POV-Ray : Newsgroups : povray.binaries.programming : Transform patch changed source files - transpat.zip (1/1) Server Time
28 Jan 2026 07:18:34 EST (-0500)
  Transform patch changed source files - transpat.zip (1/1) (Message 1 to 1 of 1)
Subject: Transform patch changed source files - transpat.zip (1/1)
Date: 24 Apr 2000 22:58:55
Message: <chrishuff_99-0E5DAA.22005824042000@news.povray.org>
Because of the large number of changes I have made, I am including the
whole files instead of listing the changes. However, I have also been
working on some other stuff...if you see something about "blur_matrix",
just ignore it. I think I weeded all of that stuff out, though. The
stuff relevant to the transform patch is pretty clearly identifiable.
This patch does two things:
1: it allows transform {...} blocks to be placed in objects, textures,
etc. There might be a problem with media densities, though, that portion
of the code doesn't seem to make any sense. It may be a bug.
Anyway, this means you can do things like this:
object {
    transform {
        transform identifier, rotate, translate, scale, etc...
The old syntax of "transform TRANSFORM_IDENTIFIER" is still supported.
2: it allows transforms to be inverted with the "inverse" keyword. Like
this:
object {
    transform {Trans}
    transform {Trans inverse}// this reverses the above transform
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Personal Web page: http://chrishuff.dhs.org/
Download 'transpat.zip' (99 KB)
