POV-Ray : Newsgroups : povray.binaries.programming : ppm.cpp patch Server Time
2 Feb 2026 00:49:07 EST (-0500)
  ppm.cpp patch (Message 1 to 5 of 5)
Subject: ppm.cpp patch
Date: 25 Jan 2003 07:19:04
Message: <3e3280b8@news.povray.org>
As reported in p.g, POV-Ray 3.5 does not read PPM files properly.
The proper format is
P6
width height
max_value
data
The POV reader expects the max_value on the same line as the width and
height.  If you don't want to patch POV-Ray, you can edit the PPM files
to make them work in POV.
Here's a patch to fix it. I only spent a short time on this, so it's
probably still broken but it loads the files that I've tried.
PoD.
Download 'us-ascii' (2 KB)
Subject: Re: ppm.cpp patch
Date: 25 Jan 2003 07:30:59
Message: <3E328383.AF4EAC00@gmx.de>
> P6
> width height
> max_value
> data
Just for the record, the only rule for spacing in the header of a ppm is
that between the values there is one or more whitespace (before the data
in binary ppm's only one whitespace is allowed).
Concerning your patch - i have not tested it but i never had problems
reading ppm's with POV-Ray.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 25 Jan 2003 08:43:45
Message: <pan.2003.01.25.13.43.44.95289@internode.on.net>
On Sat, 25 Jan 2003 13:30:59 +0100, Christoph Hormann wrote:
> PoD wrote:
>> As reported in p.g, POV-Ray 3.5 does not read PPM files properly. The
>> proper format is
>> P6
>> width height
>> max_value
>> data
But most if not all PPMs use the above format, possibly with comments as
well.
That's odd because the ppm code in 3.5a does not read normal PPM files.
Date: 25 Jan 2003 08:49:05
Message: <pan.2003.01.25.13.49.04.207903@internode.on.net>
I just looked at the code again, I'll change the code to skip all
white space and comments.
Date: 29 Jul 2003 21:55:01
Message: <web.3f2724af2009e4961c9f49180@news.povray.org>
  man ppm says that:
       - Whitespace (blanks, TABs, CRs, LFs).
