize.c (added tokens)
parse.h (added tokens)
parstxtr.c (added parse code to Parse_Finish)
parse.c (global_settings parse code)
povray.h (added Transparence_Blur_Max, Transparence_Blur_Max_ADC
variables for global_settings options)
povray.c (added initializers for global_settings options)
texture.c (added initializers for finish variables)
lighting.c (modified Refract(), Refract_Guts(), BacktraceRefract(),
compute_backtrace_texture(), etc. to allow blur, and added
Blurry_Trace(). Photons, motion blur, etc should work fine, but are
untested.)
Note: In layered textures, only the top layer will blur transparency. I
will try to fix this in a later version, but it shouldn't be a serious
problem for now.
Also, there is a "fix" for something that might be a bug with the
max_adc global setting for blurred reflection. It was stored as an
integer, and I think it should be a float. Those changes are in parse.c
and povray.h.
Also, this patch has just barely been tested. I don't think there are
any bugs left(other than the thing with layered textures), but there are
no guarantees.
Chris Huff
e-mail: chr### [at] yahoocom
Download 'BlurTrans.zip' (189 KB)
